Are you currently in the market shopping for a new vehicle? A reporter would like to speak with you; please reach out to [email protected] by 10/21 for more details.
motor swap
oldsalerooldsalero Member Posts: 2
edited September 2014 in Buick
does anyone know if i can add a 3800 Series II Supercharged engine to my 2001 olds alero if not can you tell my wat engine will fit or wat i can do to my original 3400 engine
  • galaxiebeinggalaxiebeing Member Posts: 9
    Are you going to take it to the track? Seems if you're going to add an engine you would want to go to an 8. But then again, is there room for a bigger engine in your Alero? I understand the 3800 Chevy engine is very highly regarded-more so than the 3400, but, the 3400 is no dog, either. I would say, if you can get to a drag strip, talk to some of the successful drivers there who know about modifying engines or swapping in new ones and see where they direct you. I have seen a Maverick whip Corvettes and Porches by pulling a 9.5 qtr mile at 134+ mph. Unless I miss my guess, the engine in that Maverick is not stock. That's the kind of guy you want to talk to. :shades:
  • rdeschenerdeschene Member Posts: 331
    I'm quite certain that Eaton makes a supercharger that can be installed on the 3.4L engine. Probably the simplest way to increase engine power.
    http://www.finishlinewest.com/supercharger_heaven.htm
    part 10-34-001
  • montecarloss9montecarloss9 Member Posts: 8
    IT COULD BE DONE YOU COU GET MORE INFO ON MOTORSWAP.ORG BRIAN TEEL CAN HELP YOU HE'S AN EXPERT ON GM MOTOR SWAPPING
  • dougo77dougo77 Member Posts: 1
    Could someone help me with this? When I install my 454, will I need to change out my air conditioning box to a after market system? Also, will I need to move my power stiring pump to allow my headers to pass by without touching? It's going in a 88 Monte SS. Any feedback would be greatly apprciated! Thanks.
  • raina2raina2 Member Posts: 2
    Can I use a 93' Regal engine to swap with my 91' PAU? Will it be an easy swap or do I have to alter some things?
  • don165don165 Member Posts: 1
    I have 1998 pontiacgrandprixgt3800 motor will it work inmy 1997pontiacgrandprixsupercharger car?if so anything i need to know?
  • marz7marz7 Member Posts: 1
    can i swap the 6cyl for a V8 orV12 in my 1990 mercedes 300 SL. if so what yr engines
