2007 Outbacks
My dealer has some hidden away at a remote lot. I saw a new color: dark grey. And the MP3/AUX input in the armrest. The "wood" inlay was also now glossy (like it was under plastic), and I did not like this. He also mentioned XM radio (not sure if all models or just some). He did not have any brochures yet.
Cars101
http://www.edmunds.com/new/2007/subaru/outback/index.html
No more XT non-Limiteds. Sigh. Think I'll just keep my current car another year.
Bob
Does anyone out there have the amp/sub in there outback? Would you consider it a good option?
Any help with this would be greatly appreciated
My question is; Is AWD in the Outback a reactive, or proactive design?
By reactive (which is Haldex's design, used by Volvo, VW, Ford, Audi, GM, etc.), I mean the AWD doesn't kick in unless the front wheels slip, at which point the AWD turns on.
By proactive, I mean the AWD is always working.
http://www.subaru.com/sub/misc/coretech/index.html
-Brian
-mike
Any how, that's only the default power split, it actually adjust the minute you hit the gas, before there is any slip.
They key difference for a Subaru AWD system is that *ALL* of them are engineered for full-time use, i.e. they don't overheat or disengage above 29mph like certain Rotary Blade Coupling-based AWD systems do.
*cough* Honda *cough*
-juice
One oddity I find when pursuing Consumers Union reliability records... on their charts, most Subarus show way below average engine reliability after about 3-4 years.
Is this due to the timing belt? I have read on other Subaru forums that timing belts need to be replaced around 100K miles, or they will break and "lunch" the motor.
True? False?
FYI, my old '83 Camry, with fiberglass timing belts, had two replacements (and broke one anway - engine survived it). Not fun. :sick:
Some? All? The charts I have always seen from CU rank Subaru near the top in dependability. What have you been looking at, specifically?
Timing belts need to be replaced on all vehicles, and I do it way before 100K.
Yes, Subarus do well in general, but their engine "major reliability" catagory does not do as well as other brands like Toyota, Honda, etc,
More worrysome is the drive system on Forester and Impreza goes way below average after about 3 years. Legacy seems to do much better by comparison.
The 1996 Impreza I started racing at 120k miles and put on about 10-20k track miles and no issues.
The 1994 Legacy Turbo I got at 100k, it now has 150k, and I put on about 10-15k track miles and no motor issues.
-mike
Besides that, wheel bearings on Imprezas before 2002, and Forester before 2003, were a known issue.
What else? Not much, really. Those were the 2 biggest issues and they're resolved.
Last year's CR Auto Issue had Subaru as the most reliable brand period for MY2004. In this year's issue, all Subaru models scored better than any single Acura model.
Not bad, but nobody's perfect.
-juice
Overall good cars though. My opinion of mine continues to shift toward the fonder side of the spectrum the longer I own it. Had I not been flat broke in Oct of 2000, I would have sold it then and never looked back. As it is, it's been fun! :P
http://www.cars101.com/subaru/outback/outback2007.html#overview
Vehicles should be at dealers in late January.
Bob
There is also a rumor circulating on the net that the much higher mechanical reliability ratings for the 2005+ Outback/Legacy had been linked to the fact that the Indiana plant had switched to using the Boxer engines manufactured in Japan, instead of getting them from the localUS Supplier.
Cheers,
Matroskin
How do '06-07 outback seats fare in comfort for long trips? I usually make several 700 mile trips each year.
My current Malibu seats, save for a too-low lumbar support, remain comfortable for hours at a stretch.
Some reports I read remarked the Subaru seats were fine for short hauls, but didn't work all that well for long trips.
Knowing this will help me decide on the next car, for which Subaru is being considered.
Also, wonder if it'll have VDC?
-juice
Let us know if you come up with a solution.
Martin
P.S. If you have moisture in your front headlights like a couple of us with new 07s have reported, then we are in big trouble.
Does +15F count? Feels almost balmy warm here after -40 three days ago!
-mike
Bob
-mike
Might help some of you.
Nigel
The issue: The air coming out of the passenger-side vents, with the temperature knob set on maximum, the blower on maximum speed, and all dashboard-vents open, is not warm, while the air coming out of the driver's side vents is warm.
The question: What could be the origin?
Thanks, Marc
I looked very hard at the '07's at two auto shows but found the lack of this feature made it very hard to get really comfortable.
Also sorry to hear about the rattles. Hopefully Subaru will get this sorted out. Then again, I heard a fair number of rattles in a co-workers' new WTX.
Rattles... annoying. I am picking my car up momentarily from the dealership where, they say, all the rattles are fixed. I dropped it off yesterday morning, so considering they fixed all 4 rattles (lift gate, dash, glove box... was there another? Maybe only 3), I am hopeful.
I will provide better info after pickup.
Link to thread from "Subaru Legacy/Outback - Problems & Solutions"
http://townhall-talk.edmunds.com/WebX14@@.ef05e94/6699#6699
--Vinnie
The shift boot and P-brake boot were both cracked due to cold temps, so I had them replace those as well (replaced on 2/20). I fully expect that they will continue to crack in cold weather, so I will request replacement as frequently as I find new cracks. Not that this will be a long-term solution, but I figure 15-20 replacements before the 3/36 is up should be sufficient to help Subaru to consider using higher quality, more durable materials on future models. It is amazing how a manufacturer can regress over the years. Shift in focus, I suppose (no pun intended... really!).
What else? Oh, yes, the radio blipped out on me again Tuesday (2/20) when I started it at -20F. Not surprised there. I am all but convinced it is a result of the marginal OEM battery. I will look to replace it with something decent by next winter. I could either pay $60+ for a "battery blanket" to nurse this marginal battery or pay $90 for a good battery and skip the blanket. Hmm.... decisions.... :P I did not use the radio yet today, so not sure if it did it again this morning.
And, headlight assemblies..... will update that one in the dedicated thread.
