Quick Links
Quick Links
Are you under 40 and think that you might not be able to afford a brand new vehicle when you purchase your next car? If so, a reporter would like to talk to you. Please reach out to [email protected] by 12/16 for more details.
Those Dreadful State Vehicle Inspections
How do I make sure my vehicle will pass an inspection? What are the requirements? Who do I go to? What if my vehicle doesn't pass inspection? How much should I pay?
Ask your questions and share tips and information here!
The best way I can suggest you take care of this is take the required test by your state and then you dont have to worry about you vehicle failing the State Inspection. jk
Actually, someone in the Forums Discussion Finder wanted to know where to post about a question concerning the NJ state inspection. Since we didn't have any relevant topics I set this one up and rather than creating one for each of 50 states ... well you get the idea!
She hasn't found her way here yet but I'll be interested in reading what her question is!
So now instead of the normal tail pipe test to check emissions , they now want to check the Obd 11 , which checks your car's computer,and if you've had recent work on your car, such as the 2ND replacement (under warrenty) of the O2 sensors, or had a battery installed, it can interfere with the test, and the state won't pass you regardless if you have perfect brakes/lights etc. I went to Castle Hyundai, the car dealer, explained this to them, they said you have to drive the car around awhile for the computer codes to reset, enabling the state inspection to pass you. Until then certain codes cannot be read ny DMV. I ask what is the fix so I can pass. They told me to drive a few hundred more miles MORE because the 2002 sonata has a quirk that way, what a load of b/s.I'm thinking.
I've drived close to 800 miles since the work was done three weeks ago. Is this guy correct or should I go back to the dealer and have them fix/reset the computer so I am not sitting in line at the DMV and wasting my time ?
I'm just not seeing the logic. At the time of inspection, either the car's emissions are within requirements or they are not. The state of the OBD should have no bearing on that. But then no one said federal guidelines need to be logical.
That would explain it! I suppose it would reduce overall costs while placing a substantial burden on those with faulty computers - or battery problems.
The requirements for these tests are in federal regulation. These tests actually do help keep the air cleaner and can also let you know before some potential failures happen. The old tailpipe tests could only find a problem after an equipment failure had occurred.
I have read many stories about people having their check engine light come on. The OBD identifies a problem, they spend hundreds of dollars to fix that problem, and then the light come on again. Some people claim they have spent $2000 or more but the light keeps coming on.
In my opinion, the OBD reading cannot be trusted and it is causing car owners to waste a lot of money.
Computers don't lie, people do.
Within a year there was quite a few rattletraps running
around...............
Scary !
- Bought at a PA auction by the NY car purchasing service, so NY service took title from PA auction place
- sold car to us and we registered it in NJ (where we live)
- 2006 Land Rover LR3, apprx 12,000 miles at time of auction
Anyway, I took it to my local (New Jersey) Dept. of Motor Vehicles for inspection and it failed the emissions part. Reason was DMV system was unable to read the OBD (On-Board Diagnostic system) of the vehicle, so according to DMV the vehicle's system is not ready to determine the status of the pollution control system. Spoke to Land Rover claims that this happens because the DMV cannot read the OBD because it is an "CAN enabled system" and that I need to have the DMV give me permission to let L/Rover's state qualified emissions technician provide a written statement that the vehicle's emissions system is OK and have the DMV accept this as proof enough to get the inspection sticker. In other words, the DMV's system will continue to be unable to read the OBD on the vehicle, but DMV will give me a passing grade any way because the dealer's techician says the car is OK. Also L/Rover says this is only a problem (that he knows of) with this particular model year and model. I had the L/Rover service dept test the vehicle twice and according to them everything looks good (after recharging the battery and rerunning the vehicle through all the codes).
Do you guys have any ideas on how to handle this? I'm concerned about having a vehicle that has to get DMV clearance in this offline roundabout way, instead of the straightforward way I'm used to on previous cars. I much prefer to have the DMV plug in and be able to clear the car as usual. I'm also concerned in having to do this every year (annual inspection). How will I know that in some year in the future, the DMV won't tell me this is unacceptable and I'm stuck with a useless vehicle because it won't clear inspection.
Should I keep going with this vehicle or proceed as if it is a lemon? Please help. Thanks.
p.s. - I have also been told that sometimes the issue I'm having has to do with a battery being disconnected and that if I drive the car around for a bit (a week or so), that would give the car a chance to 're-learn' what it needs to clear all of these so-called codes. I guess I'm concerned about what to do if it fails again even after I do the drive-around. Thanks again.
Your car is not a :lemon: your states inspection equipment is.
Sounds to me like the only choice you have is to sell it. Does the dealer charge you for the letter? If not its no big deal, when you get you oil changed close to renewal time ask them to do the test. It actually sounds allot more convenient then sitting in line at a state inspection station
If so the mfr. HAS to warranty it will pass ALL Fed emission
tests for 5yrs. 100k miles???? right?
I would be at that dealer and having a talk with the
service mgr. pronto !!!!!!!!!!!!!!
But yet again its a land rover !
They are one piss poor vehicle.............
there is a Land Rover salesman that frequents these forums. He may be able to help you with this situation. You may want to post this in the Land rover Forum as well.
That or move out to the country. Something. Geez...
Interesting, how would you propose that we go about doing things? The OBDII method is the most cost efficient because it transfers a lot of the technology to the car rather than having the inspection stations (in a lot of states the gas station owners) invest in the technology.
As for European Emissions? Funny I think they are much stricter than ours IIRC, and gas there is significantly more expensive than here.
-mike
Motorsports and Tuning Host
Most cost efficient for whom?
And then there is the Prius for which it is impossible to pass the test but owners must submit their vehicles for testing anyway and PAY the fee - followed by a trip to a special referee facility - with extra charge!
SUVs and Smart Shopper
The Gas Stations who do the state inspections. If they had to invest in a 100k or 200k machine to do a $25 test, a lot would not be in business. With the OBDII method, the computer setup for it is significantly less expensive.
-mike
-mike
The CAN stuff is weird, my buddy said they essentially have all the wires in the car "hot" at all times and they send a signal to components when to turn on or off, like the radio, cig lighter, etc.
-mike
Yes, we are set up to be able to read the OBD-CAN interface> At this time I don't have an ETA on when the Private Facilities will be upgraded but we have been testing with CAN since late 2006. We are down to about
5 vehicles on our "exempt" list and even if a particular vehicle "defies" the norm.....The State will work on us to authorize by-pass testing with if necessary as long as the proper documentation is obtained.
If you are still having problems and you haven't alrady, please see an Emissions Repair Facility as discussed previously. If they perform the diagnosis, show that the vehicle will communicate in "generic" mode and that there are no other issues, I can then send that paperwork to the State and get a by-pass authorized to a lower level test.
I hope this helps to clarify and let me know if I may be of further assistance including talking with the ERF of your choice if that will help matters.
Here in my Area if you live in Nashville Davidson County or a county that touches Davidson you have to have emissions inspection once a year. The cost is $10. You can have the biggest POS on the road as long as it passes emissions.
You see a number of cars down here that have the right side of the license plate cut off. This allows the owner of a POS to transfer the expiration sticker to the POS and thus seem legal without paying or getting inspected.
a bunch of rattletraps running around with broken/cracked
windshields, bald tires, and no tail lights!!!!!!!!
Also your yearly plate renewal verification was a new
sticker with the year and it was placed in a spot on the
corner of your existing license plate.
But the crooks had a better idea ! Steal your plate and
remove your sticker or even better carry a set of metal
clippers and cut the corner with the new sticker off
your plate and peel it off at home then put it on their
own car !!!!!!!!!! :P
applied if someone tries to take it off it tears into pieces so it's no good to anyone to use. the dmv HAD A GOOD IDEA, wow who woulda thunk :shades:
