http://www.ecrostech.com/prius/original/Understanding/PowerSplitDevice.htm
http://www.ecrostech.com/prius/original/Understanding/PowerTrain.htm
http://www.ecrostech.com/prius/original/Understanding/WhatsGoingOnAsIDrive.htm
http://auto.howstuffworks.com/hybrid-car.htm
http://toyota.jp/hv/entrance.html?intohsd.toyotajp.kluger
Just because a tire has a maximum pressure rating does not mean it should be achieved. If you put the same tire on a 3500# car and a 4400# car you'll want more pressure in the heavier car to create the right surface area. Increasing the pressure on a lighter car however lessens the tire contact area and thus create a longer braking distance as well as less surface area for grip.
Granted there is some "play" in these numbers but increasing pressures 30% over design is pushing the safety and handling aspect of the tire design for good FE.
Tires are designed with a maximum pressure so that they can achieve a wide range of applications, not so you can pump them up hard on your TCH.
Also (someone mentioned the max on the Michellin was 44 psig) running at 42 cold pressure on concrete highways at high speed in hot weather will probably exceed your maximum tire pressures. If you blow a tire and wreck your car don't put it past your insurance or whoever you decide to sue to check your pressures on your other tires or for that matter your comments on this website to see if you purposely exceeded recommended pressures. (I'm not a lawyer, just spend a lot of time tring to figure them out at times)
I realize this won't change the minds of you die hards. Don't even want to. However many novices watch these forums for ideas and "buy into" just about everything they read from synthetic oil, high tire pressures and running in neutral. All these things should be (re)considered after research and study, not just as a "I wanna do it to" attitude.
Wouldn't know, never been there.
You should follow the auto manufacturers guidelines for the proper inflation of your particular make/model.
And of course, the pounds of inflation are always meant to be adjusted on tires that have not been run more than a mile or two. That will give you the proper operating pressure.
As an FYI, I have an expensive digital air gauge and checked the air pressure after driving my 2007 TCH for just over 15 miles and registered 38psi...
Wow, every morning. That's dedication. I assume you mean that the tires do not exceed 1-2psi above the recommended pressure?
I would agree that daily is a little extreme. However, if the TPMS has a 5psig (?) lower limit then I would not want to totally rely on that. That to me is just a back up for a severe pressure loss. If I set my pressure at 32 I wouldn't want to be driving around at 28. Not that it would hurt anything but FE, but I would want to keep them close to what I have determined to be optimal.
I usually check once a month and when the weather starts changing
Would the metal tire stems interfere with the TPMS?
The ICE will kick in at anytime, actually, that the onboard computer tells it to. Generally that happens when your demand for speed increases over 35/40 MPH, or even at lower speeds once you have traveled long enough to lower the stored charge in the battery, according to Toyota's computer program.
Hey, we've all been where you are, don't fret the questions.
ICE is the internal combustion engine.
Yes, the engine will always "come on" at 42 mpg (at least up to an idle). There is a technical reason for this in other posts. Something I think about keeping the (electrical) motor from overreving. Much of the time even below 42 mph your ICE will run as well. Only when you're in the E (electric) or as some refer to as the EV (electric vehicle) mode will it go completely off under 42 mph.
There are other times the ICE will be running under 42 mph:
1) like 7 seconds after start up
2) when the battery needs charged
3) when "extra" power is needed.
Actually don't expect the ICE to actually stay off a lot. As you become an "expert" you will realize it's the numerous times of infrequent ICE operations that adds up to excellent overall FE (Fuel Effeciency / Economy).
By reading the posts and tips offered by all the posters you can learn to add up these small incremental milage increase tips into a really respectable overall FE.
Most everyone that is trying is getting 36 mpg. Several over 39 mpg. Most of those in the 33 mpg range will admit they don't drive to maximize the FE. (That is they still drive 75+, don't pulse and glide, and basically drive it like they always have). While that 33mpg may not look good to all, it's probably a relatively equal improvement over their past vehicle as many people have never gotten the EPA estimates due to driving habits or unusual or difficult environmental driving conditions.
You'll also need to decide how dedicated you are to FE. Many become obsessed (at least mildly)yet some totally ignore the gages and energy screens. In other posts I have outlined $$$'s saved between 36 and 39 mpg and from a pure economical view it certainly may not be worth the effort as the savings is small (less than 10% in that case. However if you're coming out of a 16 mpg ride like many of us have and get 39.5 mpg then the savings is significant.
PS: Sorry you were not in time to get the full tax credit. It motivated me but don't sweat, I would have bought this knowing what I know now with no credit.
Just remember you have bought a Hybrid. It was not manufactured to be an EV (Electric Vehicle). It was made to use both gasoline engine and electric motors, to optimize mileage and performance.
Go to www.tundrasolutions.com and use the link to set up an new account (you can pay with a credit card). Within 24 hours, they will send you an email that confirms you have been setup. Log in to www.tundrasolutions.com and go all the way to the bottom of the page. Choose the "Knowledgebase" link in the blue bar at the bottom. Select "Reference Knowledgebase", then "Owners Manuals", then find the links to the "2007 Toyota Camry HV Owner's Manual" and "2007 Toyota Camry HV Navigation System Manual" and download each. They come in a .zip file of numerous .pdf files. Go back to the "Reference Knowledgebase" page and select "New Car Features & Pricing" and find the "2007 Toyota Camry HV New Car Features" link and download it. Same kind of zip file.
I have compiled each of these into one pdf file with bookmarks. I am willing to email you the compiled files if you can send me one specified file from each download proving you have signed up and downloaded the original files (I support intellectual rights).
Hope you find this useful.
P.S. I have averaged 40.5 mpg on my last seven tankfuls of gas. First two tanks only averaged about 38 to 39 mpg. I personnaly like the TCH better overall than any other car I have ever owned, and I have owned various and numerous cars for over 35 years.
JUST CLICK HERE
Also just for the record, if anyone wonders, I keep all 4 tires at 35.5PSI cold (recommended is 32psi).
For me, the fact is, the 2007 Toyota Camry Hybrid is a truly amazing vehicle
I'll keep on enjoying my 1-2 MPG "overinflation bump" and watching my tires wear perfectly normally. :shades:
No one is talking about "wear" but about catastrophic tire failure.
Like I said, those of you doing that, will never be convinced by scientific or legal fact, and will continue to do so up until you actually cause injury to your loved ones, or are denied coverage by your insurance company. Or both. I have read literally thousands of such cases.
I hardly think your savings of one or two miles per gallon (What is that anyway? 10 Cents?)is worth the risk of someone I love being severely injured, or being exposed to millions in liability, when insurance company refuses to pay. But thats just me.
Where, exactly, have you read about "thousands of cases" in which tires inflated to Max PSI causing deaths and/or insurance coverage being denied? I'd like to see that data.
I am not going to be baited into another long-drawn out so-called "discussion" about something so widely reported in the news media over the past twenty years. It has been the subject of several "news magazine" show reports on TV, and widely covered in the auto- trade magazines. During the big Firestone/SUV deal, it was drummed constantly what a danger it was, at least weekly, for over a year.
If someone "claims" not to know of the dangers of disregarding the auto manufacturers safety guidelines, they must live in a cave somewhere, or be in denial....
So, as a TCH owner and a previous HCH owner, here's a tip: Do research yourself before adjusting your tire PSI. Don't listen to me telling you not to worry about overinflation and don't listen to those who say overinflation is nothing short of a crime. Do your own research.
Anyway, moving on...... :shades:
Anyone reading what I posted, not trying to argue, would realize I was saying it was brought up in addition to the manufacturing defects involved in that case. It was argued in many instances, and proven so, that some of the failures were do to over-inflation.
Please stop trying to end discussion and just argue and nit pick. It is not productive to these forums, and drives people off.
Please show all of us something from a tire or automobile manufacturer that says it is okay, that it is safe, to exceed the automobile manufacturers recommended inflation.
Back to TCH driving tips:
I frequently use 34 MPH as a "sweet spot" to get good MPG when the engine is still cold.
I've moved the posts that spun off into tires and used them and the starter for the Toyota Camry Hybrid Tire/Wheel Questions discussion.
Please remember what the topics are supposed to be about when things start to wander. Thanks!
I suggest ignoring it.
I'm still not sure the "B" mode works as well (if at all) at charging the battery as compared to using the brake petal. I've not seen a definitive explaination on that.
I'm not sure how you can assume it's saving on your brakes? My understanding is that using the brakes at any speed over 12 mph, except in emergency stopping, is using the torque on the motor to charge the batteries and NOT using your hydraulic brakes. Under 12 mph, I doubt that B would help much anyway and you'd have to start using your pedal to stop.
Also, I have found that reasonably moderate acceleration is better than hard acceleration that some advocate. At approximately 35, 45, and 55 mph, I can let off slightly on the gas pedal and get the transmission to slip into a lower ratio and see the effect by an increase of 5 to 10 mpg on the analog comsumption gauge. If I then press down slightly on the accelerator, mph drops some, but is still well above original. Daytime temp is now averaging about 60 here and I am back up to about 40 - 42 mpg average for a tank full of gas.
I think you're simply seeing the engine going to idle, not the transmission going to a different "ratio". The "transmission" or power splitting device in the TCH works similar to a CVT transmission.
I'm guessing with some of the new 7 speed auto-tranny's you will eventually get to where they will shift so smoothly that they will almost seem like a CVT .
Sorry, but I disagree. A CVT transmission still has a varying ratio from power in to power out. The power split device just controls that ratio.
I also said that I reapply acceleration to get back to about the same accelaration rate as before but the indicated mpg is higher. I have been testing this the middle of last summer and have seen an apparent increase using this method. My current tank average is 42.8 mpg and it's not even that warm yet.
Like you seem to be, I am very tech oriented. I have read the manuals, including the Body Electrical and related info from Toyota. I understand how this system is supposed to work.
My bad, that's not the way I understood the PSD. Most CVT's (I think) have bands or chains that in effect do change the ratios without actually "shifting"ike a conventional transmission. However the PSD is not a CVT transmission. My understanding of the PSD did not include any information showing that there is a change of "ratios" possible.
I'm not automotive "techie" so I struggle to totally understand all this.
http://www.hybridsynergydrive.com/en/power_split_device.html
This site shows the schematic of the PSD (as well as other techie stuff) and it simply appeared to me that you have a sun and planatary gear connected by the pinion gears. It doesn't show any ratios other than 1. Perhaps this was simply an oversimplified explaination
