Pontiac Grand Prix Engine fires 3800 series II 1996-2003
                    Hi everyone, my 2002 grand prix had an engine compartment fire on March 11, 2006 and after much research by searching the web it become clear that the fire was caused the defective MOP intake manifold. I am looking for others that have had this experience with there GM 3800 series II engine made from 1996 to 2003. If you know anyone with same experience of an engine compartment fire in with there 3800 series II engine would you please respond.
1
We contacted the GM dealer and he said he didn't think that was a great idea and thought GM was crazy.
I then contacted our attorney and he advised to contact GM again and inform them we would contact Better Business Bureau and if need be go the legal route. GM called back 3 days later and said they would send an investigator. After a month they let us know the investigator couldn't determine the cause of the fire.... geeeee really??? And, there was nothing more they could do. We are now proceeding with the BBB and if need be the legal route. Cars just don't burn up... this was a well maintained vehicle and thank goodness no one was injured.
What is it going to take before they acknowledge they have a problem? Hopefully nothing as serious as personal injury. GM needs to step up to the plate
Their investigator could not determine the cause due to the severe burning. Surely, they have to have some culpability in this......................
I think you should expand this link to GM 3800 engine fires. The 3800 Engine is used in seveal GM models. Expanding this forum would link the this engine to all GM makes that use it. The Engine is used in Chevy's, Buicks, and Pontiacs. I have a 3800 Series II in my Pontiac Grand Prix GTP. Let's open this up to get a better cross section and true picture of this issue.
Thanks, -Heather
My 1999 Grand Prix GTP did not make any engine noises or smoke prior to catching fire, it was running perfectly when I parked it on my mother's carport. Within 10 minutes, the car burst into flames, thank God the fire department was close by and her home did not burn. The car was a total loss, this seems to be the pattern with everyone else that has had engine fires. I am no car expert, but if I were you, I wouldn't park the car anywhere it could cause damage to anyone else's property. Have you had the oil checked? It sounds as if the engine is about to blow and you definitely have a leak, probably the water pump is going bad or gone, they make strange noises.
Grand Prix for engine fires...
On Valentines Day, I went to go out to get food at a store that was about a half mile away. I got back, shut the car off and went into the house. It seemed about only 20 minutes and I heard a noise, looked out and saw flames shooting out from under the hood. My car also ran like a top and went like a raped ape.
Unfortunately, I didn't have insurance on my car, I bought it cash and didn't require it because their was no lien holder. It never got to the inside but totally wiped out the front end and did melt part of the windshield and dash.
Not that I am glad but at least I know I am not alone. I usually do my research pretty good before buying and this was new to me. This has been my dream car since they came out with the GTP. My first car was a 68 Grand Prix. The car I had before this one was a 94 Grand Prix 3.1 and I never had a lick of trouble with it and it had over 300 K when it was traded.
Now, has anyone had any luck on pursuing this obvious defect? If so, who do I notify. Both my Wife and I are disabled and on disability and that was our only transportation. I bought my baby with part of my disabilty check because I knew it was going to be my last car and I wanted it to be my dream car. :sick:
This issue is also being discussed at http://www.autoblog.com/2007/02/05/nhtsa-investigating-pontiac-grand-prix-engine- -fires/#comments
Here is a link to the recent NHTSA posting:
http://tinyurl.com/3cljhx
http://www-odi.nhtsa.dot.gov/cars/problems/defect/results.cfm
In the search window use "PE07006" to pull up the open report...
The one that is still open can be found at: http://tinyurl.com/3cljhx
