Toyota Matrix Interior/Passenger Comfort Problems
Seat replacement
After coming from a car with very hard seats I thought the softer seats of the Matrix would be a welcomed change. Instead I find them to be too soft and lacking sufficient lumbar support for my taste.
I tried inserting air-bladders for lumbar support but the seat remains too soft. After-market seats would do the trick but I am concerned about electronics around the built-in seat airbags.
I understand the after-market seats will *not* offer airbags in the seats and I'm fine with that. What I want to know is what (if any) problems should I expect if I replace the stock seats. For example: Will the electronics complain that they no longer sense/have a connection to the seat airbags? Will other airbags in the system fail to deploy by removing the stock seats from its signal loop?
Seems a shame to sell the car just because I am not a fan of the seats.
:confuse: :confuse:
Just a cautionary note.
The dealer was unconcerned and would not give me a “Due Bill” for this problem and insisted that Toyota warranty would cover this. The car on the lot was the one I wanted. I was ready to buy right then as we had agreed on the price. Instead I wasted 3 hours of my time.
Has anyone inspected the driver seat cloth upholstery for this problem? What opinions about the cloth used in the Matrix seats are out there?
But the other thing the dealer said is correct. It should be covered under warranty -- but I suppose only if someone acknowledges that it isn't normal. I bought a Renault Medallion in 1987 that had a bubble on the vinyl on the front passenger seat. (Where you sat was fabric, but the sides of the seats were vinyl.) The dealer replaced the seat cover right away under warranty. Didn't try to tell me it was normal, though.
The seat edge is apparently not padded enough, or too high, or something. I'm going to try a pillow and I'm taking it back to the dealer to see what they can do.
I've had both a Corolla and a Tercel (and a Subaru Impreza) previously and have never had such a thing as this - it's like a hard metal rod pressing on the tendons in the back of my knee. Horribly painful!
What happened with you and your wife when you experienced the same problem???
If I remember, he told me that he had to adjust his seat by lowering the front or raising the back and now no more pain in his right leg.
The secret is to adjust your seat for your leg to be in a comfortable position..
Thanks so much for the helpful suggestion. If this fails, I've already called the dealer about the seat and asked for help. The car will be spending some time at the dealer's next week for the two recall fixes--both the gas pedal and the floor mats. Hopefully if I haven't been able to fix the seat by then, they can.
Thanks much.
Wondered if anyone has a solution or source for a replacement folddown front passenger seat?
Thank you,
Dan
Thank you, Dan
