Maybe and maybe not.
We have plenty of spring at least in front now unless you are mahout.
He cuts one coil which not only lowers his by 5/8 to 3/4 of an inch but
increases the spring rate making the ride feel stiffer I would think.
It gave him what he wanted for the rode course which is fine for him.
But I don't want to lower my front end even that small amount.
It drags my driveway now as it is unless I go into it very slowly.
I don't want to rode race as he does, nor do I want mine to ride any stiffer than it does now.
I simply want it to stop popusing, and nothing is needed to do that but a
good set of replacement shocks that are well made and will last.
That lets MANDO out as many of us can attest to who have had
the originals plus the TSB replacements fail. :lemon:
I see no need to spend thousands of dollars for coilovers when it is not necessary.
If Bilstein would make aftermarket shocks for the Azera, a pair would probably be less than
$300, and Bilsteins will last for 180K to 200K miles according to my alighment man.
I tried a set for the rears that were supposed to fit according to mahout but they did not fit!
To short by several inches and the bottom hole was not big enough either.
But I did have both the original rear Mando shocks and the new Bilsteins ($150 only for the pair!)
in my hands for a comparison. Nothing wrong with the original rear shocks on my car yet,
but we were told and I agree that more control back there is needed.
I wish you all could see the differences in the build quality of the original Mandos and the Bilsteins.
There simply is no comparison in any way. I gladly would have paid several hundred dollars
more for the car when it was new if it had Bilsteins instead of the junk that it has now!
To put it simply, only good quality replacemets shock are necessary, and nothing more.
The only reason I put the coilover out there as a suggestion is that there seems to be no other offerings for replacement options. So...it would seem that a bunch of Azera owners need to start contacting these aftermarket companies and press them into making parts available. I know it's tough, it took a year for me to be able to get ceramic pads for the front brakes. Which by the way, if anyone is interested...Rockauto.com sells Akebono ceramic pads for under $60/pr.
Mike,
I have either called or written to just about every aftermarket shock manufacturer you can think of,
and not a one save Monroe has indicated any interest in producing shocks for our Azeras. :sick:
Why do you need Akebono brake pads over the original stock Hyundai pads? :confuse:
Did you get them only because your originals were worn out, and are they as clean as the originals?
I have never had any car with dics that left no dust or residue as the original Hyundai pads.
I kept the orginal pads until I wore them out, then I replaced them with another set of Hyundai pads (since none were available at that time) and this last time, I found the ceramic pads available. The Akebono pads are MUCH cleaner than the Hyundai pads. I installed them 2 weeks ago and my wheels are still silver with no brake dust on them, if anything...road grime shows up before brake dust.
Well I have, but I know of only one other person that has done that also.
Those pads must really be something to be cleaner than the originals.
I have never had to clean my wheels and sometime go several months between regular car washes.
My wheels simply do not ever get dirty, unlike some other cars (MBZs) I've had in the past!
I am very easy on brakes. :surprise:
Well...of course it depends on how heavy you are on the brakes. I ran through the front pads after about 32K miles. They dusted up, but not terribly bad. I had ordered some Monroe pads initially that were supposed to be ceramic. I put them on and my wheels were charcoal in color within 4 days. There was no way they were ceramic...I sent them back and got the Akebono pads. I still drive as I do and haven't washed the car since I installed the pads 2 weeks ago...no visible dusting as of yet.
Eventually, I plan on switching the rotors to the cross drilled rotors as those will help the pads cool off even quicker. With the rotor upgrade, I'll change the calipers to the dual piston version.
Did you get your OEM shocks given back to you? If so, could you SEND them to Bilstein, Koni or KYB and ask them if they make anything for some other car that matches their physical specifications?
I don't know how good the customer service is at these companies, but it seems worth taking a flyer.
A good idea Tony, but . . .
I tried to get the stupid mechanic that did my TSB to save my old ones.
He promised me that if Hyundai did not want them back, he would
watch them and if they were not sent back, I could have them.
Well he couldn't be bothered, and I think they were simply thrown out!
I don't think that anyone makes a front shock with anywheres near the physical specs. :surprise:
The rears are very close, but not exactly right.
The Bilsteins I ordered were supposed to fit but did not. About four inches to short, and
the bottom hole diameter was not large enough. Cost me shipping both ways.
Your tale reminds me of what I think is the worst story I've ever heard about having your old parts handed back to you, told to me years ago by a female co-worker. She had zero mechanical knowledge and she knew it, but she tried to be a dutiful consumer by asking the mechanic to hand her the discarded part. He disdainfully reached down and handed her what she realized later, and what you and I would know instantly, was a completely dissimilar part from an entirely separate portion of the car.
Good service is indeed hard to find. When I find a good independent mechanic, I treasure him.
Nor does Genesis have Azeras power folding outside mirrors.
The Genesis has shocks made by Sachs, not that junk from Mando like the Azeras use! :lemon:
It is my understanding that the suspensions between the two vehicles are entirely different. ( I hope so!)
I didn't know there was a problem to fix with the Genesis suspension! :surprise:
I'm joking, I know what you mean. The suspension is truly and signficantly better than that of the Azera. I have an '06 with the shocks that don't fall into the TSB for replacement (so I haven't had the problems most have). My suspension is fine (no wallowing and no clunks). When I tested the Genesis 3.8 w/Premium Plus (18" wheels) I made it a point to drive over pot holes, man hole covers and other uneven parts of road to see how the suspension would respond. Very, very compliant and solid...especially compared to that of my Azera. Now that being said...if I feel it's that much better than the suspension on MY Azera, I can only imagine how much better it would be for those that do have Azeras with the suspension problems.
Given the price difference you would think the Azera "upgrade" would offer those 2 feature too.
Hyundai didn't get it 100% right, but they weren't too far off in my opinion.
However, I wish the power pedals positions could be remembered by the memory seat option. It just surprises me that Hyundai didn't integrate this with memory seat function. So, my wife & I have a common position for the pedals we both are comfortable & we don't change pedal position. So, for us, power pedal isn't an advantage at all.
Regardless, as most have posted, the Azera does fine on interstate type highways. It is when you get off on back roads that the problems surface, especially county roads. Try US 176 or 276 in the Columbia area and if you don't see the problem, considere yourself very, very fortunate.
I work at the U S Dept. of Justice's executive offices...
I did it with no police escort (actually...135 mph)!
http://townhall-talk.edmunds.com/direct/view/.f1037a2/25!keywords=allin%3Amsgtex- t%20limit%3A.f0aaebf%20security#25
Snaglepus said you lowered your azera by 5/8 inch on the front by cutting the coil..
where you able to still get correct camber and castor?
Also did you lower the back?
Allmet said he lowered his with H & R springs apprx.1.4 to 1.5 inches..is this too much , do you think? ie cause bottoming?
Why do I want to lower...lower centre gravity..reduce lean on corners and improve
look...so close the fender gap
ISomeone said one could change springs for coilovers ??
Appreciated your thoughts on the susbject of lowering
Thanks in advance
alymac
Alymac...I did NOT lower my Azera yet (I'm planning on it though). I originally posted some links to show you a couple of guys that have lowered their Azeras though. The pics are on cardomain.com. If you do a search by model, look up Azera and you'll see 2 maybe 3 that have lowered their suspensions.
I don't think you have to worry about bottoming out if you lower it using the kit. The aftermarket kit comes with the coil over shocks and much stiffer springs that stock. Personally, this is something I the the car's OEM springs should be...stiffer. I think it's possible to have them a bit stiffer and not be a hard ride.
Coil overs are replacements for shocks, not the springs. The springs can be replaced as well.
Where are those links now? What happened to those links? I cannot find them!
Elninorudo's CarDomain page Used coilovers
OpirusXG's CarDomain page Used lowering springs
Martianiv's CarDomain page Used lowering springs
Thanks Mike.
Thanks for your reply.. think I need a little education on coilovers.. you wrote that coilovers replace shocks not springs..I thought that coilovers replace the
springs on a car.c ould you mind clarifying this for me..obviously I dont understand
the subject.
Also you mentioned an aftermarket kit.......who makes it and what does it consist of?
Sorry I sound so dense on this subject but.. heh.. theres only one way to learn
Appreciate your reply
Alymac
Azera Coilover Set
Here is what the lower springs look like, nothing but a set of springs that you replace the OEM springs with. They are shorter and much firmer, but still rely on the OEM shocks. Personally, I think the aftermarket springs by themselves would improve the ride of the car, but I really don't know because I haven't done it and I haven't spoken to anyone that has.
Azera Lowering Spring Set
The guy that used the coilover kit said that replacing that has significantly improved the handling of his Azera. He said in turns the car tracks like it's on rails.
"Here is what the lower springs look like, nothing but a set of springs that you replace the OEM springs with. They are shorter and much firmer, but still rely on the OEM shocks.
it and I haven't spoken to anyone that has."
You are wrong Mike. All four shocks are replaced. Two in the front and two more in the rear.
Look closely at the picture. In fact Zoom in.
What are those two cylindrical objects laying flat on the table?
Those are the rear shocks. :surprise:
You had better get all four springs and four shocks for 12 bills.
Snags...what are you talking about??? If you look at how I did the posting...I put a short narrative in FRONT of the link showing what it was. I know the coilover set is replacing all 4 shocks. Duh...that's exactly what the picture shows. My post started by saying that most coilovers are adjustable... I didn't say much more because I've never dealt with them, but I NEVER said anything about only replacing 2. :confuse: Then I put in a link to show what the coilover set looks like.
Then went on to mention the lowering springs...and posted a link to show what the lowering spring kit looks like.
I ended it by saying I spoke to the guy (via email) that went with the coilover kit and he says his handling improved dramatically.
Sorry old-timer, time to take a trip to the optometrist and get an upgraded prescription.
Here's what I read from your earlier post:
"They are shorter and much firmer, but still rely on the OEM shocks."
Now what are you saying? "still rely on the OEM shocks" to me
or anyone else means using the original or OEM shocks.
Just because I have few wise years on you in no reason for you to try and insult me.
I know what you posted; It is right there for anyone including yourself to see.
At seventy two years young, I have 20/25 vision and do not have nor wear corrective lens at any time, and my vision is perfect thank you.
Chill out as you young people like to say.
Now...you're right, your vision is good, you are correct in what you read, however...wrong in it's context. Again...I put the narrative in FRONT of the link showing what each is (narrative/link...narrative/link). What I stated about the lowering springs being shorter and stiffer than OEM... PRECEDES the link for lowering springs. I think if you go back and look at my post...you'll see that. In which case, I am correct...the lowering springs are shorter and stiffer and rely on the OEM shocks (because the springs are all that are being replaced). That statement was NOT said in reference to the coilovers.
If you notice, my explanation of the coilovers is very brief as I don't have any experience with them at all.
As you said, it's right there for everyone to see.
sideview mirrors. I have the clear bra protection but it still took a while to scrub them off. Definitely now going to pursue getting the struts replaced with the latest part.
Got 27 Miles per gallon . Very quiet and I still hear no noise at 15,000 miles with the Michelin all weather tires.
