Do you currently own a 2019 or newer RAM pickup? A reporter would like to speak with you. Please reach out to [email protected] by 1/27 for more info.
'01 Pathfinder - weird whistling engine sound
I own a '01 Pathfinder which I bought used around 2 years ago. So far I am very happy with it except that while I am driving it any where between 40mph to 50mph, I hear weired hollow whistling sound. This happens only when I have applied pressure on the gas paddle. This sound remains there till the truck is accelerated to 50mph...After that, the same thing happens again from 70mph to 80mph.
Has anyone experienced such a thing before? Any suggestions as what should I be looking for in order to troubleshoot this thing.
Btw, it is an LE 4x4 version of '01 pathfinder.
-Rafay
-Rafay
Otherwise, it sounds like the intake. Check the air filter (sealing ok). The intake hoses will whistle if the clamps aren't tight. Also the PCV valve, though they usually rattle.
Note that right after you shut it off, the carbon canister vent will moan or whistle, until the system has vented.
Just to elaborate more on the issue, this weired sound is only there if i have applied some constant or increasing pressure on gas paddle while the suv is moving anywhere from 40-50mph or 70-80mph. There is no sound if i let go the gas paddle at these speeds.
I just bought a used pathfinder 20001 se, with 60k miles on it. Nearly Everything works fine, as it is still under extended warranty.
There is one thing which is driving me crazy. If I am driving at low speed at 40 mph and let go of accelerator, then if I slightly tap the accelerator instead of pressing it down hard as I just want to increase the speed slightly, it makes at lound whirring noise at 1500 rpm and 45-50 mph. If I keep the accelerator pressed hard, then it does not happen as it shifts from 2-3-4.
When it is whirring, I think the response goes down also.
I am thinking it is a timing belt or transmission issue.
Before I got the car, the dealer had installed a new transfer case, harness wiring.
Any help on this would be appreciated as do not trust the dealer to much to really take an effort to replicate the problem in the workshop.
Khurram
Any help! It's deafening at 45 mph!
