Who plans on keeping their Corolla for 200K+ miles?
I have a '99 Corolla which I put 2500-3000 miles on per month. Since the vast majority of miles this car sees is on the highway, I can easily see it lasting AT LEAST 200K miles. How many of you are looking to drive your Corolla this long and what type of preventive maintenance do you do/have done to reach this milestone?
So far, I've only done the standard preventive and scheduled maintenance (oil changes twice a year, the standard service every 30K, one set of new brakes - the front discs finally gave in a month ago at about 95K miles!, new tires when needed). I'm still on the original muffler, radiator and every other major part.
I may look to buy a replacement next year, but it'll be really hard to give up such a reliable ride that gets decent (30 mpg in 60/40 city/highway driving) mileage and, more importantly, has been paid off for a long time. Safety is a bit of a concern, though, as I've got two infants now and it is a base model - no ABS, side airbags, or any of the other safety features that are now common in most cars (we do have a Highlander that is the primary kiddie hauler though). However, I am of the belief that most competent drivers will never get in an accident where these items come into play and believe strongly that 75% of accidents are avoidable, so safety isn't necessarily a dealbreaker for me (unless the car gets unacceptable/poor ratings all around).
I do not use synthetic. I just say yes to whatever the cheapest stuff is that Jiffy Lube has handy (or the dealership for the major service intervals).
1.6 liter, 3 speed automatic tranny (which is why I only get 30 mpg combined instead of 35 - though the EPA rates it in the mid 20s, so I'm not complaining)
We had 232,000 miles on it and it was still going strong. No major repairs other than having to replace the original catalytic converter this coming November to pass smog check (we live in California so it's required). Guess I won't have to do that after all. Anyway, I never had any complaints about the car. It was a champion workhorse the entire seven years I owned it. If I wasn't expecting our first baby in a few months, we would probaby just get another one, but since we'll need more room, it's on to a RAV4 or highlander now!
Since you mentioned getting a Rav4 or a Highlander, I've got to give you the speal. If you need something with more room, get the Sienna instead. It's roomier than either SUV and it gets better fuel economy too. You won't be sorry.
* Engine oil and filter changes every 3 to 5K miles.
(don't use cheap oil like from Target etc)
* Automatic Tranny fluid should be drained and replenished
at least every two years or every year.
* Belts and hoses should be inspected and replaced when
needed.
* Drain and refill you're radiator at least every two years,
(every year even better)
* If you're battery is three years and older, keep an eye
on it. You can go to Sears battery express drive through,
and get a free battery test.
* Keep you're tires at the proper inflation and check at
least once a month, and rotate tires.
If you want to try and get 200K out of the car, you might
consider changing the oil more often then twice a year.
Whichever brand of motor oil you use, stick with it.
It sounds like you've done a good job insuring the maintenance is taken care of. Of course as you're car continues to pile on miles, the odds of repairs coming up increase, but thats expected within reason. I really agree with you that being a competent driver goes a long way in safety. One could drive a car loaded with safety features, but if the person is talking on their cell phone while driving or doing other stupid unsafe things, it offsets all the safety the car provides. Good luck.
Though I have a manual tranny, I plan to change its oil once a year.
The coolant in my Corolla is the 100K mile stuff, so I will change it at 100K (which is coming up in about 13K miles).
I check my tire pressure weekly and rotate every 5K miles.
I inspect the belts and hoses each oil change.
H E double toothpicks right I am going to keep Lucy II (2006 LE) for 200K. It'll be the first car of my unborn child, I tell you what. My 2 year old son is already getting the well off-roaded and cared-for 2001 Yellow Nissan Xterra.
1988 Toyota Corolla SR5
Total miles: 201K miles
Original CV Boot (no cracking or anything)
Mobile 1 5W30 Syn every 7.5K with Wal Mart brand filter; recently changed to Wal Mart brand syn. @ $12.99 per 5 quarts, I can't complain.
Replce ATF at every 20K.
Replace timing belt twice; 1st one at 70K; 2nd one at 155K with water pump, idler pulley and all the front oil seals.
Replaced muffler 2 times.
Replaced all struts at 135K.
All original hoses. They still look good.
Replaced Alternator at 185K.
Replace Starter motor one time.
Replace rubber boots on rack-and-pinion steering.
Brake pads. Average life is about 60K.
This is all the major things that the car has been worked on, and I did all the repairs except the timing belt replacement.
The car is solid like a rock and keep going strong. Plan to keep the car for another 50K.
I am getting about 33 mpg on 80/20 highway/city driving.
My coworker's 94 Corolla has 235K. He is using synthetic oil, but does not stick to one particular brand.
Cheers
Alland
Alland
My '95 Corolla DX has 145k miles on it. It has been running strong for the 10 years that I have owned it. I have maintainted it pretty well. About a month ago, I decided that it was maintenance time again. I took it to a mechanic that has done pretty much all the work on my care since I bought it. A complete tune-up was done: new wires, dist cap, sprak plugs, along with replacement of all belts including timing. Water pump was replaced as well. Needless to say, this was costly, but I plan to keep the car at least until it hits 200k. Three issues arose after this work was done.
1. The car does not run as good as it ran before the service. It idles harder then before and sometime struggles to shift into over-drive at top speeds.
2. I found an oil stain on my garage floor a few days after the service was done. My car NEVER leaked anything until this moment.
I took the car back to my mechanic who checked everything over and found no issues. He showed me the undercarriage of the car and it was completely dry. All oil levels were ok. I took the car back, and a few days later found another puddle, this time on my driveway where I was warming up my car. I checked all levels and everything looked ok. At this point, I'm extremely frustrated because it appears that all this time and money has made my car's mechnical condition turn for the worst.
Now some cars use a metal chain to turn that crankshaft, while others use a rubber belt. Needless to say, rubber belts wear after a while and need to be changed, typically after 90-100K miles. Chains are more durable and do not routinely require replacement, although as engines get old (usually beyond the 150K-mile point) chains can become stretched and loose and need replacement also.
It is much less likely for a chain to break in normal use than for a belt, which is one of the advantages of having a chain.
So for all you high-mileage folks out there in Corollaland, how many of you have a manual transmission, and what kind of mileage have you been getting out of your clutches before they required replacement? I am playing with the idea of getting a new Corolla, which would be my first in a decade, and I am wondering if they still have the longevity of the old-school ones from the 80s and early 90s.
Have a '99 LE with 92,000 miles, original clutch, 50% highway, 50% city. It is still good, but I expect to have to replace it before 140,000 because of my wife.
First, she hates stick shifts, and second, she isn't the most gifted as far as coordination goes. Even though I carefully taught her on a different car long ago and have practiced since, she still has clutch issues! She only has put on about 2,000 miles of the 92,000 miles currently on it, but twice while I was in the car with her driving, she burned the clutch. Another time, while she was by herself, she told me the "clutch smelled a little" because she got stopped on a hill and "got too nervous." Oh, well, we all have our good points and our bad points.
Considering all that it has been through, I'd be happy to get 120,000 miles on this clutch!
do an alignment and tires. Hit over 240,000 with my son
hurting for reliable car so gave it to him.
He takes out some "card" under the dashboard and a red light
goes on and the car won't start. Now he can't find the
card. Somebody told him if he took it out nobody could steal
the car.
I never noticed this or the light, maybe it was covered with
little metal box? Is this part of some security system?
I can't find anything in manual. And we can't start the car.
Lights go on, radio etc but won't start up. Help! magi :confuse:
