Leaving for Phoenix Friday to pickup my 2006 HH from a non-Toyota dealership and will be paying Toyota for an inspection before forking over $$$ to seller. Am looking for all items of concern at which I can aim the mechanics. Thanks. Chuck
gl
chris
p.s. oh, dont spill a bottle of water under the drivers seat, it plays havoc with the gps system which is stored under there:>
Waste of money. I can't imagine even wanting a hybrid if you were planning to push it to it's limit. Even then you probably only want maximum acceleration occasionally for a short burst. The V6 has been more than I need and I usually drive with the econ button on anyway. I'm not familiar with high altitudes and that might be a help (or hurt)
will report back
chris
For those who have had their battery replaced by Toyota, do you know if the TSB was also accomplished?
Anyone sufferring any adverse problems after changing the battery, or for that matter after the battery has been disconnected without performing the TSB?
chris
conclusion..im using the regular unleaded...
chris
p.s. btw: no noticeable increase in power either in the hh.
The ICE will normally run until there are four blue bars before shutting off.
It is normal for the battery to run down to two pink bars when we have AC blasting and music playing while parked.
Just relax and know that your vehicle is saving gas while draining the battery. The ICE will indeed kick back on and power up the battery when it needs to (assuming you are not sitting there in neutral)
chris
You could also disconnect the negative battery cable and then connect an ammeter in series to see if you have a current draw, but then you would be in the position of having to reset your idle solenoid.
Although I have not experienced this battery failure on my 07 with 102,000 miles, I do carry one of those battery jump boxes in the back. Just in case.
Take a look at the Nov. 2009 issue of Consumer Reports, pp. 52-55.
Possibly the Interstate MTP-24.
So, my problem is not the switch, as it can control the Center and Rear Interior lights, and it is not the door sensors/switches because opening and closing each door can control the Center and Rear Lights just fine. It's just the stupid Front Interior lights. I've taken out the bulbs so that my battery doesn't drain, but I still need to solve the problem. Anyone have any insights?
chris
it is usually the smallll battery in the engine compartment, especially if it hasnt been replaced yet.....
good luck, I have the 2006 toyota and it is my dream car. I love driving again and that hasnt happened since I owned Mustangs...
Now we're terrified to drive this car out of town for fear of another failure. We're leaning towards trading it in on another non-hybrid Highlander. I'm wondering if anyone else has experienced anything similar? If so what was your final outcome?
Eric
When I was safe the officer came to ask what happened. I explained and joked "It is a Toyota" I also called the dealer ship and while I was getting the DPS to see if they knew how to start and move the care and the repair man said the CSV has to do with traction and What do I expect him to do. He hung up.
I called AAA and they had a hard time getting to me and had to send two tow trucks and the second was complaining about how dangerous the location was. I had the car taken to the Bell Road Toyota and they were able to get the car in. The called me at noon because I went home to relax had missed work, and the repair was said to be a faulty battery and it was under warranty. I have a extended warranty to 184,000 miles and the care has been in for every service and I have paid for the Toyota warranty because I had hear their were battery issues.
The service person Steve called me back at 4:00 and said the care was still not starting and the warranty does not pay for diagnostics.
he called back at 4:30 and said he had bad news the inverte was out and the cost would be $7900. He said the extended warranted would not cover this part of the electrical. I called and they said it is not in the contract and I should have read that the electrical did not cover Hybrid inverters although the electrical is in the policy. I have been reading the complaints and I am so mad at the service. I owe more then the car is worth and now to add to the situation it is not safe and if they fix it it is only warranted for one year. The service person said he understands the issue and he will try and help he said. I did call the Toyota hotline and made a complaint and have a confirmation number. I have the numbers to NHSTA and want to get the President of Toyota. I am going to call the news paper and a local station. The community needs to know I could have been killed or killed someone today without any warning. The care stopped with no warning at speeds of 65 and this could have been a huge disaster for so many. I have lost my faith in Toyota. I have had other issues but it was not a life or death situation. This was and they act as if this is no big deal. Take this company and any other company down with this safety issue. I was also told that the dealership did not have anything on the brake recall and it would be a year. I have not had a brake job and the service person said he has not replaced brakes on the hybrid, "they just don't wear out".
I just installed my fourth 12V battery in four years into my 2007 Highlander Hybrid. Based on what I've read on various hybrid car forums this problems is pretty common for the 2007 HH if it's left parked for more than a week at a time on a regular basis. Lots of other Highlander and Lexus RX hybrid owners report similar experiences to mine (multiple new batteries and no fix from the dealer).
I've done a bunch of research into lead-acid batteries, 12V alternators/voltage regulators, non-hybrid charging circuits, the Toyota hybrid patents, lead-acid charging profiles. And based on this research, I have a theory about the root cause of the frequent 12V battery failures. I strongly suspect that the charging voltage on some Toyota hybrid models is too low to maintain the 12V in a healthy state under all conditions.
To prove or disprove this theory I need some data. So please do the following for me:
1. start your engine (READY on the dash display).
2. measure the DC voltage across the 12V battery's terminals.
3. optional: if you have a oscilloscope, measure the ripple voltage and look for switching transients.
4. pls post a response to this thread with the following info:
year, model (HH, Prius, RX400h, etc), air temp, DC voltage, [ripple voltage]
for example, my report is this:
2007, Highlander Hybrid, 55F, 13.9V
2007, Highlander Hybrid, 75F, 13.9V
based on these two data points I'm guessing that the charging circuit in my 2007 HH is incorrectly (or badly) designed. It seems to put out a very well regulated, constant 14V regardless of the state of charge of the 12V battery, or its temperature, or even whether the gas engine is running (or the engine RPM). A charger that puts out a constant 14V is worthless if you want a lead-acid battery to reach its full design lifetime.
I thought the reason my car stopped working, from one of the other discussion forums, that it was the inverter problem. Unfortunately, with my car the engine has fallen apart. Toyota does not know the cause, but parts of the engine got loose and damaged other things. HOW could that happen? I have a 2006 with 87,000 miles. Toyota does not know what happened. Of course, though, they expect me to pay for part of the repairs since it is over warranty (60.000 miles) and I did not have an extended warranty. Right now, we are looking at a new short block.
I filed a complaint with NHTSA and called Toyota national customer care. I am not letting this go; they need to fix it and people need to know of this potential engine problem.
Upon reading the additional information on this recall, Toyota suggestions you not tow anything until the problem is fixed. Mind you, this is just the "preliminary" notice; the "second" letter will not come out until January 2012.
So, we're not suppose to tow for the next how many months? I have 3-4 horse shows just this summer, one this week, and now I'm not suppose to use my hybrid??
I called my dealer—they can't help me. I called Toyota Customer service—they listen and said they can't help and pointed me back to the dealer. Said to try and get the dealer to do the repair now since I have a Gold extended warranty. The dealers don't even have the part yet. What a mess.
We can't be the only ones with this issue. I bought this car for towing as I didn't want to purchase a truck. My trailer is a European design and will never put more than 165lbs on the tongue fully loaded.
We've owned Toyota's since 1984; one for 19 years. I'm beginning to wonder about my loyalty to this company.
Tnx,
Very concerned
Question for you though, put your foot hard on the brake and hold it down, then turn the key to start the car, keep holding your foot down hard for lets say one minute , just sitting there....what if any noise does the abs pump make? When the weather is cold, 30ish, mine makes a strange noise, took it to the dealer and made it happen again, found another 06 on the lot and it did it also, we all surmised it was an 06 thing.... :shades:
