Visitor Agreement.
OK, now I'm REALLY intrigued: what's all this talk about a cooler for the AT??? I tend to drive fast and moderately hard, so I'd like to know more. And please, let's talk price!
-Frank P.
I called my dealership and the service writer told me that I would have to replace the entire mirror. I really don't want to just hand over $150 plus the material cost for this thing if I don't have to. Any ideas?
http://www.car-part.com/cgi-bin/search.cgi
Or try contacting Russ at Liberty Subaru in Oradell (by Paramus)NJ if you want a new one. Just send him a note requesting a price quote at the following link:
http://www.newsubaru.com/LIBERTY/Liberty_Subarx.html
I've used both and been satisfied.
Pat: the XT will add $5000 (or less) to the price of an XS. I guarantee it! ;-)
Keri: if yours is an S, the mirror is heated, and that explains the cost. Try a wholesaler like subaruparts.com or Liberty as per above.
If it's an L, try a junk yard like this one that specializes in Subies:
http://www.fsautoparts.com/
-juice
-mike
-juice
rsay777 - I believe there is an industry standard pattern for rotating all 5 tires. I used to do that back in the days when all cars came with full size full service spares.
Sounds to me that the best thing to do is to revert to rotating all 5. That should be easy for the smart people who saved their money and bought the Forester L (w/ 5 matching steel wheels) instead of the S. Those of us with the alloy wheels will want to buy a matching alloy wheel.
I might do this for peace of mind. It seems to me that Subaru should have used matching spares and told us to rotate all 5 tires from the beginning. (Or at least made it an option.) That way you just buy 5 matching new tires when the time comes and the spare will always be the same size as the others. In the long run it costs the same.
Dan J
It better be $2500 or less if they want me to buy one!
-Frank P.
I'm hoping it's $2000 more, that would make it a performance bargain. Vue Redline looks to be the only real challenger under $30k.
-juice
Has anyone replaced a mirror? How difficult do you think it could be? It looks like the mirror (a used one) is running around $150. My car is an L so no heated mirrors - just the movement mechanism.
I've done radios and other type of things in the past (over 10 years ago!) but I am a little nervous.
Bob
Thank you for visiting the Subaru Web site and for your message. We appreciate that you want to do what is best for your 2001 Forester S Premium Package. If you have a flat tire, you can use the spare tire regardless of the mileage on your Forester and the other three tires on your vehicle. Spare tires are only meant to be used temporarily and should be replaced with a 'regular' tire as soon as possible. Because the amount of time is short, the spare tire not being within 1/4 inch circumference of the other tires would not be a concern.
We strongly recommend not using all 5 tires in your tire rotation. This would make it almost impossible to have all 4 tires on the vehicle within 1/4 inch circumference of each other. This could cause a problem because of the length of time that you would drive with the tires not within this specification.
Thanks for the opportunity to be of assistance. If you need any future assistance, please feel free to contact us again.
Best wishes,
John J. Mergen
Subaru of America, Inc.
So it looks like the drivetrain can handle more than 1/4" difference, but not indefinitely. Although I'm not sure what they consider to be a "short" amount of time.
Juice,
On my car the spare tire is no different than the regular tires, so I wouldn't see a problem with using it permanently if it was within the spec. I thought all subarus' came with a full size spare?
gmginsfo,
I bought my cooler for $50, but they sell cheaper ones for about $30 at any autoparts store. Installation looks like it'll take less than an hours, and I thought it would be good insurance against tranny failure. From a couple of different websites (I lumped it all together):
"As a rule of thumb, every 20 degree increase in operating temperature above 175 degrees F. cuts the life of the fluid in half. The approximate life expectancy at various temperatures is as follows:
175F 100,000 miles
195F 50,000 miles
212F 25,000 miles (ATF starts breaking down)
235F 12,000 miles (Varnishes form)
255F 6,250 miles (Seals harden, Damage starts)
275F 3,000 miles
295F 1,500 miles (transmission start slipping, clutches burn out and carbon forms)
315F 750 miles ($$$$)
335F 325 miles ($$$$$$$$)
375F 80 miles ($$$$$$$$$$$$$$$$)
390F 40 miles (bye bye tranny)
415F Less than 30 minutes "
I think the optimum range for transmission fluid is somewhere between 160-180 degrees. The stock transmission cooler is integrated with the radiator, which i think runs at around 180-200? degrees normally. So even when everything is working as it should be, the transmission temp is already at the high end. And most likely, the transmission temperature is probably even higher, because it will never get to the same temperature of the coolant. That's my reason for getting one, I might just be paranoid. But I figure it couldn't really hurt anything, and it's cheap.
John
Damax07
just curious.
Gene
-mike
Dear fellas,
the time clock --(overhead) is dead (stop working) on my forester '99 Limited.
* is this a common issue ?
* is this fixable / repairable ?
* does anyone know what causes this?
* does anyone know how much roughly to replace
including labour ?
NB: the whole car, i think is sux.
another 3 days, i have to replace the rear
wheel bearings (which is NOT cheap).
now I got this clock issue.
tks all
http://www.checkthatcar.com/new_check/transmission.asp
http://www.parttrackers.com/library/1/56/58/
I haven't had any big problems with my trans yet, but I'm hoping to avoid any. I check my fluid pretty regularly, and I can notice that the fluid starts to smell burnt after about 20K miles. So I'm going to replace everything with synthetic and see if it holds up any better.
Ross
Did you check your Fuse Box.
The Clock Fuse in my car MY03 Forester 2.5x in engine compartment
Vitaly
I have never seen that purple livery in which the Forester was pictured. Also of note was that the car was credited for its bump dampening and noise suppression qualities - exactly what it has been roundly criticized for in other reviews. Go figure.
Cheers, everyone.
I have one on my wife's 96 Caravan and 02 Forester. I can say I am pleased. Used them also in some neighbors.
PS...I am in no way connected to YM or any sales company, just trying to pass along a discount as the note reads "you and your friends"....
YM International Co., Authorized online retailer of Fumoto
Engine Oil Drain Valve, wishes to provide you and your friends
with a SPECAIL 15% DISCOUNT OFFER to thank you for supporting
our business.
Using SVC4 as a discount code, you and your friends will get
15% OFF when ordering at our online store: www.fumotovalve.com
This Special Offer is for limited time only. *Expiration: 07/31/03
Thank you for your business and happy oil changing!
Best regards,
www.fumotovalve.com/
By the way, the stock auto trannies have been very robust. They've been reliable even with 300hp hopped-up WRXs.
$25,700 MSRP? Hope so, that'll be quite affordable once you negotiate. I figured $26-28k.
paul: first clock failure on a Forester that I've heard of. If you feel up to it, the bearings should not be that tough to do. Order parts via a wholesaler. You're Down Under so it would be hard to guess at prices.
joseph: overall noise levels in the Forester have always been low. C&D measures them and in both comparisons the Forester was in, it recorded the lowest noise levels.
Maureen: the 04s will come next month, so I kind of doubt prices will get any lower. At least not significantly lower. If you are price shopping, I'd buy now.
Just returned Bob's trailer, after using it for a few days. I did a round trip from his house, plus two round trips to the mulch yard, just over 100 miles overall.
Since we has just talked about it, I decided to get gas just before and then right after using the trailer. In fact the trailer was on there the entire time, minus the trip to the closest gas station.
Well, the mileage penalty was more than I thought - I got 17.3mpg, my worst ever by far. My previous worst was 20.3 mpg, and that was the week at the Outer Banks, when I spent most of the time on the sand.
It was raining, and they really did fill it up to the brim (I'm guessing 4 yards of wood chips per trip), and I guess I should be happy because that's what most models do without a trailer behind it! ;-)
-juice
-Bob
Your first tank will record very poor mileage, the 2nd a little worse than normal, and by the 3rd it should be back to normal.
-juice
Sheesh! It's getting so I really dread having to place my vehicle into the hands of people like this, even for the most trivial things.
-Bob
The cargo liner used to be standard, I strongly recommend one. Mine has taken a beating, but the carpet below is perfect. I tend to prefer the net over the bins, personally.
My wife's Legacy did not come with one, so the liner was the first accessory I installed for her, the net came next.
-juice
Haven't tried the cooler/warmer things, I was looking at getting one from target, but they're too small to really be useful for me.
-juice
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item- =2416002824&category=33697
Knock sensor: Yes, milage does drop after an ECU reset, but I've found that it returns to normal after 1-2 tanks.
Cargo liner: A great investment. My cargo interior looks great after 5 years thanks to the liner. The cooler unit is okay, but you need to remember that it works only while the power is on.
Ken
Does anyone have comments on whether the air filtration option is worthwhile?
Am I the only person who thinks the hard unpadded lid of the "armrest extension" is unfriendly? Anybody know of a padded alternative available anywhere?
Has anyone with a 2003 Forester replaced the U.S. D.O.T. headlight shells (lens & reflector) with the probably-much-better European Forester shells?
-Jack, who'll probably buy an XT soon
Ken: don't all Subies use a 17mm drain plug? I bet it's pretty much universal on Subies. I was more concerned about the residual oil left in the pan.
Jack: I have the air filtration, but I also have asthma. My filters were not that dirty after one year, but I've seen some that were absolutely filthy. Does your interior tend to get dusty?
If you think the armrest extension is bad, try the door arm rests on the early models, those were rock hard. Now those are padded. The center one isn't nearly as bad.
I have E-codes on my Miata, that's the euro pattern you're talking about. They put more light on the road, less elsewhere. My concern would be to buy from a supplier in a LHD country (i.e. not the UK), so the light beam is in the right direction.
-juice
Just got my '01 Forester L back from the dealer for a new Clutch, Pressure Plate, and Flywheel all covered under warranty ($831 was the bill the dealer submitted). Been great so far.
Complained about the clutch shudder problem to the service mgr starting at 3000 miles (car at 20,000 miles now). Service mgr kept saying "can't duplicate - don't worry it won't hurt your car". When I set up my latest oil change I brought it up again and mentioned that I have been reading about clutch shudder on the Internet and I can't believe that other owners have not seen the problem at the dealership. To which the service mgr replied "I have never heard of the problem on the Forester - you say you read about it on the Internet? I'd be interested in seeing that." That's all I needed to hear - I printed out about 30 pages of the choice postings on the problem including a print-out from a CA company that sells a "Subaru Clutch Fix Kit". I delivered the printouts when I dropped off my car for the oil change and when I came back to pick it up the next day the service mgr said "Subaru has a service bulletin on your clutch problem and I ordered the parts - when can you bring it in again?". When I picked it up for the clutch work I was very suprised that the work included the flywheel.
I don't know if the printouts from the Internet helped or not, but it sure seemed like they did.
cellmates
The security system upgrade on my 98 Forester added the alarm horn and motion sensor to the pre-existing keyless remote. Subaru outsources their alarm units. Mine is made by Alpine. It's a basic unit, but does it job well enough for my area.
Air filtration is worthwhile. I'm always amazed how dirty the filter is when I replace it yearly. I'm not sure about the latest Forester, but for my 98 it was a simple DIY installation. I saved $$ by buying the filter kit and installing it myself.
I'm sure it's possible to swap in e-code lights into the Forester -- it's just a matter of getting a hold of the assembly. FYI, the beam pattern on my 98 Forester is very good for a DOT headlight. The cutoffs are very sharp leading me to believe that Subaru might just have used a universal headlight for their models. Using a Philips Vision Plus bulb made the cut off even sharper.
I'd try out the MY04 headlights before changing them out.
Ken
"I have a 2003 XS2.5 which I drive about 7,000 miles per year. I will, in the course of each 12 months, accumulate $500.00 in Subaru bucks. When I have enough would I be better off buying an extended warranty with them, or would it be better to just save them to use towards the repairs, servicing and parts replacements that are part of the regular expense of owning a car?"
What are Subaru Bucks, how do you get them, how many do you get, and so forth?
Hold on while I ask my surgeon... Nope, he says my interior is whistle-clean. My car's a mess, though, so maybe I'll order the kit.
-Jack, whose sense of humor is abysmal.
My car is only 7 months old so I have no interest in the offer.
DaveM
-Brian
Went to my local Pep Boys today to pick up some Mobil 1 10w/30 and they don't seem to have the stuff I've been using for the past two years. Apparently they have a Mobil 10w/30 synthetic "Blend". The girl at the register didn't seem to know.
They still stock 5w/30 and the other viscosities in true Mobil 1 form.
Anyone know something about Mobil 1 they care to share?
/Scott
www.cars101.com
-Brian
