Subaru Forester (up to 2005)
Ed
-juice
Of course if you miss a turn, you are now behind schedule and need to make up time.
-mike
Thanks for your advice.
Gene
Sounds like it's different now, you might need only the filter.
-juice
Gened
I think it should be similar to this.
http://4ester.net/Forester_Technical/Forester_TechDis4.htm
On the new ones, I think the only thing you really have to do is put the filter in, everything else is already there.
I have a 2001 Forester that I added the interior air filter to. You just pop off the two metal clips and lower the plate (and rubber gasket). Insert the TWO filters (they both come in the box and they fit together) into the opening, put the cover and gasket in place and fasten the two clips. Reading the instructions and looking it over took me twice as long as installing the filter. I replaced mine after about 15 months, and it was pretty dirty. It's amazing how much crap would be getting into the car without it.
I hope this helps.
Len
Greg
If not, then if my Forester is pointed up hill and both the right front and right rear wheels are sitting on glare ice and the left wheels are on dry pavement, would it be correct that the right wheels would spin and the car would not move despite having "Active All Wheel Drive"?
"Active All Wheel Drive" is Subaru's brand name for their AWD system found in the automatic transmissions (except for the WRX, VDC Wagon and Legacy GT). This system uses an electronically controlled clutch pack that "actively" changes the torque split between the front and rear axles (not each wheel) based on driving conditions. These driving conditions can be what gear you're in, your throttle position as well as ABS.
The situation you described would indeed result in the right front and rear tires spinning without any forward motion. The AWD system, as far as it is concerned, is not sensing any problem since both the front and rear axles are spinning at the same rate.
The same applies for the 5-speed manuals that use a viscous coupling. It too only manages torque split between the two axles and not each wheel individually.
Some models use a rear limited slip differential to give extra traction in situations you mentioned and also in high performance driving where you one would be cornering at the limit of traction. The LSD helps to then sort out any differences between the left and right rear wheels. In this case, you would theoretically only get stuck if both rear tires and one of the fronts were on zero traction.
The only Subaru model that can manage torque to a specific wheel is the Outback VDC (and the WRX STi in a more passive manner). This model uses a slightly different AWD system coupled with a traction control system. Together they can direct torque to and away from any individual wheel.
So why doesn't Subaru just simply overlay a traction control circuit over all their vehicles? I think the answer is cost. The challenge with getting power to an individual wheel is that an active AWD system, for lack of a better term, (differentials, clutch packs, viscous couplings) and a traction control based AWD system work against each other.
If a wheel was spinning independently, traction control would try to slow it by applying brakes to that wheel. However, an AWD system needs that initial "slip" to get it to direct torque away from that axle.
The VDC system uses some complex electronics to manage the entire interaction between AWD and traction control. Other companies like Mercedez Benz use all open differentials (ie. no active way to split torque) and rely on pure traction control. The pros to a traction control system is that it's simple and adds virtually no weight. The biggest downside is that in some situations you can loose quite a bit of forward momentum since the system relies on braking.
Ken
http://www.subaru.co.jp/forester/index.html
We were just discussing the other day why the interiors on the Foresters are so BEIGE (or grey! It's like you got a great apartment but you can only have it if you agree to take the big paisley sofa that came with it. Makes you feel so middle-aged.....My wife's trying to cover as much of it up as possible with floormats and seatcovers.
JL
Cheers
Pat
No one is writing up the XT, not Automobile mag, C&D, or Edmunds. And it's supposed to be in the dealers in a few weeks? I'm beginning to like the lack of attention though - just think of what a sleeper the XT is going to be!
I'll likely be getting mine in black w/ the mega moonroof!
-Brian
Cheers
Pat
Obviously we don't have a review yet. Read what was said in the Future Vehicles section.
I wasn't aware that official prices had been released yet but I am sure our editors are on it!
There's plenty of talk about XT pricing in the Subaru Crew discussions, as well as Nasioc(aka nabisco, lol) and SubDriven. Nothing on XT pricing over at media.suburu.com yet though.
-Brian
If that link doesn't work, just do a search on Subaru there and the XT link should be the most recent link (5/23).
-Brian
Well, me too but let's TRY to be patient!
You're correct about the interior: black only. There is one more exterior color - the same metallic red available on '03 Foresters.
I really wish there was a metallic charcoal grey, but I ordered my XT in silver.
The Edmunds site says there will be a First-Drive report on the '04 XT in June. Let's hope that's EARLY June!
- jack
Cheers, Pat "
That's true, but that's not what kept me from ordering leather and sunroof on my XT. To get them, you have to sacrifice the 5-speed and order the automatic. Ridiculous. Completely brain-dead configuration decision, SOA!
tidester, host "
Official XT pricing has been out for about two weeks. First place I saw it was on the cars101.com website of a Seattle dealer, and I posted that link here two weeks ago. Including $550 destination charge, a base 5-speed XT is $23,323 invoice and $25,520 MSRP. Adding two popular groups and a boost gauge, mine will be just under $24K delivered.
Well worth doing based upon how filthy mine was at 7500 miles. Lots of stuff I'd rather not breathe in.
HTH - Larry
My opinion: The Subaru dealer-installed hitch is grossly overpriced. If you search the 'net for something like "Forester hitch" you'll find lots of well-known companies like Draw-Tite that have been making frame-mount hitches for decades. You'll be able to buy a hitch made to exactly fit your Forester for around $100-125. They require no drilling and bolt up to existing holes, exactly as the Subaru hitch does. The muffler hangar and fuel vapor collection unit get unbolted, then they (and the hitch) bolt onto the same mounts. You could probably install it yourself in an hour, or two at most, with nothing but a socket wrench. This is what I plan to do with my '04 XT when it arrives.
I don't mind sharing, it's nice that it's being hosted somewhere, actually.
On that hitch, the only tricky part was the fuel vapor canister. Just pay attention to how it's connected and make sure you don't end up with loose hoses.
Oh, and get a long-shaft torque wrench.
-juice
i agree that the tow hitch is way overpriced. ill go aftermarket.
i have joined the IMBA, celebrated by riding trails all weekend, and my subaru VIP dealer invoice + 0 privilege ought to be just about right come december, when the new intro chaos should have died down a bit and selection should be better.
mark
It was easier to snap the parts back together, remove the front bolt, electrical connector, two hoses (didn't even need pliers for the clamps) and loosen the hose clamp at the intake manifold(a socket, 5/16 I think, worked great).
In fact it took me longer to type this than it did to actually do it. Then you can open the case, clean it out and reassemble it with the new filter. Then just drop in the whole assembly. Very quick and easy.
I haven't checked my wife's 03 Outback to see if its as tight to work on.
Larry
Now thats fast delivery!!
Went out took off the two clamps dropped down the hinged door put the filters up into the box closed it up and I'm good to go!!
Seems like the 02 is less work than the 03.
Thanks everyone for the information.
Gene
Wait, I just thought of something. Are you trying to remove the filter without removing the back of the box? Maybe that's why, you can't open enough to get to the filter without taking the back off, you have to remove it first. Just pull the back of the filter box out (rotating about the intake elbow like I mentioned) and you should be able to get to it no problem.
I realize all the hoopla is over the new '04 Forester XT (and rightly so!) but has anybody seen what, if anything, the 'O4 X (base) adds to the '03 X version (eg, better armrest, limited-slip, etc)?
getting itchy...
Have you been inside the ducting upstream of the air filter housing. Any reason to clean in there when the need arises? Bob L
It doesn't look like there were too many changes to the 04 over the 03:
http://www.cars101.com/subaru/forester/forester2004.html
Other than the intro of the XT, it looks like the X gets cloth visors instead of vinyl, all models get collapsible pedals and the XS loses it's cassette player. Also prices increased by $50.
Ken
I realize all the hoopla is over the new '04 Forester XT (and rightly so!) but has anybody seen what, if anything, the 'O4 X (base) adds to the '03 X version (eg, better armrest, limited-slip, etc)? getting itchy... "
No change, according to what I've seen. And only a $50 price increase. You'd probably be better of getting a steal of a deal on a 2003 X. Portland-area dealers are advertising them in the low $17K region. Haven't seen anything in the $16's yet, but who knows?
I've been considering an XS premium, but have been dragging my feet waiting to check out the XT. Local dealer seems to think that the new model will be in soon - hoping I might still be able to deal for a 2003 if I can't justify price-hike on XT. Thanks alot.
At that point I came up with plan B.
Put it down to a minor manufacturing difference?
Larry
My wife and I will be getting a 2001 Forester next spring from my wife's parents. They are moving to Florida and are taking only one car. Are there any potential problems that I should know about with the forester? My in-laws arent the best at scheduled maintenance but they do manage to change the oil and rotate the tires at least twice a year. The car had a low number of miles on it (18000) the last time i saw it. It is their second car driven mostly by my father in law who is retired. I dont anticipate more than 25000 miles before it is given to us. I can't wait until i can drive it as our own being a big fan of subies and the previous owner of 2 of them. Any help would be greatly appreciated
thanks in advance,
Kyle
I think I'm going to look into a 04 Forester XT Premium - silver, but was wondering if some of the options would cheapen the look of the vehicle more than they protect it, or server their intended purpose. I'd like to get something to protect the windshield and front of the vehicle from stone chips since most of the roads around here are in pretty bad shape, and the Moonroof air deflector may be of some use in keeping wind noise down on the highway. I haven't seen pictures of any Foresters with these options installed. Are they not worth installing, or do they work and no one likes their looks? Any information on the usefulness of these or some of the other options would be greatly appreciated. From some of the other posts, I already see that the cabin filter is worth looking into.
You could try a product by 3M (?) that basically is a very clear piece of plastic (or something high tech) and apply it to the first couple inches of the hood edge. I'd probably look into something like that when I get our XT at the end of the year or so.
-Brian
Len
-Frank P.
