Isuzu Trooper Check Engine Light
I've got a 93 Isuzu Trooper that is giving me a check engine light intermittently in the morning. Again, this only happens in the morning and is intermittent. When the car idles, I get no check enging light. When I accelerate, the check engine light comes on. In the afternoon, when the day is warmer, the check engine light stays off. I took the car into the dealer and was told this was the EGR valve so I have removed and cleaned the valve but am still getting the same check engine indicator. I am going to try and replace the EGR valve but was wondering if anyone has seen this before and could offer some advice before I go through the trouble and expense.
http://www.carspace.com/atfdmike/Albums/ISUZU%20TROOPER%20FORUM/egrchart7.gif/ph- oto/v./photo.jpg
Hope this helps.
1993 Isuzu Truck Trooper (4 Door) V6-3165cc 3.2L DOHC (6VD1)
Vehicle Level Powertrain Management Emission Control Systems EGR Valve Testing and Inspection
Warm engine to operating termperature (120°F / 60°C).
Place finger on on EGR valve diaphragm and accelerate engine, diaphragm should move.
Disconnect vacuum hose from EGR valve.
Using a vacuum pump, apply 10" of vacuum to the valve. It should move and engine should run poorly or stall.
If valve passes above test use CHART C-7A. If valve fails, replace valve.
The procedure usually includes the use of a digital voltmeter and is not technically challenging, but hopefully someone who has done it or has a diesel manual will see your post and respond. One guys opinion.
Any suggestions on resolving this issue?
Any suggestions on cleaning the outlet pipe that goes into air intake? I could not clean this pipe properly. Is there any way to clean without opening the air intake?
Thanks very much in advance.
and the check engine light
stays on, i had it check out
and it was the EGR valve.
How do you remove the old
EGR valve and replace it
with a new one? Please advise.
There is a gasket between it and the manifold that you may need to replace if in removing the valve it is damaged. Your discretion.
Original Isuzu part no is 8170961783
Hope this helps
http://www.isuzufaq.com/
" The car will not idle correctly, is difficult to start and runs rough much of the time. My truck did not do any of that. I was also told that in many cases, the insufficient flow may be from carbon in the passageways to and from the EGR valve. After some closer looking with a flashlight in hand, I found a plug that has access to the line between the ERG and the cylinder intake. The plug is located below the EGR unit on the left hand side. You will need a set of hex keys to remove this plug. Once I had the plug removed, I had clear access to the horizontal passageway to the engine intake. I quick inspection did show quite a bit of carbon build up within. To clean the passageway, I broke out my gun cleaning kits and used the barrel brushes attached to a 12 inch section of rod. I believe that it was the .40 caliber brush that was the closest in size. I also used the generic carb cleaner in the process as well. This scrubbing did remove much more buildup than I imagined. I installed the plug back in it’s place and have not had a 401 so far. So I believe that possibly could have been the problem. "
Manual lists:
K16PR-P11
PK16PR11
RC10PYP4
How do you know the battery was to small? Make sure you did not put a larger battery then needed compare the old and new battery. Hopefully you put O.E Orgnial equipment spark plugs in the car. There is a lot more to batteries, spark plugs and even air filters Nowadays. Every thing is tied into each other and the computer. I would suggest taking this to a shop. Hopefully this helped.
I am new to this forum and found this very helpful..... I have one question though..
I have 2002 Trooper which runs perfectly fine, but from last month and a half I noticed that CHECK light is keep coming up, its right under TOD sign, its not the constant but keep coming now and then. sometime when I start engine it stay there and flashing then I turned-off and turned back on then it goes away.
Any idea what is it for, I will really appreciate your help.
Check this out: http://isuzufaq.ibctech.ca/range.pdf
Bill
I have Isuzu Trooper 2002 my SUV running fine until 3 days ago then it was just parked in my garage, today when I start my car, it started fine but about after qtr mile I see Engine Check and Reduce Power lights were on and my gas paddle just went free and there was no power when I press gas paddle and car was running like 2 MPH so very slowly I reached home.
Can anyone tell me whats wrong with my car, its been running fine in fact a month ago it got done complete tuning.
Any help will be really appreciated.
P1295 - Electronic throttle control power management mode probable codes.
P1515 - Commanded versus actual throttle position correlation.
P1125 - Electronic throttle control limited performance mode-two APS faults set.
My question is... Do these problems fall under power train warrenty ?
Thanks in advance for any help.
