Honda Civic Security Systems
Does anyone know what kind of security the new Civic has? I know that it has anti-theft radio because the console covers the radio, but does it have an alarm system that sounds when someone tries to break in, bump the car, or breaks the window? I'm thinking of installing a security system with shock sensos, glass sensor, and an alarm pager...does anyone have any experience to recommend what and where? Thanks
I am looking for some information on how to wire the remote starter part of the system for a manual car. I know that I must bypass the starter wire and somehow connect to the clutch switch, but I don't know how.
If anyone can help me or has come across a good resource, please let me know.
Thanks for the help,
M
i've had lojack and viper for over 10 years and that's what i'm using for my new Si. Lojack is good for prevent and retrieval, Viper has some good features too. if someone bumps your car it'l page you (pager in your pocket)
Lojack can be set up to call your cell phone
with these cars you can't be lax because it'l get stripped or stolen - you'll never see it again especially if its got good condition or fancy accessories
good luck
What is the cheapest/basic Viper model that would have basic alarm with a two-way remote/pager? I don't need remote start either. The closest and cheapest is the Viper 5000 i've found.
Thanks for the help
1. put on car parking break
2. turn key to II position
3. press and hold the driver's door "unlock" button to hear two clicks (1st click after 5 secs, 2nd click after 10 secs)
4. within 5 secs of hearing the second click, turn key to I position
I've followed those steps at least 3-4 times and have had a second person check the directions. I've also pulled the key out after the steps and restart the car, and start the car immediately after completing those steps...and everytime, the front passenger doesn't unlock from the inside.
Anyone know what I could be doing wrong? do I need the gears to be in 1st, not in gear, feet on brakes?
In the interim, I played around with the auto-locking/unlocking feature, so that the car doors would lock after AT was moved out of Park and unlock the drivers side door after putting AT back into Park. After finding this a nuisance, I disabled locking when AT is moved out of Park.
And now, I've noticed that the car does not lock by itself after doors are closed and waiting more than 5 seconds. How do I enable this again without enabling the feature to lock the doors after AT is taken out of park?
Also, the locking/unlocking feature was a nuisance since only the drivers side door would unlock after putting AT back into Park. Is there anyway to unlock all doors?
I try to use these following instructions available online to reprogram the remote I just bought but it does not seem to work:
1. Turn Key to on position.
2. Push and hold valet button on the stock radio (which is skinny bar located between am/fm & cd/tape buttons on stock radio). Door locks will cycle one time.
3. Press any button on remote one time within 20 seconds. Door locks will cycle again.
4. To program up to 4 additional remotes repeat step 3 for each remote.
5. Turn key off programming is complete.
As my car does not have power locks, the door locks will not cycle as indicated in step 3 above. So I do not if these program instructions are incorrect or the remote I just bought is defective as I cannot use it to arm or disarm the antitheft system.
Does anyone know of about a different procedure to reprogram a keyless entry remote for a 1997 Honda Civic with a dealer installed antitheft system (but NO power lock)? I am sure that someone has been through this before and has it resolved. Please share the solution.
Thanks in advance for your suggestions/information.
message to the dirtbags/scum, if you come back for the rest of my car, get ready for a big SURPRISE!
BTW... Stock, it does not come with an alarm that actually makes sound does it?
Thanks in advance
Whenever I turn off the car the driver side door locks unlock, but none of the others. I have to manually press the door unlock button to unlock all the other doors. Do any of you know if this is normal or if there is a fix for this? Is there, perhaps, a way to program the automatic locks so that all of the doors unlock when you turn off the car?
Thanks for your help.
I never even knew this was an option, thanx will26 for the heads-up.
Let me know how it works for you.
thanx again. My wife really appreciates it...as will any one who rides with me. Being able to get out seems important.....
rich
The dealer is correct, keyless entry was not a standard feature in the LX models in 2005, it was only offered in the EX models.
And the Honda factory security system was an upgrade to all Civics in that year.
Here's a web-site where these accessories are sold where you can verify this information. Just scroll down to the descriptions of the Keyless and the Security System and you can see these accessories are meant to be sold for the 2005 LX.
http://www.collegehillshonda.com/honda_civic_4dr_accessories/03_05_electronics.h- tm
Anti-theft: passive or active
Does the device disable the vihicle (is it an ignition or fuel system cut-off) sound an audible alarm, or both?
Device manufacturer's name:
Device model name/number and serial number:
They also want a dealer's invoice which is easy enough (or some sort of proof of anti-theft installation) but the invoice doesn't have the anti-theft listed since it's standard. Any suggestions? Thanks.
Technically there are two anti-theft devices. The immobilizer system which is passive and cuts the fuel line if it does recognize the chip in the key. The security alarm is active (it only turns on when you lock the doors) and it sounds an audible alarm.
As for the device model number you should ask your insurance agent how to fill that out or just put down Honda standard system.
http://www.clifford.com/Products/Product.aspx?ProductID=705
I arm both the factory system as well as the Clifford. With both systems armed, I'm not too concerned with the car being stolen so I didn't get the Lo Jack. I was more concerned about vandalism such as stealing the Nav System. With the Clifford, I have a shock sensor which will detect window breakage. I also have a two way transmitter which will instantly page me should something occur. My car is parked on the opposite side of my apartment building, so I wanted something which would alert me at night that something was happening.
The bright flashing blue light of the Clifford is also a nice touch---lets people know that there is something else in there other than the Honda factory system.
