How much is the iPod connection and what does it entail? My dealer quoted me of $149 plus installation.
My dealer doesn't even know it exists. Tell him to get off of his lazy @## and get online!
Could I alternate and plug my Sirius Sporster unit (which I already have) in it also? I'm guessing if you already have the Sirius unit hardwired from the factory, you might just want to wait for any updates.
It would work if there was a 1/8 pin connector rather than a iPod dock connector. It's only going to work for the dock connector though, since the head unit also allows the steering wheel controls to control the iPod.
Any options to switch? Hang tight, theres way too much money on the table for Mazda to walk away from, not to mention any models they might want to offer with the Tech package in the future would be obsolete before they left Japan.
Apple and Mazda will come up with something...
1. Any update on IPOD adopter
2. How do I display the FM channels name in the display.. Like the one in Murano..??
Thanks..
http://townhall-talk.edmunds.com/direct/view/.f0f3a79
As for displaying FM channel names? Can't be done. This is one of those shortcomings of this head unit.
Vince.
When I bought this vehicle I was specifically told that it would play MP3 files. In fact, when I was looking, I wanted a vehicle to either play MP3s or have an AUX port. Turns out it DOESN'T play MP3s OR have an AUX port. Oh it will play MP3s if you bought the right one from the factory in the beginning. To get the right one now costs $550.
And I was also told that you cannot have the AUX port if you have Sirius installed. The port, by the way, would be installed in the glove box.
Someone mentioned maybe a switch. Even if I had a manual switch on the line going into the Sirius port that would allow me to plug in the 1/8 pin. Does this sound feasible?
You can get an FM modulator installed that will allow the 1/8 jack to plug into your ear jack, but the sound won't be the best. And if the salesman specifically told you that the unit would play MP3s, I say haul their butt into the General Manager's office to make the switch free of charge unless they want a negative referral on their opinion survey!
{They hate that}
While you're at the dealer, make sure they've swapped out the gas cap for the new version that has the gaskets on the cap to prevent the engine light to come on.
:shades:
Also, I've already tried to force them with opinion survey, knowing they get paid on good reviews. That's when they told me that it sould cost me $550 to get one that plays MP3s. Guess I need to play hardball.
The thing is, is that the floor managers don't want any problems going over their heads, and they'll do whatever it takes to make it right before the owner finds out about it!
Trust me, after working in the business for 6 years, I found out first hand how pressure on the GM will make a customer very happy!
There is not a General Manager alive who wants the owner to know he can't solve a customer problem on something so trivial as a head unit on a new car that his salesperson misspoke about!
Keep working 'em over, they'll give!
Legally speaking, if a guy said a car did "x" it's your word against theirs. Frankly, neither the Monroney sticker nor the brochures point to an MP3-compatible player, and the $500 range is probably where it starts to get hard to recoup without a real fight.
Anyway, good luck, but the best policy next time is to strive to be more educated about the car than the salesman. Sadly, in my experience, it usually ain't that hard.
He's the Mazda manager... he's also the owner's son. This is a huge dealership too, Lujacks Auto Plaza. I believe they have every major mfgr except Ford.
I'm sure he won't want Dad to find out.
There are other issues with the vehicle as well. It's only getting 16-20 mpg on the Hwy for example, and they tell me that's perfectly acceptable. The key and remote start fob have stopped working and they're on backorder indefinitely. And many other things. :mad:
We don't get paid on individual surveys...
I compared these two disks and noticed there was a format difference between the two: the CD-R (which plays fine) is in the older CDFS format. The CD-RW (which I just formatted using Windows XP and was not recognized) was in UDF format.
I then took this same CD-RW and burned a playlist of MP3s to it using iTunes (I made sure the Advanced burning options were set to burn tracks to the disk as MP3s, of course). Voila! When the disk was done, it was completed by iTunes as CDFS. It plays perfectly in my Bose unit now.
Hopefully, this will solve your problem.
Carl
i have made only CD-R's and none have been recognized. also, i have used iTunes' mp3 burning option. so i must be still missing something that you got.
could there be a difference between your windows xp and my mac os x?
no voila's here yet. hope you have some more insights.
thank you.
xopher
RealPlayer Plus version 10 fully supports MP3. That product is awesome. I burn MP3 disks with RealPlayer and they play well in the Bose deck.
Unfortunatley, RealPlayer isn't compatible with Macs
Vince.
From the Mac's desktop, right click the image of your CD-RW disk and choose "Get Info." Find out if the disk's format is "Universal Disk Format" (this is the UDF format I was referring to in my previous post that causes the conflict with the Bose stereo).
If it is UDF, use "Disk Utility" (a program located in your Utilities folder) to Erase the CD-RW (quick erase is sufficient, and will be a lot faster than a full erase). This removes all the data from the disk, and its format.
Now, go to iTunes. Make sure that under the iTunes menu under Preferences, you choose your Advanced/disk burning option as MP3 CD. Burn a Playlist of MP3s to the CD. When the disk is completed, the format of the disk will now be compatible with your Bose stereo (at least it is with mine).
I hope this works for you.
Carl
So, sorry to (RE)state the bad news, but if your head unit does not have the MP3 logo, no amount of disc formatting or OS tinkering are going to help you - just because it says "BOSE" does not mean it plays MP3 files.
So, besides a dealer-installed accessory, how does one GET the MP3 capability? Is it in the technology package?
Is his price quote totally insane or in the ballpark? Has anyone out there added in satellite radio after the fact, and if so, what were your experiences? Thanks.
My guess is that you're being a bit hosed...
On the Mazda website you can get the radio and installation kit for 399. Then you can ask the dealer what the charge for installation is, roughly about 2 hours {I wouldn't choose anyone but Mazda to install it}. or you might just call another dealer, that 600 is steep, even with 15% off...
So for the money Mazda is asking, you have to find out:
Is it Sirius or XM? (It's probably Sirius, because that's the CX-7 integrated unit).
Which radio/features are you getting? Is it fully integrated into the vehicle, or something placed on an extra mount like mine?
Finally, once you've determined those specifics, you might want to comparison shop on your own. I certainly would.
Opting for XM negates all of that. Output from any XM component will not display properly on the Nav screen nor on the upper dash. And as calessi points out, one would have to use an available FM frequency to gain output.
From a purely aesthetics point of view, sticking a docking device and a clunky looking module onto the dash, in my humble opinion, would look like !@#$#. :P
Vince.
I will have to find out how much my dealer would charge to install the kit if I were to first purchase it from the Mazda website. Perhaps that route will bring the price into a more reasonable range.
If nothing else try another dealer in your area... try the aftermarket dept. and ask who does their installations as well.
I agree with Vince {again
"It will be available with the Dealers in September."
But not sure Sept 2006 or Sept 2007. But looks like it will be there soon... to know more read the MAZDA FUEL magazine issue 6 Page 11
Thanks..
:shades:
The unit is out already. Check out "The news ain't good..." link on the front page.
I DO think there will be some options available when the car has been out a bit longer. Because it's so new, tackling the problem just hasn't been figured out yet. But as an example, apparently on the Mazda 3 with iPod plug, originally you weren't able to have both the plug working and satellite radio, but they've since come out with a splitter that makes it possible to connect both.
Anyone?
I can e-mail the instructions if you want.
One of the models I am considering has to have the Sirius unit added but so far they have quoted me the normal option price... probably because there is a little cushion in the deal they can take the hit for the labor. Once you leave the dealership with your new car the entire expense to add it later becomes the car owner's responsibility and exceptions are rarely made unless you have a lot of clout with the dealer's owner.
I understand new licences for your XM account are very inexpensive, so if that's your primary consideration, you may just have to wait for the aftermarket to start producing products for the CX-7.
Good luck, Vince.
Took me about an hour; the hardest part (or maybe most STRESSFUL, I should say) was taking off the center dash bezel that covers the radio and HVAC controls.
Sorry I didn't take any pictures, but if you Google "iPod CX-7" you can find some guys who have done it and posted progress images. The adapter comes with pretty decent directions, but if you've ever put in a car stereo, the process in the CX-7 shouldn't be that complicated for you.
The display integration leaves something to be desired, but the functionality is good, and all the controls, steering wheel or otherwise, work fine.
I like the fact that the volume level between radio/CD/iPod is pretty consistent. That was a big problem in my other car where I was only able to install a line-in jack for the iPod.
All in all, I'm happy and looking forward to loading up my new iPod (also a holiday gift) with music.
-c92
Enjoy the new iPod kit!
Vince.
Incidentally, I spent yesterday loading 1,800 songs on my iPod. This morning I am learning that my comment about the functionality of this adapter may need to be revised.
Getting access to the actual songs I want is proving to be a fun little game, which is cool in the driveway, but less cool during the commute.
I made all my MP3s with iTunes or iTunes+SoundTaxi. I used standard CDRs (nothing special). Info is displayed properly on the nav screen.
And if you're using iTunes; go to 'Edit', click on 'Preferences'. When the full options box opens, click on the 'Advanced' tab then click on the 'Burning' tab and place a check on the box for "CD Text".
From there you can name your playlist, and create your disc with the title of the disc being the playlist, and the names and artist being displayed.
Next time you make an MP3 disc, trying using the 'Data Disc' option, some machines don't give the full info on MP3 type discs.
This definitely has to do with the ID Tags. Load the MP3 into iTunes, right-click on the song and select "convert ID3 Tags" ... then select version 2.2 (I know for certain that works because it's what I'm using for my MP3 CDs in my CX-7 -- version 2.4 might work too, just don't know.)
