Mercedes-Benz E320 Issues
spiritd
Member Posts: 1
Hello! I am looking to buy a new vehicle and was leaning towards the Mercedes E320. I am looking at a 2003-2004 model of the vehicle and I have a couple of questions:
1) If the car has 20-50k miles on it, then will that mean it'll be problem free?
2)Could I put a MB navigation system in it later if wanted? How much would that cost?
2) Not likely.
Thanks, Justin
And I have the same problem with the temp display in the warm weather; some of the segments in the numbers don't light up so some days I can't tell what the temperature is. Seems to be OK in the colder weather though.
Have you ever had the alarm sound off when you opened the driver door when it was UNLOCKED? It has happened to me 7 or 8 times in the last year. My dealer can't seem to fix that or the right side rear view mirror that won't tilt down when you back up.. I've only asked them to try once on those, and they claim to have replaced switches but that didn't fix them..
Both rear power window motors stopped working and had to be replaced. The dealer said the cause was that they were not used often enough and that was the reason for their failure. I have heard some lame excuses in my time, but a part fails because of none use. PLEASE GIVE ME A BRAKE!
While driving home from the dealer after getting the power window issue fixed at $400 per window, I noticed a loud strange noise as I turned into a parking space. After this noise I could not turn the steering wheel. the car was towed into the dealer where it was discovered that the bolt which connects the steering wheel shaft to the steering gear under the hood had failed. It completely sheared off.
This is turning out to be one of the most undependable cars I have yet owned. To think that its original new cost was over $55,000 and now have a critical part fail is most disturbing.
This is the first and last MB I will buy. My Lexus cars have been by far better built and significantly more dependable.
Twenty years ago MBs were the best on the road but in the last 10 years their quality and dependability have gone down hill significantly. The number of miles on it is absolutely no indication that it will be problem free. My experience is, that the more miles on it the better the chances are that there will be more problems in the future. If you want a dependable luxury car buy a 3 year old LS430 Lexus with 20k to 40K miles on it. You will never regret following this advice.
As for adding an after market GPS there are many available today. Some merely stick on the dash or windshield and a good one can be had for as low as $300 to $400. The Garmin 4040 is an excellent unit. However if you want one that is built into the dash they are available as part of a new radio and will cost about $1500 and up. The only real advantage of the built-in units is that most have larger screens then those mounted on the dash. Circuit City has both types of units on display. Also do a search on the INTERNET to learn more about what is out there.
Anyone installed one on theirs?
Stan
email a1a55559@telus.net
Any thoughts and suggestion on this issue?. Thanks
Suggest that you join the Mercedes owners club. You can read their site but cannot post unless you are a member. I have solved several problems with the help of this membership.
Strongly recommend that you join the MBCA--Mercedes Benz Owners Club. Only $45/yr. Good tech support available.
D
I could not move it to the 1, 2, or 3 settings. Has this happened to anyone else?
I think that there are times in bad weather or in mountainous regions when the
slower settings are useful.
Maybe one of my grandchildren has dropped something into the center console that has become an obstruction.
I did take the car to a reputable transmission repair shop and a specialist drove the car for a few miles. He said the car engine and transmission are working fine and that the problem is probably in the center console. Maybe a mechanical blockage.
Bought a new battery for the car and for the key. Had a MB mechanic check the car w/ the computer...no malfunction codes appeared.
Last week, same problem. But now, nothing seems to work. And the new battery when checked, shows there are defective positive plates. Will exchange the battery,but...what could this be?? Any thoughts. Can't get to a MB mechanic/dealership any time soon...thanks, ama
also the key doesnt open the trunk from the key slot on the actual trunk is this normal.? does the key usualy open the trunk ?
We were considering a 2006 Cadillac CTS when we saw a 2001 E230 on the dealers website.
Is it practical to buy such an old car? The price is affordable.
Is this a car that is difficult to maintain?
Is there much reliability difference between a 4 year old Cadillac and a 9 year old Mercedes?
