Ford F-Series Climate Control
jetmech_63
Member Posts: 1
in Ford
I need a direction to go before i dig into this. I have a 99 F-150, standard cab with the V-6. I have a problem with the climate controls. The Fan Blower works in all speeds. The A/C works, and the Heat works. But no matter where i turn the far right knob(to tell it where to blow i.e floor, dashboard, vent etc...) it always comes out the defroster vents. It will blow A/C and heat, but it will only come out of the defroster regardless of setting. Any ideas.
Start checking all the lines - look for obvious disconnected lines, then check each one for holes or cracks. The vaccuum lines should be smooth and pliable. If a line line is stiff, brittle, or cracked replace it.
Not sure about your model F-150, Ford may not use the typical black rubber vaccuum lines to go to the climate control on your truck. It may look almost like its colored wire about a quarter inch in diameter going up to the climate control air box up on the firewall.
I very dissatisfied with the heating system, no matter what control you set it at very little to no heat will come out on the floor. Dealer removed dash replaced components and still the problem exists. They indicated all trucks on their lot acted the same way. Guess I am stuck with cold feet.
I found this out when I was looking for information about serviceing both differentials and the transfer case.
So, what pops the fuse?
What doesn't work?
The blower motor relay is on fuse 22 circuit.
The realy controls both the motor and the floor/panel/defrost mode.
One thing to try is to disconnect the heater blower motor resistor. The plug in is close to the blower motor.
It will run the heater motor only on high, but if the relay lasts, then the resistor is grounding.
I think you may have more than just a fuse problem.
Unplugging the resistor will help to determine if it is a resistor problem, which is often a cause of the relay going.
So it is an easy test to eliminate it as the problem.
I appreciate any feedback.
I have the exact same issue. Started yesterday. 2004 F250 6.0.
Feel pretty stupid for something as easy as coolant level. I am going to watch it though, because it's going somewhere.
You can download your manual here: http://www.motorcraftservice.com/pubs/content/~WO3F12/~MUS~LEN/36/03f12og5e.pdf
If you were to read the manual, on page 41, you would learn that if you press and hold the MAX A/C button and the Defrost button together for 1 second, it will switch you from F to C
Good Luck,
Mark
we have replaced the thermostate (with a 195(recomended),This we tested and it works.We also maded sure the water flow thu the heater core-is flowing, (we hooked a water hose to each heater line and water flowed,good),and the flapper controll under the dash is working.The 2 hearter water lines are very hot after engine runs a while.
the heater will not get warm.
you got any ideas we can try?
tom
Took it into the Dealer. System would not hold vacuum.
They replaced EGR Cooler, Oil Cooler, T-stat, misc. Factory Warranty. so far so good.
Check out this web site for diagnostic information and options to repair the system at costs significantly below what the dealer will charge. These guys are the experts on blend door issues on Ford, Chevrolet, and Chrysler and have a bullet proof solution to the problem. link title
thanks in advance Warren K
Has anyone had a similar experience? It is a 1997 F-150 Lariat with 4.6 8Cyl.
If anybody has any other solution to check it will be greatly appreciated.
HeaterTreater
Hey I have the exact same problem. Have you fixed this and if so how mucnh are they wanting
Joe
