Mazda CX-7 Electrical Gremlins
I';m experiencing serious electrical issues. Occasionally all of the gauge needles and cluster lights will go crazy for a second or two. The passenger window will then no longer operate from the driver's side control and one-press up and down stops working.
Most annoying is that all of my radio stations reset back to default and with Sirrus radio that is 36 presets lost.
This morning the only way to start my CX-7 was to use the secret key-fob real key.
I have nearly all options. Anyone else seen these issues?
Pickin' on ya. Seriously, a trip to the service department is in order. I've sneakin suspicion that the security system has gone haywire, but that's only a guess.
If you find out what's wrong, would you care to post back here again?
Vince.
I did tell the dealer "I don't want it back until you recreate the problem" I'll see if that will fly or not.
Ain't true. :mad:
Anyone have any ideas on how to change the clock setting?
Dart Vader CX-7 AWD & Nav system aka NMK
It even states that in the manual.
Go into the Navigation system, configure.
there is a clock setting. press buttons accordingly.
It took a little while, but it turns out to be pretty simple.
Good Luck!!!!!!
My radio lights flicker. It's JUST the buttons for the radio, not the upper dash display or the gauges or headlights... after I've been driving the car a while (at least 20 minutes), I assume when it's gotten good and warm, the radio button lights start to flicker. Nav screen and all other lighting appears to be fine.
Anyone else have this issue? What fixed it? I have the latest PCM Flash (they did it today). Dealer could not replicate the problem (probably because they weren't driving it for more than 20/30 minutes LOL).
Help?
Heck, the thing only has 100 miles on it and this is what I get. My only saving grace is that it is a company car and I don't have to pay for it.
Turn car to "on"
Roll down passenger window (from passenger side) all the way. Then roll passenger window up all the way holding it for 3 seconds.
Repeat on Drivers Side.
From drivers side repeat with both buttons simultaneously.
SUVs and Smart Shopper
my lens melted, I found out after having owned my car for 2 years. I had the original buls from the factory, it appears that the bulbs give off a very high amount of heat and that the plastic utilized in the construction of the lens is brittle and not of able to withstand the intense heat from the bulbs.
Anyways, my brake lights work but the lens melted. As always I contacted mazda but they have turned a blind eye on my complaint.....
any suggestions?
CX7 2008 GT-AWD blue with 55K miles
By the way, I love my car!
