Changes You'd Like To See in the Pacifica
Have an idea to improve the Pacifica? Maybe a bit of a redesign, or added features or gadgets, or maybe just a few additional color choices? Well, this is the place to let Chrysler know what you think would do the job.
I'd LOVE to get one with the same MB engine being used in all of their SUVs this coming year (R320cdi, GL320cdi, ML320cdi).
If the Pacifica doesn't have this option, I'm going to have to do something drastic like spend $57k on the R320cdi come September 2008 when our Pacifica's lease is up.
I think a lot of people would like a 7 passenger version, 2nd row bench and the rear seat. A little more headroom and legroom in the third row would be welcome, but the biggest thing is more cargo space behind the third row.
If it was a diesel, I would plan to buy it and keep it for a LOONNGG time. I also firmly believe the resale on a diesel equipped model would be much higher, so you've got that to work into the math, too. It would also be quite a bit more powerful (and not just that 0-60 kind of power, but the real highway passing power that our pacifica lacks).
Big change needed is a 6 speed transmission and more HP. Of course a Hemi would be terrific.
Also why arent the controls on the steering wheel lighted? I rented a cheap Saturn last weekend and the controls were lit. I bet the lights are in the steering wheel already but they just didnt get wired.
Your request has already been answered with the '07 Pac.
The Chrysler Pacifica crossover could be headed for the scrap heap, if reports from the Detroit Free Press pan out. The paper reports that all work on the replacement for the Pacifica has been stopped by Chrysler. The project, code-named CT, was to make its production debut in 2009. The project could merely be on hold, the Free Press speculates, as Chrysler tries to mitigate its losses this year after a third-quarter red ink flow of $1.5 billion. The Pacifica was an early entrant into a market that is now overflowing with vehicles like the Mitsubishi Outlander, Ford Edge, and Saturn Outlook.
The car has very good ride and enough oomph in the engine. Surely you always want more but it has enough.
The only 'complaint' I have is that this fairly high prized vehicle does not have automatic running lights. I did have the daytime driving lights turned ON (country code Canada) but it just amazes me why it is not standard on all Pacs to have true automatic lights, i.e. the ones with daytime driving lights that automatically change to dark time running lights as the sun sets down.
That is all I would improve by my 4 month experience so far.
Arrie
I wouldn't expect it to be standard on all pacs because the base model is actually a pretty inexpensive vehicle.
What I'm talking about is that this Signature Series that I have does not have any kind of automatic lights as it came, i.e. no daytime driving lights or automatically working head lamps that would turn on automatically when it gets dark. This disagrees with your statement of higher trim Pacs (including the Signature Series).
The only automatically working light now is the daytime running lights that I had turned on by the dealer. That fix is the country code setting 'Canada'. I believe in Canada daytime running lights now are mandatory in new cars so that function is built in all Pacs. They just don't enable it for U.S. market. But it can be as was done to my Pac.
Daytime running lights use the high beam bulbs but with reduced voltage so they are quite dim even in dark. But they are on and make car more visible in daytime driving, which is the whole idea.
The higher trim Pacs as I have should come with automatic head lamps that turn on at dark. Some packages have it but amazingly Signature Series does not.
Arrie
prawie paw
Arrie
I cannot remember if my 2004 Pacifica had autolamps or not. A quick check of the owner's manual should help.
It just doesn't make sense that the vehicle manufacturer does not think that FWD vehicle drivers might benefit from automatic head lights also. It does get dark down south at night time also.
I have a '04 Tahoe and it has totally automatic driving lights. Daytime driving lights are ON at all times when you drive it unless you choose to turn them off. At dark head lights come on automatically.
Some people think it is waste of money to use driving lights during daylight driving as you do not need them to see your way but at the same time these people forget that you also need to be seen in traffic for others to know you are around. Daytime driving light do a great service for this and automatic lights even more when they come ON when the driver just forgets or chooses to turn them on too late.
Arrie
Jay
my dealer still tells me i can't get the DRL's turned on.they say that it is impossible and won't even try it.first they said they would charge $80 and when i said go ahead and do it they said it would be waste of money to try it so they did not do it.never seen a dealer this geneorus(yeah right)they still can't figure out what i need to purchase to get the auto headlights so i got my mirror from e-bay and need to get the stalk and i think i am all set...
I want to see a MAJOR MAJOR Change on how these dealers work
why can't these dealer keep up with what's going on with their vehicle.they should know what is available for their vehicle as aftermarket.
And, the previous poster is absolutely correct about a piston assist hood support rather than a prop rod, especially when a massive/weighty hunk of metal is involved. Save the cheapie odds and ends for the lightest/lowest level transports.
Therck
by the way...the hood is NOT metal but a composite material.
The one thing that's been bugging me every time I drive it since the nice weather started is the fact that there is no auto-up on the driver's window. Now THAT'S a feature I've had in FAR less expensive vehicles.
2. Put back the low tire pressure sensor or have this as an option for ALL the vehicles
3. Use a better GPS program. This one cannot find a place name like McDonalds - it uses the entire USA to choose from. Additionally it goes into "uncharted area" very frequently - not just on new roads. Road names not usually visible on the map, so if you're looking for a particular turnoff its difficult ot find. I've also been routed 10 miles around to take an interstate when the destination is one mile up the road. (No, I'm not in Timbucktoo, I live in NC, USA) The portable GPS systems are much better value.
4. U-Connect Hands free could be improved - it would be nice to shorten the messages from the robot voice - and my call waiting doesn't work, it just hangs up on the first cal whenever another call comes in. I'd also like a button to turn it off so that when a call comes in my kids can't listen in.
5. Placement of the air vents for the middle seats needs to changed - if the front seats are moved back for legspace, the air is blocked by the seat.
6. A more powerful engine option.
7. A pocket on the back of the driver's seat. Putting one only on the other side is chintzy. At least give an option for this.
Other than that, this is a very nice car, its my 2nd.
The problem is that they are not controlled with manual switches, but 'signal' buttons (that always return to off when the ignition is turned off).
Does any one have access to the wiring diagram for the seats and the rear defrost?
I would like to install a good old fashioned manual switch to have both in "on" position and need to find the right wire to splice into so they are 'on' when remote starting the car.
