Subaru B9 Tribeca Engine Problems
in Subaru
Having an issue under the hood of your Tribeca? This is the place to work it out!
All I can think of is the timing chain broke and the pistons hit the valves or something.
That's the first time I've seen that here on Edmunds, not just for the H6 but for any Subaru engine.
-juice
Bob
Jerry
-juice
I now have my Tribeca back after 23 days in the shop. The biggest problem was SoA had a difficult time properly packaging and shipping the transmission. One ended up sitting in Arizona in a leaking package before SoA "overnight" air-expressed another one. My car is back together again and seems to be running great.
It was probably the first time they had to ship a new tranny, so I guess the learning curve applied.
How many miles did you put on the loaner?
Good luck in the future, hopefully you'll have a perfect one from here on out.
-juice
-juice
I say crank the tunes and enjoy the heated seats! :shades:
-juice
If you thought you were getting a luxury car, Subaru isn't it. Look at Audi, Lexus, MB, BMW if you are looking for that....
-mike
If you thought you were getting a luxury car, Subaru isn't it. Look at Audi, Lexus, MB, BMW if you are looking for that.... "
Don't think that LUXURY is the magic word to get your car to start the engine quitely. My 14 years old toyota started quiter than my new Tribeca. Now just hope that noise won't get much worse down the road, or I might just trade in to get a Acura or Lexus (right), or ...
-mike
-mike
-mike
This and more about both lights are in your owners manual, BTW.
-Brian
-mike
-juice
We left on Thursday and put 8-9 driving hours in without incident. Friday we started up again and were able to put about 4 hours on the road before our problem occurred. We stopped for fuel, car was down to about 3 gallons left in tank. Filled up with premium and approximately one mile from the gas station (BP) about a 1/4 mile onto the freeway the Traction Control Disabled light and Check Engine lights came on and the engine started to stall. I pulled over and the engine died. Would not restart.
Subaru Roadside Service sent a tow truck and we were towed 54 miles to the nearest dealer. Got there 10 minutes before they closed and had to work to get anyone to take a look at the vehicle before Monday (when they said they would be able to get to us).
Scan tool showed misfire on cylinders 5 & 6. They were able to get the engine to start and limped it into the shop. Everyone's assumption was bad fuel due to the timing. Saturday they drained the fuel and didn't find any water or debris like we thought may occur, also tested to ensure it was not E85. They put in new fuel and started the car. It seemed to idle fine but the engine misfires under load, now cylinders 2, 5 & 6. They are going to look further tomorrow (Monday) and see where the diagnosis leads.
I am guessing a bad ignition coil now that fuel has apparently been ruled out. Any ideas? Anyone heard of anything like this before?
This is my sixth Subaru and I worked at a large Subaru dealer for 9 years.
I know they use E10 around most places, maybe you did get a poorly mixed batch?
Problem is, the ECU probably tried to adjust to that bad fuel, and now with a new tank it's probably trying to re-adjust. I'd reset it by pulling the battery, but it's in the hands of the techs and I'm sure they'll try that.
Hope this gets sorted out soon, sorry 'bout your trip interruption! :sick:
The bolts that were used to put the AC compressor together on my BRAND NEW car are completely rusted -- see pictures below.
http://picasaweb.google.com/palpatov/ACRust?authkey=3etmLST3cKo
Is it just me or do others out there think that rust in the engine compartment of a brand new car is completely unacceptable?
p.s Moderator, since according to the dealer, "they all do that", can the rust issue be made a separate topic?
Seems reasonable to me to get that cleaned up as rust only gets worse and you certainly do not want the bolts snapping the first time it is taken apart for a timing belt change... :sick:
Having said that, it's just surface rust on a large bolt, so I doubt it'll ever matter beyond the ugly aesthetics.
That's the first place to look.
When you turn the key to the on position, do you hear the fuel pump priming the pressure? It should sound like a "whirrrr".
-mike
Motorsports and Modifications Host
Listen for the whirrrrr when you turn the key before you try to crank it, just to be sure the fuel pump is still working.
-mike
Today - the call from the dealer is Subaru is ordering a new short block. To which I responded, "do we know what caused this?" Dealer - "We don't because Subaru wants us to ship the short block to them to inspect themselves and they don't want us breaking it down." I should be up and running on Friday this week or Monday of next week.
Questions - Would anyone else be concerned about them replacing the short block and not the entire engine? Has anyone else heard of anything similar to this? If this is an anomaly - should I buy lotto tickets? Would you request SOA to warranty the 3/4 new engine beyond the 5 months 10k miles I have left on my warranty? Is this a reasonable resolution to the problem?
Nick :sick:
I agree this is rare. The H6 is very robust, in fact this is the first catastrophic failure of this type I've heard of on a Tribeca.
FWIW, as long as they cover it under warranty, I'm happy to see that Subaru is actually taking the engine back for analysis, to determine a cause.
