Volvo S40 Brake Problems
I have a 2006 S40 T5 with 4200 miles on it which has developed a squeal from the rear brakes when backing up. I’ve had the car in twice (with a 3rd looming); and each time the pads were replaced, along with the rotors this last time in. The dealer can’t seem to find the problem, and I've done some searching around online and have found that while not widespread, the problem is not unique to my car; however nobody seems to have been able to identify the cause. Theories range from brake dust to the chemical make up of the pads themselves.
Has anybody heard of this problem and figured out once and for all how to correct this?
"The problem IS the make-up of the pads themselves. Volvo knows of the issue and is working on a fix, but there isn't one yet. The problem shows itself primarily in the rear brakes when backing up, and the severity varies."
Has anybody come across this? I'm wondering if the pads from the Mazda 3 would work since the cars share the same platform and many underpinnings, or if they’re the same pads used on the S40.
If this doesn’t do it, I’m looking into a set of aftermarket ceramic pads (providing it doesn’t void the warranty).
Other than the brake noise, the car has been bulletproof, so hopefully (knock on wood), I won’t get to your situation because I absolutely love my car.
I am taking it in again this Sat. for an oil change and again I will address the issue with them. I believe I am still under warrantee but I tell you right now, with the stupid issues I have had to deal with? I want to trade it in already! I have had it! I expect so much more from a Volvo!
Second of all, the radio sometimes doesn’t work. It is on but nothing can be heard, then I park it and later I go to drive it and the radio is working, the window to the driver side will go up and then down it will not stop in the up position, and then it will be fine. One day I got in put my seat belt on and the beep noise when you have the keys in the ignition came on and I drove like that till I got home and then parked it. The next time I went to drive the car; it didn’t do it any more.
Just about two days ago, I stopped at a mini mart, put it in park it was running and a co worker was in the car and told me that the air conditioning came on as soon as I got out of the car, by itself. She was a little taken back. So on and so on .I would think it would be a long process to declare this auto a lemon but that is what I think it is at this time. So instead of going through all that hassle I would rather go to the Mitsubishi dealer and trade it in. I have owned a Mitsubishi and never had all the problems that I have with this Volvo. Volvo let me down. They are not doing any thing about my car because they know it will be a matter of time when it will be out of warrantee and then they can start charging me good! Well? I was looking into Audi?
Bad idea! If you read the write ups in this site just about all the people that have had the A3 and all the problems they have had? Well lets just say I am not getting an Audi either. I am disgusted at the luxury manufacturers who think that the name speaks for itself and the quality can be ignored. Well? I guess I have to thank each and every one of you for sharing your experiences on this forum because we all work hard for our money and why should we give them away on poor quality? We disserve better, I disserve better don’t you?
The issue itself does stem from the pads themselves. There was a tech notice on them when the redesigned S40 first came out. A new type of pad were put on that was supposed to correct the problem. However, my car is a '06 and was supposed to have had the new pads from the get go. It does, but still made the noise. I don't have the service order in front of me to reference everything, but I do know one thing they did was shave the edges of the pads and that worked. Every now and then they still squeal, but only if they're wet or dirty from the car sitting for a few days (which is to be expected), but not since last November have I had the problem.
Other than that, the only problems I've had were the car would stall right after start up if it was cold out (it would always start right back up the 2nd time). They fixed that the first time with a computer download. Also, the ventilation system will sometimes make noises that sound like an owl hooting (!!). That is also a problem that I've been told a few times can be corrected by a computer download, but I've not had the chance to take it in to have it done (in all honestly, I don't notice it that much but it drives my friends crazy.)
I did look at the A3 but I'm not a fan of Audi's new designs. The interior of the A3 looks nice, but I think the rest of the new interiors are very cheap and '80s GM looking.
Again, I hope you get everything worked out. I honestly can say that I absolutely love my car and wouldn't hesitate to buy another Volvo. Good luck!
My car has 12,500 miles on it and the squealing is starting to come back so I'm taking it in next week for it's 12k service. My tech has already told me they'll replace the pads and do the same thing they did last time to solve the issue. I think it is an ongoing problem, but my dealer (at least) has been more than willing to make sure I'm satisfied.
jsnapp
I thought they all went away with the Audi 5000 :confuse:
buying a 2010 T5 R-design S40 this month. haven't read about continuing brake issues this this puppy...
any 2010 T5 R-design S40'rs out there?
Is there another adjustment somewhere else?
I have recently experienced the exact same accelerating while breaking issue with my 2003 Volvo S40. I find it happens if I'm going over a bump in the road and at the same time have to break. I also have found it when I suddenly had to slam on the brakes. Please tell me what you were able to find out about the problem and if it was fixed. Thank you.
