Pontiac Vibe Engine Questions
Having an issue under the hood of your Vibe? This is the place to work out a solution.
We had our first "blast" of winter in Michigan this morning, and I noticed that it took quite a while for my Vibe to reach normal operating temperature, compared to other cars I have owned. I also noticed that when I stopped at the gas station and left the car running while I was inside, when I came back out, the engine temperature gauge had dropped quite a bit, back down to about halfway where it was before. As soon as I pulled away, it quickly moved back up.
Is this normal? Should I have the cooling system looked at? I haven't checked the coolant level since buying the car (June), so would low coolant cause this? I'm just curious. I've never seen a gauge drop like that in a car that is already at operating temperature except on days when it was maybe like -20 degrees with a fierce wind. It was only about 25 degrees above this morning. Any insight would be appreciated. Thanks!
I think it's just the bumper-to-bumper that's voided after it's re-sold.
I looked at a 2004 Matrix at a non-Toyota dealer, and the powertrain warranty was in effect. Also, if you look at a CarFax report, you'll see that it estimates the remaining life on the warranty. As CarFax is a resource for buyers of used cars, why would it do this if the warranty was invalidated beyond the initial owner?
Good luck with this, ChuckB - I'm sure a number of us are curious as to how this will turn out.
For those of you who haven't read through the forums, I'm one of the guys with the mysterious "warm restart" issue on my 2005 Vibe. The car always starts great, except when the engine is warm (i.e. run into a store, come back out, car doesn't want to start).
Well, today it didn't want to start period. Turned over fine, but the engine just would not catch. Maybe whatever's wrong will fix the warm restart problem also. I'll post what it is for others who have the same issue, if it fixes it.
I have no confidence in "Toyota" reliability after my experiences with this car. I think next time I'll buy a Honda. I have no desire to give GM any business either. :lemon:
Here is the link:
http://www.infotraxx.com/searchPublic.php?Year=2005&Make=PONTIAC&Model=VIBE&Subm- it=Find+TSBs
I like my PV too..but I miss my Toyota.
Anyhow, this is the second time this has happened. A check engine light about a month ago was traced to a "chewed through" crankcase harness, which they replaced under warranty. However, they told me then that they wouldn't cover anything else attributable to the rodents.
Well, the reason it wouldn't start is because the pests chewed through the entire crankcase harness and then some, so they're still trying to figure it out - on my bill. It appears my insurance company is going to cover it - or at least some of it, however, but I'll be without a car for more than a week. They have to take out the alternator and the radiator to get to the crankcase wiring harness apparently.
I've lived in the same place for 15 years, and although I have seen some minor evidence of rodents being in my vehicles in the past (chewed nut casings, etc.), this is the first car that they've done this kind of damage too. Unbelievable.
I told myself on the one hand I should be happy, since now it appears I don't have a lemon - I just have pesky animal neighbors! But it sucks royally having to go through this, and I sure hope they find and replace everything they've destroyed and get everything put back together correctly. The dealer's been real good about it, which is amazing, considering how most dealer's are less than sympathetic about these kind of things.
So, word to the wise. If you live in the country or in a rodent-prone area - BEWARE! I'm still trying to figure out what I'm going to do to keep them out of the car when I get it back. Any ideas? I'm thinking about parking over a tarp covered with mothballs... :surprise:
http://www.dreamingearth.com/natural-pest-control.htm
Mouse Away provides all natural rodent control - made with our exclusive formula that combines pure Peppermint Oil with pure Spearmint Oil in just the right combination to provide maximum repellency. Mouse Away does not harm rodents (mice) at all - they simply hate the smell and move away ASAP. These Essential Oils of Peppermint and Spearmint smell so wonderful that it seems almost a shame to use them for chasing away mice and other rodents but, Mouse Away WORKS. Our friends who live in the high mountains had a terrible problem with mice eating the wiring harness in their car. They tried everything with no luck but, finally, they gave our Mouse Away a try. They just sprinkled it around under their hood and two days later - no more mice. Also, we've sold quite a bit to folks living in the Bronx - so it works on big city rodent problems too. We've had customers who use it in cars, campers, houses, basements, kitchens, warehouses, farms, barns, etc. (one farmer in Maine buys a 5 gal. pail each year).
Note: don't get Mouse Away Concentrate or Mouse Away Spray on painted, varnished or other finished surfaces or on plastic.
http://www.sdreader.com/php/ma_show.php?id=266
[holds a home remedy note at the bottom - for the cars]
I was told moth balls help too..but since we live in a "bird protected area" we're not allowed to put them out...odd cause pest chemicals are okay.
I guess forewarned is forearmed!
I am assuming that a Timing Chain would last much longer than a Timing Belt, but I would hope this would start an interesting discussion.
I thought I remembered reading in this Forum that GM had issued a TSB for the 05 Vibe regarding the warm restart problem. I did a search and found information about a Toyota TSB for the Matrix, but that's different.
Anyone know what the TSB was or where I can get it? I took the Toyota one in several months ago and the dealer ignored it. They aren't interested in "non-GM" TSBs.
It may have been in another Forum where I read about the GM TSB. If I remember correctly, the fix involved changing the Powertrain or Engine Control Module, or perhaps reflashing the software?
Any help would be appreciated. I'm near the end of my warranty and want to get this problem fixed before my warranty is up. Thanks!
Here's a link that might help you as well.
Two quarts is about a half of your oil change, and it's not a small oil consumption IMO.
Looking into the future, if there are no external leaks (and there are none), and if there is no oily slime floating around in my coolant reservoir, can I start assuming it is the rings, or are there other possibilities?
gurabita: I am one long time Corolla fan who is disgusted with the Vibe. It has been said by many before that it is the worst car to come out of Nummi and I could not agree more. The problems have been too numerous to list here. Mechanically, it has been reasonably sound until my Houdini disappearing oil trick. It certainly was the worst purchase I've made in quite some time. I'll run it into the ground and then it has an appointment with the bottom of a cliff.
I have not heard of Toyota engines having this problem. However, I did hear of GM 3.4 V6 engine (GM Minivans 1997 - 2004)problems where a thin gasket and DEXCOOL ate into the Gasket near the intake manifold causing coolant to get into Engine Oil compartment. Have it resolved ASAP.
I also know that some were successful in using Coolant LEAK Material to prevent Coolant leaking to Oil side. It may not work if Oil is leaking to Coolant side.
Have you been using GM DEXCOOL instead of Toyota coolant? DEXCOOL is know to eat into Gaskets.
This may mean a engine head gasket replacement and using only Toyota coolant for Toyota engines going forward.
Comments from others?
What has been your experience?
As for the Vibe, it has been a fit and finish nightmare; very disappointing coming from Nummi. However, I believe the Vibe's engine is essentially a late 90's Corolla design, and I don't expect troubles from those good production year power plants.
I'll be curious if the car passes emissions next year, despite the lack of any visible smoke.
Thanks as always for all your help.
It sounds like you have oil getting past a seal or gasket somewhere even though you have no visible leaks. Synthetic oil may have been your problem. I know there is article after article stating that synthetic oil does not cause leaks. But there is also a lot of claims that while it may not actually cause a leak, it does have a way of finding exisiting ones that dino oil does not.
