I purchased my Spectra5 when in reality I was shopping for a Toyota (again). I have not regretted buying the Spectra 5.
Outstanding value and pricing. Thought-out practicality. Good fit & finnish. Quite ride under normal conditions. Good back seat leg room. Great body styling. Great driving dynamics on the twisties & turns.
The so-so news:
I need to be aware of tire stops or curbs when parking the vehicle. The paint is a little thin. The engine is constantly searching for the right gear when going uphill.
The seat belt chime is a little annoying when I'm cleaning the interior and listening to the CD.
The engine looks better without the funky plastic engine cover (but I appreciate it as a sound barrier).
The Twilight Zone news:
At 3,000 miles, I took the Spectra5 in to Glendale KIA dealer (L. A. Calif.) for:
1) Oil change (I know, I know).
2) Slight vibration on the right front tire.
3) The car wants to pull slightly to the right on the open highway.
The oil change went without drama. But when it came to the alignment and balance, Oh My God.
The service manager tried to convince me that the steering pulled to the right because the pavement was paved at an angle for rain run-off. If that's the case, it should pull to the left. And my improper tire pressure (28 front & 30 rear) is the cause of the right front vibration.
Needles to say, I felt uncomfortable with Glendale KIA's service manager's incompetence and left in haste.
At 8,000. I took the Spectra 5 to El Monte KIA dealer (hoping for service) for oil change and right front vibration. Oil and filter changed, tire balanced, life is good. All went well until I drove out of the dealers driveway. It felt like they accidentaly removed the struts. I checked the tire presure (while still in the driveway and tires cold). Lo and behold, 55 psi on all 4 corners. The reason I say 55 psi is because my tire guage only goes up to 55 psi. I will not return to El Monte KIA.
In retrospect:
Great car for my needs and purpose. Great price and finacing. Better looking than the 08 model. The light window tint all around on my red KIA looks and feels cool.
Attention KIA Motors USA, I thuroughly enjoy my Spectra5 for what it is and how it gets me there. KIA Motors in Korea make a great product.
Dealers in L.A. County are:
1) Hiring high school grads as automotive mechanics.
2) Don't understand the "Return business" credo.
3) Have no intentions of resolving normal automotive
issues (under warranty) in an effort to reduce cost.
KIA Motors, Irvine, USA, wake up.
Enjoy the ride. HV
I have a 2002 Kia Spectra, automatic transmission, 47,000 miles. I have the same problem. In the morning I will try to start the car and it will sputter out and die. Then if I try to start a second time, it works fine. Once warmed up the problem goes away.
I am going to take it to the dealer for warranty repair. I had a similar problem happen to a Saturn SL a couple years ago - on the Saturn it was the "Cold Start Valve".
If I find out what the cause it, I will post it here.
Result: I took my car to the Kia dealer to see if they could diagnose the problem. The tech discovered that there was a "software update" for the ECM. They uploaded the update and the car runs fine again. They charged me $90.00 to diagnose the problem and upload the software. I feel a little bit "had" because they seemed to know what the problem was immediately - and they seemed to know that the software would fix the problem. I am going to research Kia software issues now and see if there were any recalls/updates. I'll post my results when I find them.
I don't understand why the software would have been fine and then suddenly one day go bad. I supposed that it is like Windows that can become corrupt for any number of reasons at any given time. I hope it doesn't happen again.
Please disregard what I wrote above. The dealer said they fixed the problem, but the very next morning, the problem happened again.
I called the dealer and they said I could bring the car in again at no charge. I left it with them overnight. They said they can't find any problems at all. They even said the car started up with out stalling - I find that hard to believe. The only rational way I can see the car starting properly for them is if the mechanic has an assistant who goes and gets the car from the parking lot. This assistant would experience the car stalling on the first start. However, the mechanic might not, since the car would have already been started once.
At this point I am going to give up, either the dealer is lying, incompetent or the problem really doesn't occur for them. I will just start it twice every morning before I leave. Eventually, it will probably not want to start, but I'll cross that bridge when I come to it. I've also decided that I will not buy another Kia when this one dies.
Where are they and what dealership did they visit?
What year is their car?
What was the issue?
How long did the repair take? How about total experience time?
Who gave them great service? (Name, contact info?)
Was the problem satisfactorily corrected or, if the owner had to compromise, does it seem fair?
I feel this kind of information would be really, really helpful to new car owners and two those who are beginning to experience warranty-covered issues.
Just my two cents. Thanks, mods!
The dealership is very SHADY. Dorschel KIA in Rochester, NY likes to schedule your appointments, and then do absolutely no work on the car. This has happened to me twice. If I have an appointment, I expect work to be done on my car, especially a simple oil change. The other problems with Dorschel are the heat sheild issue. According to my maintenence record, the heat sheild has been removed 3 times, not replaced. They have been charging me money each time and will not own up to their mistakes.
Does anyone else run into these issues?
Another problem im having is that when i go up hills i lose horsepower example i will be going 50mph as soon as i start up the hill i drop down to 20mph and i cant get speed built back up til i go down the hill then my gas goes down alot.
IMO KIA's just suck, noone knows how to work on them and as I stated before they give you every excuse not to honor the warranty.
Since the reprogramming of the transmission my sons KIA is running fine although check engine light now stays on....
So far the car has been a solid performer for me and I put almost 900 miles a week on it.
I've replaced the stock radio with a new pioneer head unit and installed an 8 inch subwoofer in the back.
Everything works on the car as it should and it appears to be holding up well under heavy daily use. I average about 900 miles a week on the car.
I should mention that paid $9100.00 after trade and that it is fully loaded minus ABS. I opted for the 5 spd. manual tranny.
We found with one of our vehicles that the oil drain plug as lose after an oil change possibly that is where the lack of oil came from suddenly.
I would say find a new dealer to maintenance your vehicle. :shades:
The check engine light came on and I hooked a OBDC-II
to it and the code report it as an EVAP (small) emissions control problem.
I owned a (2006)Kia Spectra for about 4 months until I got it totalled in a car accident(not my fault). Decided to go
with a Spectra5. I loved the old 06 spectra. Had no problems
with it at all. In four months I put on 15k miles!! Followed
KIA manual with out fault.
Now I get the check engine light under 1k on the Spectra5 !!!
Checked Gas cap and check under hood for obvious hose or loose line problems.
I love the car. I choose the Manual Tranny with Electric Orange Color. It is great !!!
Bringing it to dealer first thing on monday.
troy
I have needed a new gas cap on one of my two Kia's before, too. You're under Warranty and if you feel more comfortable taking it in, do that, and let them check out your gas cap(among other things, if they need to). For some reason sometimes they're not made right and don't provide a tight enough seal for you.
I think you'll like your Spec5 too and that is an awesome color choice. Do report back what you find out, OK?
they pulled the car to service bay.
i asked for all paper work.
tech reported that they "re-tightened" gas, drove car.
and "cleared" on-board computer.
if problem re-occurs then i will re-post. but i did
exactly what the tech did, except i did not "clear"
the computer.
The dealership only had my car in the service bay for 8 minutes. plus 4 minutes for the test drive. I was out in
under 15 minutes !!!
Way to go KIA of Baton Rouge !!!(Allstar KIA)
THINGS I HAVE LEARNED -
GOOD THINGS
#1 - Our sales person Tara wanted to put us in a alternate car right away !!!
#2 - Tech talked straight forward to me.
#3 - Tell someone your "keeping" a folder of incident
and start writing names down AND the wheels of progress
start moving faster.
BAD THINGS
#1 - Service guy(RYAN) does not know SH*T. so IMHO
dont even talk to these guys. All they do is paper work
and thats it.
#2 - KIA does not want a responsible "buyer", such as myself
to have access to "diagnostic" print outs.
WHAT I WOULD LIKE TO SEE CHANGE ?
#1 - I really wanted that ERROR LOG printout from the diagnostic computer to compare to my own readings.
#2 - New Service Guy. Ryan sucks.
To get that error log would be nice. It's possible it won't tell you much of anything, though. But to be able to read it in it's entirety would be helpful. Your dealer should be interested in helping you. After all, you've spent a lot of money on one of their cars. You deserve to have a great running rig with no problems. Keep up the desire to probe for more information.
Good fortune to you and report back how your check engine light situation goes, OK? I remember those lights coming on and I felt better driving my Kia's when that dumb engine light was off. What's weird is it's for information and the car always ran well even with that light on every now and a then.
i did that as well, but they "reset" or cleared the computer. i did not.
i guess they are ruling out the fact that its the cap.
and if it happens again, then replace cap comes next. i guess.
one cavet of information. i cross checked the ERROR code "(SMALL) EVAP Emissions Control Leakage"
and found out that this problem commonly
occurs when GAS CAP is not on properly OR it could
be a "LEAK" in hose OR the EVAP unit has been contaimenated
with GAS.
basically the last one mean that a person has "topped" off
their gas tank until it is completely full AND the excess gas has found its way into the EVAP unit.
Apparently a RONDO buyer had encountered this problem before. I checked the forums for the EVAP error.
I knew about the excessive topping off but never knew exactly why or what it damages. So its good to know.
And should be on the TIP of every SALES person's tounge when they talk to a customer when they purchase a car.
troy:)
sequence of events -
1)Left shop on Monday.
2)Filled up gas, but did not overfill.
3)reset tripA milage meter.
4)car would not start outside of daycare.
5)car had to be jumped started !!!
6)found that battery cable to battery post was loose.
7)checked mileage. Car has only travelled 111 miles
and used 3/4 a tank of gas !!!
8)Check engine light came back on !!!
8)set up appointment with service manager RYAN.
He reported that he will need it for a few days.
He reported that he will hook it up to a SMOKE machine.
9) A pit has formed in the pit of my stomach.
I knew this was not the end of the CEL problem.
troy:(
A smoke machine?
i put 12999 miles on it in those four months.
The tires showed 73% thread usage. The insurance people
measured the tire tread depth. So the tire life on your tires is about right.
Must have been one owner ?
but sounds like a sweet deal. really. I trust the regular Spectras, but the Spectra5 is another story. I am having headaches with the EVAP system in my BRAND NEW 2007 Spectra5. Had it in to the dealer twice in One week.
Two more times and I have a lemon law case.
They mentioned a smoke test, but all they are doing is test driving it.
BAsically it is getting bad gas mileage. 130 miles to the tank. And the Check engine light comes on about 100 miles into a fresh tank of gas.
They have got me a rental car, but get this. The first time they fixed it, they disconnected the battery and cleared the computer memory. The tech did not tighten it, so next day later they car would not crank after driving to day care. Car had to be jumped off and thats when the battery terminal was found loose !!!
People, WATCH YOUR CARS !!!
But they are "test" driving and waiting for the
Light to come on AND then fix it.
But what the difference if the light is already on ?
Are just came on ? BTW, Lemon law in my state says
they(KIA) has two more chances at fixes this problem.
Else they can give me a NEW car(since mine is BRAND NEW)
OR buy mine.
Honestly, I am having second thoughts about this SPECTRA5 !!! :lemon:
http://www.kia-world.net/index.php/2007/08/14/kia-releases-2nd-teaser-for-frankf- urt-coupe-concept/
Very exciting!
The CEL may not come on, but the car only gets 215 miles per tank now.
live and learn.
troy:(
Any suggestions?
I've owned lots of Hondas and was considering a Honda Fit. But I came across a 2005 Spectra5 w/ 20K miles at a good price. Still has factory warranty.
After test driving both, I prefer the Kia.
Kia kind of "scares" me because of a poor reputation in their early production. And it seems maybe their warranties aren't worth the paper they are written on? I've read complaints about Kia not standing behind their cars and honoring their warranty.
What do y'all think? Would it be a mistake for me to buy the used Spectra5 instead of a Honda Fit? I was certainly impressed by the Kia. But if the previous owner used the "wrong oil" or missed a service by a few miles, I fear they will void the warranty.
Then again, if these are good, dependable cars, I won't need it!
So, come on, Kia Spectra5 pilots... talk me into one!! Or I'll end up in yet another Honda
Have you had problems with yours? Major repairs?
Shannon
Rob
Last year, I bought a 2002 MINI Cooper and the tranny failed at 34K miles. 4 months out of warranty. "Tough sh**" was the response I got from MINI. Even though I found multiple posts on the internet of the same failure. Even though they dumped the Midland transmission after 2yrs and replaced it with Getrag transmissions. So, why did MINI tell me, "we've not had any problems?" Why did the dealer tell me, "we haven't had any transmission failures here?" If that were true, why go to a new transmission?
By the way, Toyota has done the exact same thing on their 03-04 Matrix transmission that were failing right and left. Acting like they know nothing about it. But, hmmm... for some mysterious reason they put a new tranny design in the 05 Matrix. Wow, imagine that. They just "randomly" decide to fix something that isn't broken.
It's time we stand up to these car companies. There is simply no excuse for a drive train or engine to fail at these low miles. I don't see how they can defend it even at 100K miles. Cars should last at least that long.
I can accept that poor engineering happens. I don't condemn them for that. I don't expect perfection. What I DO expect is for them to face up to their mistakes and make it right. I expect them to stand behind what they sell.
If I did business the way they do, I'd be out of business.
I was a loyal BMW / MINI fan. I will now do my best to spread the word that they wouldn't fix my car for me. I will not own one again. Even though they now have great reliability records.
Maybe we figure out a way to not let them get away with this any more.
Shannon
P.S. BMW if you're reading this, I own a Porsche now. It's 20 years old and it is a better machine than you can ever hope to build. So take that!!!!
I noticed today after looking through everything that i have absolutely NO previous maintenance records on the car. It has 20,000 miles on it. I dont even know when the oil was changed. So Car Max was telling me i had a warranty from KIA, but really they should have told me i dont because the previous owner provided no records?
Is there any evidence that the 2008 Spectra EX is NOT at the same build quality
as the 200 Elantra SE? Im considering purchasing the Spectra EX for a long term
car of around 150,000 miles.
I would love your thoughts!
Here is what I found out:
I talked to Kia this morning, I was really upset. They told me that they should be able honor the warranty as I am starting at 18, 600 miles, even though there are no records. They also gave me the number of the dealership in Texas where the car was purchased so that i can attempt to get any service records kept there. They also told me that if I start the severe maintenance now and save the records of everything i should be fine, that my car is under 19,000 miles so there was not much to do in that period of time anyway. They also said that if the fluids are clean and whatnot, it will be obvious enough that the car was being maintained to their satisfaction.
She did say that they can still refuse however if something goes wrong and there is some evidence that maintenance was neglected. So I guess they can do whatever they want.
Car Max will be giving me their records, which i demanded today, and hopefully dealership in Texas has something for me too.
But in any event, at the worst I will have to fall back on Car Max's warranty to 94,000 miles. I have to pay a deductible each time i get a repair, $50 at their place or $75 at any state certified mechanic.
