I hardly think an insurer would deny a claim over 35 psi in the tires. (Although they would like to.)
Keep in mind 32 is recommended by the manufacturer, but the max inflation pressure on the tire is probably 45 or 50 psi. (It's printed on the sidewall.)
A few extra psi, as long as under the max inflation pressure, is nothing.
Over-inflated tires, where they suspect the increased pressure, along with the load inside the car, coupled with driving conditions, is used every day, and in hundreds of lawsuits, to deny coverage. And they are quite successful in doing so.
No matter what it says on the tire, for they are indeed used for many different vehicles, owners are always instructed to use the inflation posted on the plate located inside the drivers door frame.
I know you will never be convinced, and if you believe it is better suited for you to increase the pressure, go for it. If you don't believe me, ask Toyota, Ford, GM. All will tell you the proper inflation is what THEY say, not the side of the tire.
Absolutely! The tire is designed for many applications for cars of various weights. The maximum pressure on the tire is just that, a limit before the tire will fail. It has nothing to do with the safe design pressure for the specific vehicle.
To be fair, this is a matter my old man used to curse about.....so for 30 years that I am aware of, people have taken their cue (falsely) from what is printed on the tire, and not the owners booklet, or vehicle sticker, so JPMiller isn't alone.
I have read over the years many a horror story of mayhem resulting from tire failure, side wall failure more specifically, resulting from owners changing the inflation pressure by as little as 5 pounds cold. On a hot day, at even moderate speed, rounding a corner can have terrible consequences. :sick:
I will quickly believe your assertion when you provide some documentation.
No doubt, significant tire over inflation is potentially dangerous. Still, the burden of proof would be on any insurer seeking to deny a claim based on over inflation.
The recommended inflation pressure is a compromise, depending on vehicle load, average speed, and road conditions. My '92 Camry, for instance, recommended 26 lbs for normal urban driving and 32 lbs for primarily freeway driving, or when the car was carrying more weight.
And in the most famous cases of tire failure--Ford Explorers--while tire under inflation was a significant cause of the failure, the tire maker and manufacturer received most of the blame, and liability.
I doubt tire over inflation of 2-3 lbs changes a car's handling characteristics enough to matter much, but I will be persuaded by any facts to the contrary.
I have 90,000 miles on a Ford Explorer. I did do research on the tires (afraid for my safety) and I found that Firestone and Ford compromised and determined that safe tire pressure would be 30 psig. I believe Ford wanted it lower and Firestone balked. My opinion is that the Ford had mnore to do with most wrecks than the tires, but that's just my experience and opinion. While underinflation can cause tire failure, high pressure (as little as 34 psig) on the 01 Ford Explorer I drive for work absolutely makes the car so twitchy that it's scary at interstate speeds.
Granted the TCH will not get twichy at 40 psig like an SUV. But the contact patch of the tire to road will be diminished and if you live in an area with hills and rain I would think twice before going to extreems on high tire pressure.
After 13,700 miles the difference in 39.5 mpg (what I get) and possibly 41 mpg (might get with overinflation_debatable) I would have saved less than $35. Not worth it.
Ok, since I started the discussion under title "What an awesome vehicle the 2007 TCH is... with great MPG.... ", I take responsibility and have come to conclusion that the best way to care for the tires is to absolutely follow the vehicle's manufacturer suggested tire pressure. The reason of keeping my tires 3 psi above normal was actually more of an assurance that my TPMS is functioning correctly after the toyota dealership had 2 times to adjust/reprogram the 7 digit ID code (valve transmitter) into ECU (loooong story) and got distracted and let the uneven air pressure the dealership had put into my tires giving assurance to myself that the TPMS warning light is fixed... no more -- all my 4 tires are back to 33 psi and with the cold weather it will be down to 32 psi.
Btw, I have emphasized to follow the correct tire pressure under "Toyota Camry Hybrid Driving Tips & Tricks" discussion title in post# 67.
Also, after lowering the tire pressure I felt better handling of my 2007 TCH on the road and especially in the rain.... what a truly awesome vehicle the 2007 TCH is... -- happy HYBRID TCH driving --
Tires ARE overinflated for transport, to protect from tire "flat spots" and probably several other good reasons. I do not know where you get the information that the presure is set at 90 psi. I doubt that is accurate. Probably closser to 45 or 50. IMHO.
I've got a trip coming up and I'd like some extra trunk space. Has anyone ever increased trunk space by removing the spare and adding a can of fix-a-flat and a AAA card? This is something Miata owners frequently do and I was wondering if there's a downside of doing it with the TCH. I think I've heard the Prius doesn't even have a spare.
That fix-a-flat and the AAA card would work fine if it's no problem for you to wait a couple of hours to get towed and then worry about finding a tire store open at zero dark thirty in the middle of Timbukthree in the event you have a blowout or a ruined tire for whatever reason.
Personally, I'd rather pack less crapola and keep my spare tire.....
I noticed a new thread on the "other" forum about tires cupping and making noise. It was mentioned that mis-alignment is not an warranty issue for the tires. That may be so for the specific case where the guy has 19000 miles on his tires and has never rotated them. I had bad experiences with tires and alignment on my 2003 350Z that caused me to HATE that car. Almost had the same issue on the TCH. Here's what I have noticed and observed.
1) My tires have always been rotated at 5000 miles. 2) My tires were beginning to cup due to misalignment but the "idiots" that rotated my tires did not mention this 3) When I noticed it I was still under 10,000 miles and brought it to the dealers attention. By showing him the cupping on the rear tires (occurred when they were on the front with less than 5000 miles) I was able to demonstrate that it was misaligned from the factory and realignment was then performend under the warranty. 4) By doing it early I was able to live with the mild cupping for the life of the tires. 5) Without rotation, cupping will only get worse and possibly unbearable. However your rear tires may last through another set of front tires. (I prefer even tread on all 4 and replace them as a set) 6) Cupping, when extreem (like my Z Car) can cause very loud noises and eventually is quiet noticable even in the feel. 7)The Bridgestones suck. With one alignment and rotation at 5000 miles mine were absolutely worn (evenly) at 23,000 miles. However I was in a tires for life program (that's why I did the rotations and annual alignement)and the dealer put the same tires back on. I can't complain since they are free, but it would save them money to have put something else on as I'll be back next year wanting another set.
All of you with a TCH, at least the ones from Japan need to inspect your tires early and frequently for misaignment problems. It's easily fixed and you don't want to have to live with noisy tires until they wear out. Actually that's my advise for any of you with any car. Don't count on the mechanic to tell you these things. Running your hand lightly over the tread can easily detect any feathering or cupping that is starting. Catch it early and it's not a problem.
Our above car has 20K miles on it. the rear tires are wearing out very quickly!!! Our mechanic is wondering if the car is just too heavy in the [non-permissible content removed] since it is a hybred. Any others out there with similar problems?
This is still a FWD car and I don't think the batteries would add that much weight to cause this problem. Are you rotating at 5000 mile intervals? If you have the bridgestones then significant weat at 20,000 for rotated tires is about where mine were going bare
I have ~30k on my TCH and my tires are almost bald. I was told by the dealer service technician that because of the battery weight, the tires on TCH wear out faster.disappointing.
Sorry, if this has been posted somewhere already but my quick search didn't get a hit. So, I'll appreciate if you could recommend any good tires to use .... I am definitely NOT going to buy a Bridgestone...it was a bad choice by Toyota....I'm disappointed like others on the list. At close to $175 a piece, they should take you well past 35K miles..I think...I must admit it's a layman's guess...actually probably more of a wish
I'm suffering from TCH early-tire-baldness syndrome too. Followed tire-rotation at 5K advice....although I missed the alignment "warranty" limit (at under 10K) and had to pay for it at ~20K miles....it was OFF...Toyota mechanic said not by a whole lot but I'm not sure...these were the readings on the report: ================ Front Left -0.13 degrees
Front Right -0.15 degrees Total Toe: 0.03 degrees
Rear Left 0.30 degrees
Rear Right 0.28 degrees
Total Toe: 0.58 degrees ========================
Anyway....what tires should I use for this car? .... I was thinking Dunlop or Michelin although on my little Acura I have used Yokohama with no complaints for the last two tire changes (~5 years)...I think that is a good tire for around a $100.00.
I have been riding on Michelin's that came with the car... they have worked out great. What I would do is go to tirerack.com and read the customer reviews based on the area you live. It's a really good site with great prices.
My UPS guy said that he even delivers tires from them to auto stores. Beware, if you do order from them expect the tires within 48 hours... their service will blow your mind. Good luck.
My car was a May 5th 2006 delivery (an early one). It was out of aliggn from the factory and since I was maintaining it at the dealer on 5000 mile increments I didn't even look at the tread. At about 9000 miles I noticed the cupping and had it aligned on warranty. (I've had the same issues with other Toyotas). The tires though (Bridgestones) wore out completely before 24000 miles. Fortunately I had a "tires for life" deal at my dealership and they put another set on. At 39,000 miles I can see these will need replaced before the summer is over. I couldn't convince my dealer to put better tires on, explaining it would save him money and perhaps even be cheaper. That's the only reason I stick with the Bridgestones (free is good no matter how long they last)
I don't understand why Toyota decided to put a V rated tire on an economy car. I don't know a lot about low rolling resistance tires, and I can see where a hard rubber tire like a V rated tire can help, but surely they make one with a 400+ treadwear rating? I have heard of no one complaining about the Michellin's.
The other problem I have is with the size of the tires and calibration of the speedo. Earlier posts last year covered this but it is impossible to change tire size to correct the speedometer error. This should have been designed and then calibrated with a taller sidewall for comfort, OR give me the SE suspension! I don't want rough riding tires with soft springs. I want a ride like a (Big) Cadillac or like a Vette.
Our TCH 50th Anniversary Edition has 15,700 miles on it and the original factory Bridgestone E400 V rated tires have had to be replaced. We had alignment problems with the car and I noticed this at the first 5,000 mile rotation. The dealer did only a 2 wheel alignment and I still noticed inside tread wear on the front tires at the 10K rotation. At the 15K rotation I noticed an excessive pull to the right and the tires were badly worn. I replaced the tires with Bridgestone Potenza G019 Grid tires. I also had a lifetime alignment done at the Firestone garage where I bought the tires. The car now runs true and the new tires are much quieter, longer lasting and more fuel efficient. The original tires had only a 20,000 mile tread wear specification. I noticed the new TCH has a Michelin Energy tire with a much higher tread wear rating. Also, when it comes time for you to replace the tires on your TCH, stick with the 215/60R16 size. I found changing tire size caused problems with the computers ability to transition from battery to gas, reducing the fuel efficiency.
I doubt that had anything to do with the computer, more than likely to do with the tires rolling resistance; a wider tire or different tread design causing more friction
Finally replaced the stock wheels with some cool OZ Racing Rims off tire rack . Question- does anyone know if the computer and speedo can be recalibrated ? I think it's showing me with lesser mileage and that I'm going slower than speed shown on speedometer .
I have a 2007 Camry Hybrid with 61,000 miles. I am going on my third (3rd) set of tires this week. The problem is cupping of all 4 tires at the same time within 25k-30k miles. I have discussed with my dealer and they said i did not rotate/balance enough. I did this maintenance work every time i changed my oil. I have the receipts to show and dealer still blamed me. I have had suspension system checked and have done alignments. Still the second set of tires cupped (all 4) after 25k miles. First set of tires was stock - Second set are GoodYear - not sure what to try next
HI, I have a 2009 TCH that I bought in July. It now has about 6500 miles and just today has seen its first snow. I don't like how it handles in the snow, thus I'm considering 4 snow tires.
I did the same thing to my Volvo and it was great. Without snow, it was scary to drive. With 4 snows its a pleasure.
My questions are: What snow tires to most people put on the 2009 TCH?
What considerations or concerns do I need to be aware of concerning the tire pressure sensors? Do I need to get them on the snows as well or can they be disabled when I have snow tires? How do people handle this?
I have blizzaks (on dedicated alloy wheels) on all 4 corners. had them on our 2007, and now have them on the 2009. the camry is great on ice and snow with Blizzaks. you should definitely get snows...your OEM tires are resting when the snows are on, so the snows don't really cost you anything. tirerack.com is a great place to search, and to buy as well. you can save a few $ if you can find steel wheels for your snows instead of alloys. I swap them on and off myself, but if you buy them locally, the tire shop might do it for free for you.
If you buy snow tires only, and have them swapped onto your OEM wheels each spring and fall, then your existing TPMS stay in the wheels and continue to function. you'll have to reset them each sway, though, but it's an easy process. doing this means you have to pay for rebalancing 2x year; not worth it, to me.
You can get tpms sensors if you buy dedicated wheels, but they are pricey. I didn't bother. The light flashes at first, but then stays on solid all the time. easy to ignore.
don't know. I think it varies with different manufacturers. It might be mounted to the inside wheel flange. I believe it's difficult to move them...better to buy another set if you really want them on the snows too. I seem to recall tirerack wanted a few hundred dollars just for the sensors. You might be best off just using your existing wheels/sensors, and mounting and balancing the snows each season.
Know that this reply is a bit late but if it helps somebody... Got my 2007 with the recommended Michelins and I changed them at around 45,000 miles for another pair of Michelins. Have the tires rotated every oil change and drive 100 miles a day to and from work. Like the ride, traction and wear on them.
I have a 2008 Toyota Camry Hybrid with Firestone tires. I'll be lucky to get 20,000 miles out of them. My car is well maintained and I regularly check the tire pressure, which is set at 32 psi per manufactuer recomendations. No alignment problems. The car is basically local to and from work and not driven hard. I understand the Michelin tires will go about 45,000.
I had a 2007 tch and the tires were gone at13,000 miles, now I have a 2009 and the first set of tires is gone at 15,000. The dealer blamed me for bad rotataion. Documented not true. Then I must have thown out of alignment. Tires were wearing to inside at the first rotation. Did they not beef up the suspension to accomadate the heavy batteries??
I think you should go and change your dealer. If you show on your receipt that you paid for oil change with tire rotation and balance, then they are not doing a good job. All they want is to make money. So if you are concerned a little bit with your tires, they will try to milk it and have you change it. By the way. I have a Toyota Camry Hyrbid 2007 as well. I bought in in Feb. 2007. its now july 25, 2009. 76,000 miles. still using factory tires.
I need to replace the tires on my 2009 camery Hybrid after 27000 miles. The Bridgestones offered a great ride but lasted only 27000 miles. I am sure this is a common issue with these tires any suggestions as what to replace with and do I need to continue with the "V" rating
yup...unfortunately, it is a common issue .... doesn't seem like Toyota cares...I replaced mine after 18 months (at 26K miles) on my 2007 hybrid....after quite a bit of research I went with the Michelin Pilot Exalto (H-rated) and I'm glad I did ... great performance so far on Chicago (tire-testing) roads. I did look at Michelin Primacy and Yokohama (I have only used Yokohama on my 10-year old Acura and love them).
I'd say pick a couple based on some initial research, then compare them more thoroughly (based on user feedback) and roll with one.
I am consicering the pilot h rated How long have you had them how are they wearing how is the ride and most important how is the gas millage Did it go up stat the same or down I must say the ride on the original oem was good they just did not last
These Michelin Exaltos have been quite good ... I have ~33K on them now and they seem to be wearing quite miserly ... next time I go back to discount tire for a rotation/balancing, I'll ask for an "official" check but I think they have AT LEAST 30K more in them. The ride has been smooth and the gas mileage..well, I believe it has improved ... last summer I hit 42 MPG a few times while I was struggling to hit 38/39 earlier. You could argue, that probably I've gotten better at driving it but I don't think so. As for the noise, I could comment better if the interior of my car would stop rattling for a second ... I hate it from the beginning.. taken it many times to the dealer but they never gave a crap..always thought it was in my head. My ancient Acura is ton more shock absorbant and smoother than my TCH... if Acura started making Hybrids (and in the neighborhood of Camry pricing ~5K) ... I'd switch in a heartbeat. Just my opinion!
Well, I have a 2009 Toyota Camry Hybrid, took it in for the 30,000 mile service today and was informed that the tires were down to 3/32 and need to be replaced. The mileage was at about 30,018 (had the car just over 18 months). The tires were the Bridgestone and I ended up replacing them with Yokohama's that were about $110.00 each. I didn't pay too much attention to the tires when I bought the car to be honest, guess I just kind of assumed I might get 45 or 50k out of them, but that was obviously not the case. I believe the Yokohama's are guaranteed to last quite a bit longer. The 30,000 miles on the Toyota are fairly "easy" miles and the tires have been checked and rotated very 5,000 miles, pretty much like clock work. Based on what I have been reading online you can't expect much more than 30k out of the Bridgestone tires. I will contact Toyota and complain about it. I would have expected somewhat better from Toyota and I have had good luck with Toyota over all.
Got my TCH in 06/06 -- just buying new tires this week. Have 50,260 miles on P215/60R16 94V. Tires need to be replaced before snow.
Have only sporadically rotated tires. Currently have best tread on front. Rear is pretty bare & will replace all 4. Had a recall on a steering rack so got car realigned at about 40 K. Prior to that did notice some pulling to left. Important to keep tires properly balanced -- had to rebalance a few times (threw some weights I guess.)
Have followed tire pressure thread. Tend to run 33-35 psig in summer, and 32 psig in winter. Manual says 35 Psi to be used if running at > 100 mpg. I drive fast on trips and so use the higher pressure in summer, but reduce in winter for better traction.
Traction in Snow -- Also have a 98 Infinity I-30 with 150 K miles and it is definitely much better in the snow. Live in Boston area and go to ski country. I-30 definitely better in snow. Seems like front end is "lighter" on TCH, with traction not quite as good as I-30 (a great car but only 22-24 mpg). Could be that I-30 with Dunlop Sport All Season Radials have better traction, but it feels like it is much more then just the tire. I-30 much heavier in front it seems.
Any others with experience using tires in snowy region?
Have been getting about 35 Mpg overall in summer, and 30-32 MPG in winter (due to car running longer to heat up and not shutting down at stop lights in winter). Have hit tanks of up to 40 MPG on trips -- especially in the mtns.
Extremely pleased with Michelins and will go with same -- especially after reading other tire horror stories.
This is an excellent site for info -- just found it and appreciate all of your input.
These tires are the original equipment on my 08 TCH and have served me just fine. I have 67,000 miles on them and they will probably be replaced by the time I hit 70,000. I drive roughly 600 miles per week in Atlanta traffic and get about 40 mpg. I would like to find tires that are much quieter but don't know if that is possible. The ride is good and they do fine in wet weather and dry. Never tried them in snow! I'm think about replacing them with the same or with Hankook Optimo 727--both pretty pricey. I'm eager to hear from anyone with experience with these or other tires.
You accept the risk that your insurance carrier will most likelt deny coverage in the event of an accident :confuse:
I'll give you a hint - it's above 90 psi.
That has absolutely NOTHING to do with normal operation of a car, by a consumer, on roadways.
Period.
I'll give you a hint - it's above 90 psi."
Would you care to guess how fast and how far the cars are diven at that PSI?
Hint - it's less than 5 MPH, for about 100 yards.
90 PSI isn't my number. I think it is 45 PSI. I was responding to a post...
What actually happens if you run without the sensors.
I want to runs winter wheel / tire setup but I don't want to switch the TPMS's from wheel to wheel each season.
I will probably look into doing the same thing next year.
On Pg 172 of the manual
"The system will be disabled in the following conditions"...
*If the tires not equipped with tire pressure warning valves and transmitters are used.
It appears that "When the condition becomes normal, the system will work properly.
For more info... contact the people at an online store, such as tirerack.com, and they should have an answer for you.
Gampa
Thoughts?
Front Left
-0.13 degrees
Front Right
-0.15 degrees
Rear Left
0.30 degrees
Rear Right
0.28 degrees
Thanks for any recommendations.
I thought that these Camrys only came with these Bridgestones. I'll check out tirerack.com.
My questions are:
Steve
Where exactly is the tire pressure monitoring system? Is it in the valve stem on each tire?
I'd like to continue to use it when I get snow tires.
Steve
I got some Yokohama YK520 from Discount Tire and they have been great. Quieter, and the mileage had not been affected.
http://www.tirerack.com/tires/tires.jsp?tireMake=Michelin&tireModel=Pilot+Exalto- +A/S&partnum=16HR6EXAS
