Visitor Agreement.
http://www.edmunds.com/chat/subaruchat.html
Drew
Vans, SUVs, and Aftermarket and Accessories message boards
Ken
(Don't base a decision on the car based on the tires - they can always be changed!)
-juice
1) "Engine shudder on start-up" Yeah, I posted to this board when I first got it back in August and the Folks here agree that the boxer configuration tends to do this as each cylinder "catches". It's normal for this car/engine and ALL Foresters should do this. After a while, you don't even notice it.
2) My car does this too. If in Park, there is a slight bump/vibration, but in "D" with foot on brake, smooth as silk (well almost!). Big 4 cylinder engines tend to not have the smoothest idle. In fact, I had an '88 626 with a 2.2L engine that would shake your fillings out in "D" w/foot on brake. Boxer is much, much smoother than most. I noticed that your previous car was an Oldsmobile (maybe with a 6 cyl?). I too moved from a very smooth 6 cyl back to a 4cyl engine. People who make this transition will tend to notice this stuff more.
3) I have the same faint whine/whistle you describe. It is more noticeable when it's cold. I believe that it is coming from the auto tranny. It could also be the fuel pump as it occurs only when accelerating.
It's actually good to hear that you are having the same things occuring with yours. I am not overly concerned about them. If they change (noise becomes louder, harder starting, etc.) it's off to the dealer we go....
-Tony
Drew
John
Don't know about the newer models, but my 1999 downshifts automatically from high gear going down steep hills over 45 miles per hour. It will upshift when it gets on a level
stretch, or I can upshift by shifting down to 3rd and up to 4th manually. You may need to check with the dealer if yours is not downshifting (or they may have changed the system since 99).
PDouglas
"While going down a hill
When descending a steep hill, depressing the brake pedal will cause the transmission to downshift to 3rd gear, thus applying engine brakeing. Reacceleration for a short time will cause the transmission to upshift normally.
NOTE
In some cases, depressing the brake pedal on a downhill grade does not result in an automatic downshift to 3rd gear. This can happen when the automatic transmission fluid temperature is very low, for example, during driving shortly after the vehicle has been parked for an extended period of time. When the ATF temperature has risen to a certain level, automatic downshift normally takes place. In the meantime, downshift manually for engine braking as required. Also, downshifting when braking downhill will not occur at speeds above approximately 50 mph (80 km/h)."
Frank
Also what is the proper brake in procedure. I was told that in the first 500 miles not to exceed 4000 RPM. Someone told me not to use the cruise for the first 4000 miles. Others say first oil change s/b @ 1,000 (another said at 3,000).
TIA...
A so-so deal, 2002 model for 22850 with the rear differential protector, air filter & arm rest extension thrown in.
I look forward to continued comments on Forester boards. Thanks again, everybody!
PB
what should I do about this checklist? Is there a position I should take with the dealership, i.e. provide me proof of preparation or let it ride because maybe it's just paperwork they didn't complete? Do I need it completed to enforce my extended warranty?
Cynthia- It most likely means nothing. Subaru puts blank pre-delivery checklists in the glove compartments of all their cars prior to shipping them to the dealers. It's mostly likely that the dealer just used his own form to conduct the pre-delivery inspection. If you're concerned, you can ask the dealer to show you his file copy of the completed checklist. To answer your 2nd question, lack of this piece of paper has no effect on your extended warranty.
FYI: Any potential car buyer should know that every dealer has to complete a pre-delivery checklist and the salesperson is supposed to go over it with you as part of the delivery process. You should never leave the dealership without having the the saleperson fully cover all aspects of vehicle operation.
-Frank P.
Under $19k for a Forester sounds like a deal to me. That's less than I paid 4 years ago!
PB: go ahead and yank out those speakers. It's not hard and will produce the best cost/benefit among stereo upgrades.
Cynthia: each dealer probably has their own PDI (pre-delivery inspection) checklist. That one is probably provided as an example. Given you have the extended warranty, I'd be even less concerned.
Congrats on the new Forester.
-juice
-greg
Dave
I think - because 2002MY already in stock
Congrats.
-juice
stuener
We're all out of luck. Homepage.com went out of business and took down juice's homepage. QSubaru went out of business so Darlene can't supply us anymore.
juice managed to transfer most of his photos to his Photopoint account, which I'm sure he'll post soon after reading your message.
Ken
http://albums.photopoint.com/j/AlbumList?u=1400062&f=0
Ross
By the way....you mentioned weathertech rubber floor mats. Are they a perfect fit for the Forester? Where can I get a set of those puppies? I'm in desperate need of good rubber mats. You wouldn't beleive all of the dirt, gravel and mud I accumulate in my Forester over one weekend.
Skip
These mats are made in England...will capture a quart and a half of water without getting it on your floor, and fit the Forester quite well. I'm thinking about getting the one piece mat for the back seat floor next. The price? About twice what you'd shell out for el-cheapo's, and worth every cent (in my humble opinion). Hope you like 'em...
You can go to the manufacturer's web site directly at www.macneilauto.com/store/ They sell the Weather Tech mats and have a few pictures of them. I bought a set of four for my '01 Forester and they are nice. They're pretty heavy, and you can trim them to fit. They have score lines to trim along. I fit the rears by trimming the outer edges off both mats, and by removing the top outer curved corners (easier to understand once you see the mats). They now fit perfectly around the front seat rear floor mounts. I also trimmed the driver's mat under the accelerator pedal, as the mat prevented it from going all the way to the stop on the floor. You just trim along the squares. The front passenger side mat didn't need any trimming. One of the front mats comes with the left-front corner relieved, and it fits perfectly around the driver's left foot rest. I also trimmed this mat under the accelerator pedal, as it prevented the pedal from going all the way to the floor. Here's a hint: if your Forester has the factory carpet mats, take the rears and put them under the front Weather Tech mats. The floor has a depression in the center, and the square carpet mats fill it in perfectly under the rubber mats. I tried leaving the factory front carpet mats in place under the rubber mats, but they were too bulky.
An update on fuel economy: with about 1600 miles now logged, I've tracked four full tanks so far. I got 32.00 MPG on the first and 28.28 MPG on the second. These were on Sunoco Super 93 octane. The next two tanks were 28.21 and 31.39 MPG, both on Sunoco Plus 89 octane. Average for four tanks has been 29.97 MPG. I hope this will go up to low thirties when it is fully broken in.
HOLY COW, LEO! You going down hill both ways or what?! 32mpg is sweeeeet! I have yet to break 30, but I'm still happy with my 25.1mpg average.
-juice
By the way, regarding the crush washer on the oil drain plug (as was discussed on several earlier posts on this forum): it goes with the flat side against the drain plug. I changed my oil last week for the first time and I checked it as it came from the factory.
juice: unfortunately, only downhill one way! Otherwise I could coast! Seriously, I travel about 90% highway during off hours, so I don't hit much traffic, which helps.
Len
Skip
By the way, the dealer (Libery Subaru in Oradell, NJ) has a few more 2001 left and they are on clearance to make room for the 2002 Foresters. They even lowered the price on the green 5 speed to $18650? -- $375 less than I paid 4 days ago!!! They have 1-3 L automatics left (roughly $19,200) and a few 2001 S w/sunroof for 22,???. Ask for Jeff Miletta (I guess you can tell him that Renato referred you). I am NOT affiliated w/ this dealership... but was pleased w/ the way I was treated (avoid Lynnes in Bloomfield, NJ).
Anyway the break in is 500 miles, keep it under 4000RPM. First oil change at 5 mos. or 3000 miles.
Chat with you all on Thursday!
Also, has anyone had any problems having people in the back seat? Is the rear leg room too small?
Steve
Sundhar: is that Canadian or US dollars? The price is very high for an L model if you mean US dollars. People usually pay under $20k. An S goes for around $22k, and the S Premium picks up at around $23k and up.
-juice
We have had the car 2 weeks now and are enjoying it very much. I didn't have a great experience with the dealer pep though; all tires at 44psi and the manual transmission fluid was not topped off. Service manager said that the "other" dealership forgot to do the tires (even though the sticker said they were the ship to dealer). When I asked about the trans fluid he said it was actually ok the way it was (about 1/3 way between F and L on the L side). I then asked how much oil needed to be added when the stick read L and he said a very small amount (fraction of a quart). When I told him the manual said that transmission oil capacity was 3.5 quarts he told me that it didn't hold anywhere near that amount (I think he was thinking automatic). At that point, I gave up and said I wanted it topped off anyway. After top off it read on F and I noticed the shifter was a little smoother when I left the dealer. The only reason I checked in the first place was because the manual said to check it 1 per month and add as necessary. Oh well, we are satisfied with the car at 2 weeks. BTW - 1st fillup we had 28mpg.
Join us tonight for the chat.
A lot of dealers forget to air down the tires. If they are busy they rush the PDI (pre-delivery inspection) and can miss a lot of that stuff.
Anyhow, it seems like you'll be a good owner in terms of servicing, so I'm sure your Forester will be fine.
-juice
Steve
Drew
After reading the last few posts, should I rely on what the dealer set tires at (I haven't checked yet) or is there a better pressure I should start them at? Thanks, Susan
Ross
I also stopped at the dealer today and picked up an interior air filter kit. In the 2001, the housing already has a removable door on it, which is held in place by spring clips, so no cutting is necessary. Just pop it open and put the two filters in place. (Hopefully it will really be that simple!)
Next project: speaker upgrade.
Len
Patti
Len- 15%? I've heard of 20% and 5% but didn't even know that 15% was an option. I'm glad you're happy with it and bet it looks great. Can you post a picture?
-Frank P.
We debated about having a CD player installed, but the single disc player alone will set me back $350! For that kind of money I can buy a top-o-the-line 50 disc changer for my home. Has anyone found a reasonably priced alternative? Have any of you audiophiles replaced your OEM unit with something better and, if so, are you interested in selling the old unit?
Dave
