Mitsubishi Eclipse New Owner Reports
So you have your new ride, now! Congrats - tell us your first impressions.
What a fun ride and I'm coming off a 2002 Gold Wing.
"uncleharry" you are soooo lucky to get the special interior that was the car I really wanted but of course I couldn't afford that model. But I got the next best thing!
To answer your question about the mpg. I would estimate my GS gets around 20mpg, but I am quick off the line and I probably like the drive faster on the highway than I should. The tank holds about 17.5 gallons which is a real killer when filling up the gas tank. I just filled up for the first time and it came up to $40 with 14.5 gallons at $2.74 a gallon. I was used to paying $25 for a full tank on the 99 eclipse. But theres not much you can do about that.
You can't help but love this car when you get in it and start driving!
Does anyone know if this is normal for this year or has something possibly been replaced?
Thanx so much
Newbie
I realize you ask this a long time ago but since it is a common question I'll share my results.
I own a 2006 GS Eclipse with the 5 speed manual. It is in the UV Blue Pearl color scheme. I'll admit I drive the car faster than I should most of the time. I'm quick off the line and drive at high speeds on the highway. Even with this, my mileage averages out at 28 mpg. When I drive calmly, I have no problem getting 30 mpg and have in fact got 33 mpg before. The lowest mileage I have seen is 26 mpg but I normally get the 28 mpg as mentioned earlier. I just like to drive the car fast!
Leon
Mileage is 21-24 mpg with short 14 mile commutes to work each day. There is not a single wet or fluid spot on or under the engine. I paid a whole $5000 for it after talking the dealer down from $7995.
My point is do your research with carfax reports and also do comparison pricing using cars.com or autotrader.com on the same thing within a couple hundred miles. Go prepared to walk out if they won't deal as you will find one that will.
