BMW Z4 Audio System Problems
                    Share questions, answers, and observations about iPod interfaces, CD players, and stereo systems for your Z4.
Once you locate the wiring harness, install takes minutes. Locating the harness on the Z4 is a little tricky, but I got lots of support from Z4 owners online.
Pull back the carpet on the back wall of the trunk, there is a cut out in the center of the sheet metal that separates the trunk from the passenger area. That cut out is the back of the storage compartment. Reach your fingers through the cut out and you can feel the harness down on the bottom of the pocket. You will also need the remove two torx head screws from inside the storage compartment which will loosen the bucket and allow the harness to come free. The harness is also taped down but if you work the wires gentle they will come free.
The tricky part is that you have to do most of this by feel as you cannot completely remove the carpet on the back wall to do the pull for the manual override for the convertible top. But you will be able to feel the harness. And once you have it just keep gentle working the wires and the harness will pop out.
Thanks again, I only hope that other looking for those wires will find this post
Check out what this guy had to do.
link title
any problems with it?
Is your z4 a 2006? If so could you try to help me some how.
Also I have another question, my cd player doesn't read song's names, it always displays: track 01/02... do you happen to know how to fix that? Thank you evry much.
I have an 06 z4 with the standard business stereo. I recently bought a phatbox but have been unable to get this to work with my headunit. I have been looking around various different forums for an answer to this problem but so far have not come up with any diffinitive answer. I am begining to get the impression that the 06 is just not compatiable with phatbox so I would love to know if there is anyone out there who has a phatbox wired and working in a 06 z4 just now and if so what adapter they are using to connect to their system.
I would appreiate any feedback regarding this.
cheers
Tony
If you've already solved this one, then do you happen to know how the heck to thread the cable through the console grommet? I've tried hangers and such but it's just too darn tight down there. I'm pretty close to just grabbing my drill...
:confuse:
A CD is stuck in the dash CD player. The CD will play and the radio works. But, when I press the eject button, the radio goes on and the CD remains inside the player.
Any ideas on how to get it out?
I tried disconnecting and reconnecting the battery, but still no luck. I managed to grab hold of the CD with a small surgical clamp, but it won't budge.
