Chevy S10 - GMC S15 and Sonoma Climate Control
Has anybody else experienced air flowing through your vents, similar to if the fan was on low, when you have the knob on OFF. ??? any suggestions?
(Now that they changed/ closed the general forum topic to read only ( a blunder in my opinion) - I find it hard to want to spend the time to jump through multiple discussions and read reply ... too bad. But good to find a post from you !! )
re: Fan - I think I remember reading that due to CO concerns the fan will never shut off - in case someone falls asleep in the vehicle - and/or the tail pipe get blocked (i.e., parked in snow). So I think this might be "normal".
The pain is that when you leave the flow path knob set for "Floor" - it gets hot air - especially irritating in the summer.
What I do is change the flow know to top vent set to Cold (not AC)- it seems to fix the issue. Air still comes out - but it's not hot and it's at least Not bothersome ...
When the truck is well warm - shut it down, open the hood - and see if you can feel if the heater hoses going to/from the heater core are BOTH hot ?? If only one is - Check to see if you have a vacuum run shut off in one of the lines - and see if it's open allowing flow... Could be a bad valve - or - vacuum not getting to the the valve (i.e. cracked vacuum hose ??)
Otherwise - it's possible that the core is plugged - or perhaps even air bound ???
Just a couple thoughts ...
I am trying to replace the heater core in my 2000 S-Blazer. I got the dash out and the heater/ventilation unit loose except for what appear to be 2 bolts coming through from the engine side of the firewall at the bottom. I am working from a Haynes manual, but there is no mention of these bolts. If I am right, the only recourse is to depressurize the A/C system & remove the evaporator to get to these 2 bolts. Seems ridiculous to have to do this to replace a heater core.
Looking for any help or advice that might be out there.
Finally determined that you have to go in through the right wheel well -- remove the wheel and wheel well liner (meaning you have to pull the battery, powertrain ECM, and the coolant reservoir. Once all that is out of the way, you can get to the 2 studs coming through the firewall, remove the nuts, and proceed.
There is a mention of studs to remove, never did the job so not sure what they are talking about.
The GM SI for heater core replace is long and drawn out, like the job I guess.
In the mean time I downloaded MB's of files for my 2 vehicles.
Anyone can get on their SI site, but you need to pay with credit card. It used to be day, month and year.
Go here, no WWW. http://service.gm.com
I have a 2000 Jimmy and I have to replace the heater core in it real soon. Thank you for posting this information about removing the wheel well liner. Did you have o discharge the a/c system? Are there any other tips you can offer before I start?
Thanks again,
Luke
using refill ez chill auto air conditioning r-134a refrigerant plus oil
could you please tell me were or what line to attach to fill it thanks
Where is the a/c condensation drain hose on a 1998 GMC extended cab Sonoma? I am getting water in the cab on the passenger side, coming down from the firewall when the a/c is running and after it is shut off. I have looked under the truck as best as I can and cannot find the drain hose. Any help to put me in the general area would be appreciated.
This Applies to all owners looking at coolant level.
Stop looking in Coolant over flow tank for confirmed level of engine coolant.
You'll get faked out every time.
You need to only look in radiator.
First sign of no heat is low coolant.
Second is plugged heater core.
Be careful and gentle when flushing out core to not over do it with outside pressure source.
You could force a weak heater core to leak all inside vehicle.
If you applied radiator stop leak in the past, then take a minor guess where all that crap is now.
If you have to use these products, then take out the heater core from the process by removing the heater hoses from the engine.
thanks....
Good luck
I had read somewhere that it may be a Ground near the Dash Cluster, but I've no Idea where the Dash cluster is at, I've the repair manual as I've had to do many repairs to it, and in the Electrical Diagrams area, they list quite many, many grounds, many more than what I wish to check, I've check and cleaned the grounds in the engine compartment, all are swell.
Any Ideas?
Thanks in Advance.
If your Blower Motor is working, I think you could rule that out, The BMR, is roughly 17$ of course depending on where you're at.
As I've just replaced my BMR, trying to resolve another issue, I know it's a simple task to to replace.
The A/C is so cold, I have to modulate with heat or I would freeze, even when 90+ out.
At cold idle the compressor kicks in and cools perfectly. However, once warmed up and at idle or highway cruising speed, the compressor no longer kicks in and the only way to get cold air again is to accelerate. As soon as I accelerate to pass a car the vents start blowing very good and cold air. I checked the low pressure switch on the can, and as far as I can tell it's not receiving voltage when engine is running and warm. As soon as I rev the engine the compressor will kick in again and blow cold air.
The compressor and dryer were replaced about 5 years ago and I have had no problems of any kind until recently. This has me stumped. I've got a long road trip ahead of me and I live in the south. Any suggestions would be appreciated
