Hyundai Elantra Transmission Questions
Which transmission do you prefer in the Elantra--automatic or manual?
Jim
I would prefer a 5 spd automatic.
Majority of the 5% with manuals are "sport" type models.
6 speed manual and or automatic would both be nice, however, why develop a 6 speed for less than 5% of the market?
Also it's 5% of the U.S. market, but manuals are much more popular in other countries where the Elantra is sold.
Very good point.
What I would really be exited about would be a DSG type transmission similar to the one being offered in VW's and Audis that combines the benefits of a manual and an automatic. And it would be applicable to all markets.
However, I am concerned about road noise with the MT, so I'll need to drive both to find out. Has anyone already done so?
I think it's the "fun" factor that sways us. We love the control that a manual transmission offers the driver. Fans of paddle-shifters and manumatics can say whatever they want about control... but I believe that if it doesn't have THREE pedals, it's not the same! I think manuals also promote a connection between the car and the driver, in that they require a driver to actually drive.
In the new Elantra, we would be looking at a Limited model with a manual. I have a feeling that particular combination may be difficult to find, however.
If you want to see a comparo with ATs, I expect CR will do that sometime next year. They might even test both MTs and ATs, which would make for a nice comparison.
I thought you have had trouble with your clutch in your Elantra.
What happened to your auto transmission?
Niels
The clutch works great?
Or,
The auto transmission works great?
:confuse:
My reply, in context to his question, should be clear.
Backy.
Your auto transmission has a clutch? :sick:
I am not an expert on the Elantra's automatic transmission, but in general auto trannies have clutches. Here's a primer on automatic transmissions that may help answer your question:
http://www.familycar.com/Transmission.htm
Your new car is probably designed to be more fuel efficient for normal driving. That doesn't mean that top gear is always your best choice, i.e. lugging.
If it's a manual and the RPMs don't like to drop when the clutch is depressed, that is a known issue and if there isn't a software fix the dealer can do, I know of a simple modification to the Idle Air Control Valve that prevents the RPMs from hanging when you pull your foot off the gas. If your son has a MT you're interested in the mod, let me know. (It's basically making a restrictor plate for the IAC valve to keep it from holding the RPMs high. Hyundai does this because letting the RPMs drop too quickly hurts emissions.)
Assuming it is an automatic, isn't this the "shift flare" problem that a lot of Elantras have experienced? I think there is a TSB for this...I know mine had it. I think it was 2nd to 3rd gear shift where the RPMs would flare up. My '02 started doing this right after we bought it (new), and I had the TSB performed on it (which I think was a software adjustment). It got better, but still occasionally happens from time to time. I now have 92,000 miles on the car, and get the transmission fluid plushed every 30,000 miles.
Bulletin# 0240001 from January 2002. NHTSA item # 628956
Summary - Some vehicles may experience a 2-3 shift flare condition (engine speed increases during shift).
Maybe doohickie can chime in, and show you how to look up on the "webtech" site, and see exactly what the dealer is supposed to do in order to correct this. Also, make a note that the TSB I am referencing is for 2002 models, but it sounds like this is the problem you are experiencing.
Like I said earlier, my car started doing this right after I bought it (brand new), and we did have the TSB performed on it. The condtion pretty much went away, but it will still do it about once every 2-3 months, and I now have 92,000 miles on the car with the original transmission.
P.S. - TSB = Technical Service Bulletin. These are issued by the manufacturer, and sent to dealers. They are essentially little bulletins the manufacturer sends to the dealer regarding problems that seem to be "commonly seen" in a particular model. In addition to notifying the dealer of the problem, they instruct the dealer how to fix it.
I also used the abbreviation NHTSA in my post. This is the National Highway Traffic Safety Administration in case you were wondering.
What you described (an increase in RPMs) is a "flare". The TSB you are mentioning does not specifically mention the "flare" in RPMs between gears.
Any Hyundai dealer should be able to handle the repair. Just a suggestion - I wouldn't go up to the service guy and specifically say, "This TSB needs to be performed to my car." I would instead say, "My car is doing such and such, and through my research I have discovered these 2 TSBs. Could you please see if they are applicable to this situation?"
Going this route, you aren't coming off as being too arrogant (or acting more knowledgable than the service guy), but yet you will have given him enough info to know that you somewhat know what you are talking about.
PLEASE - let us know how things work out for you. I have found the guys taht post regularly on this Elantra forum (doohickie, backie, jlflemmons, snakeweasel, and a few others), to be extremely helpful. These guys are very quick to help solve a problem, or offer a how to, which epitimizes why message boards like this exist.
Anyone had this happen to them? I have an appointment with the delare for Tuesday and am preparing. Total mileage on my car is 49K, so I'm hoping this is still covered in warranty.
Edgar
you just remove a plug. then refill the trans to the
proper level on the dip stick (hot) There is a big plug
at the bottom of the trans
What is a good tans fluid that meets the sp lll hyundai
fluid.. thanks
