Subaru Forester (up to 2005)
1276277279281282344
  • c_hunterc_hunter Member Posts: 4,487
    Nope, though VW (and GM) coil pack problems certainly outnumber the Subaru ones. Do a search on this particular topic and three unique failures pop up. Again, not a lot, but it's something I remembered!
    Craig
  • suydamsuydam Member Posts: 5,152
    I posted something about my problems with them a couple of months ago. I had to replace mine at around 65,000 miles ('99 Forester S). The real pain was, it took them about 4 different visits to figure out the problem, and my dealership is 50 miles away. I think people should know it is a potential problem because of the ease with which it can be misdiagnosed. Lots of cars have particular weak areas -- like mufflers in older make Mazdas, starters in Toyotas, and it's good to know about them. I think this may be one of Subaru's. Not a reason not to buy a Subaru. If you just have to replace the coil pack I think it was around $150. Hopefully the replacements are better.
    Then it happens but I wouldn't quite call that a pattern, at least not compared to VW. Dealers couldn't stock enough parts for those.
    That's funny you bring up Mazda mufflers because our exhaust went out on the 626 we dumped.
    -juice
  • ballisticballistic Member Posts: 1,687
    The muffler on my '79 RX-7 lasted beyond 100,000 miles. Then I replaced it with an aftermarket item, which was still in fine shape when I sold the car at 200,000 miles. Can't ask for more.
    RX7 prolly had stainless steel pipes. Not so the 626. But some competitors in its class did have SS back then.
    -juice
  • secretariat73secretariat73 Member Posts: 47
    My auto-dimming mirror (02 Forester) had problems around 50k (the N was always lit on the compass, so you couldn't tell your direction unless it was north :) ) I mentioned it to my dealer when I took the car in at 59.8k miles for service; and they replaced it under warranty. So, I think the warranty on that item is longer than 36k.
    -Steven-
  • sharksoupsharksoup Member Posts: 26
    Thanks to all for input on CD problem (message 14303) I'm disappointed, but not really surprised that someone else with this problem ended up having the system go bad on them.
    Someone had asked about cost for 30,000 mile service; was just over $325 at Quirk's in Bangor, ME.
    In all honesty, I probably could have gotten it done for less as I know that this dealership recommends servicing things at earlier intervals that the Subaru manual. But as I'm 185 miles one-way from them, (AND SOMEONE POSTING HERE WAS CONCERNED ABOUT BEING 35 MILES AWAY FROM A DEALERSHIP!!!) I figured let's do it all to their satisfaction while still under warranty, then I'll make choices after the warranty is gone based on Subaru specs.
  • leo2633leo2633 Member Posts: 589
    suydam said in post # 14323 that a coil pack problem can easily be misdiagnosed. I'll say. When mine went bad, the dealer initially believed that the clutch that was defective! Luckily they did get it right, and it cured my problems (well, my car problems, anyway!).
    Len
  • once_for_allonce_for_all Member Posts: 1,640
    potential coil pack problems, but the topics of rotors, distributor caps, condensors, and other previously standard tune-up items no longer appears on the radar screen.
    Give me a coil pack any day over the problem of getting the dwell, advance, and point gap dialed in.
    John
  • gmginsfogmginsfo Member Posts: 116
    Happened on the way to work yesterday, when a cherry-sized piece of gravel got me. Not very noticeable, except to me - and I want it out! I recall some miracle product touted here a few months ago; can anyone steer me to it or recommend any other fixes?
    I made a major boo-boo and I need to hear it's not all that bad: I didn't rotate my tires at 7.5K. I'm planning to do it in a month or so when I take my '03 XS AT into the dealership for its first "official" maintenance. I'm at 13.5K now and have been changing the oil every 3-4K. Do I have anything to worry about?
  • p0926p0926 Member Posts: 4,423
    Too bad about the windshield chip. Is it just a pockmark or is there an actual crack in the glass? If the windshield is cracked then many insurance companies will pay someone to come to you and repair it for free. Or if you live in a state that requires windshield coverage it should be replaced with zero deductible. If it's just a divot then I'm not sure what (if any) your options are. The local car parts store might sell glue that you can use to fill the hole.
    Didn't rotate your tires? Tsk tsk! The good news is that as long as they're still balanced, the front end is in alignment, and you've kept them inflated properly, you've probably not done any harm and they'll last just as long. The front tires will be slightly more worn but that will even out when you rotate them to the rear (in fact you might want to not rotate again for another 14k miles so they even out). Really the main advantage to rotating every 7.5k is to catch any problems early on before they can cause any serious wear to your tires. Or if you drive aggressively you'll wear down the fronts faster so you'll want to rotate them fairly frequently.
    So the bottom line is that you're probably fine.
    -Frank P.
    I actually do it every 15K myself, and the tires have been wearing fine on our Subarus (40K and 30K miles).
    Craig
  • caperosiercaperosier Member Posts: 58
    The latest Consumer Reports evaluation of car quality places Subaru well below average for problems in the 2003 surveys. CR receives about 675,000 very detailed surveys to owners each year. These are problems per 100 cars. We fill it out every year.
    This is real world, experiential take on specific problems with new cars, 1, 2, and 3 year old cars.
    The Subaru rating among all car manufacturers has dropped from '99 to '03. It is now "below average".
    So, without the flaming, what gives ? (And please, no "no one has ever complained before" approach.)
    Remember before the flame, this is a survey of owners, not a technical eval by a magazine.
    I'd like to hear from the SOA people on this.
    Disclosure: 3 Subarus over the past 14 years. Now own a '01 Forester 5 spd with NO problems in almost 70K. I'm satisfied and ready to buy a second. BUT ?
  • jlkjlk Member Posts: 12
    I am trying to decide whether to purchase XS or X. I could forgo some of the additional features in XS but there are some that I don't know what they are. Therefore, I hope someone here can help me. What is EBD (Electronic Brake-force Distribution)? Since the car is already equipped with ABS, does EBD really improve the braking? What does a limited-slip rear differential mean?
    My last question, sometimes I do need to travel on a hilly road not with steep slope to climb, will either of the model be capable to take the challenge? Or I need to look into the XT model?
    Greatly appreciate for anyone input.
  • joybelljoybell Member Posts: 275
    I've owned Subarus since 1985, one used, three new, and add to that three more that belong to family members, all pre-1999. Other than my Mom's 1998 Impreza that had wheel bearing issues, my present 2003 Forester is the only one that has had to go back for warranty repairs (twice....so far).
  • sarakaysarakay Member Posts: 19
    Hi folks, just wanted to say thanks for the replies you gave to my question. What a great resource this is! I appreciate your taking the time to give me your opinions.
    Sara
  • kenskens Member Posts: 5,869
    Most windshield installation places will also have chip/crack repair. They simply inject a resin into the crack and cure it with UV light. The fix is guaranteed for the life of the windshield. They will not, however, fix chips that are directly in front of the driver's vision.
    Get the chip repaired as quickly as you can. The thermal expansion/contraction of your windshield can cause the chip to grow into a nasty crack instantly.
    Ken
  • mckeownmckeown Member Posts: 165
    These have been my experiences: (all 5 speeds)
    79 DL.....Flawless...Never had a warrenty repair.
    82 GL 4wd ....1 recall....No warrenty work either.
    85 GL 4wd wagon..No warrenty work, but by far the worst, noisest, rusted in 3 years, cam and carb problems..all out of warrenty.
    90 Legacy LS...Best I've ever owned..No warrenty work..very few problems, over 350K when totaled.
    02 Forester....13 (yes 13) warrenty repairs, From clutch to 7 oxygen sensors. Still awaiting the coolant sealer letter. Currently 53K with a bad case of piston slap which Subaru HAS acknowledged, but refuses to repair as it causes no internal damage so they say.
    FYI....I subscribe to Consumer reports so YES, I do fill out that survey each year. Disappointed, but with my previous Subaru loyality, I will probably buy another. (my $.02.....as Eyeore says "Thanks for Listening")
  • lfdallfdal Member Posts: 679
    The 03 OBW - one day/night mirror, one piece of the gray body cladding trim lifting on the pass rear door, the tray below the CD player was totally warped, so 3 minor repairs, but 3 days out of service in 15 months.
    The 03 Forester XS - day/night mirror, grab handle on drivers side above door was loose.
    The 04 Forester XT - 1 noise trip (fixed myself after dealer visit), no other trips that weren't dealer option installation (turbo gauge) induced (so I won't count those 3 trips)
    Summary so far - no better (or worse) than my years of owning Mercury Sables. Don't worry folks, I've belabored that point before and won't go there again :<).
    My 0.02
    Larry
    I read the car issue differently than you did.
    First off, while they listed 1 year old Subies below the industry average, the actually number was actually exactly average, spot-on.
    The older models, 3 years I think, improved to better than average.
    The oldest models in the survey, 5 years IIRC, were excellent, beating even Honda.
    I'm not sure how you can conclude Subarus are below average from reading that data. I sure don't.
    I look at it this way. Baja dragged down the average for the brand, but it still met the industry average. Subarus tend to show their problems up front while UNDER WARRANTY and at no cost to you. At 5 years, when the powertrain warranty finally expires, they are more reliable than Hondas.
    Phenomenal scores. I honestly don't see how you can read it negatively.
    -juice
    mckeown noted:
    "02 Forester....13 (yes 13) warranty repairs, From clutch to 7 oxygen sensors. Still awaiting the coolant sealer letter. "
    Man, I'm only on my third oxygen sensor in 2 years on my Forester! So I'll have to have more replaced over the next 4 or 5 years before I reach my limit?
    I've been somewhat disappointed with my 2002 Forester. Have had oxy. sensor problems, had to have the computer "flashed", some loose interior trim, clutch chatter (never diagnosed while at dealer), problem with CD player (again, never while at dealer), and initial problem with alignment.
    What makes me really angry though is the fact that I really like the car!! I just don't like having to put up with the problems it's had. It's not likely I'll buy another Subaru. The main reason though is because of the distance to the dealership; 185 miles one-way. I don't want to ever again have to deal with taking time off from work to spend all day in the car just to have something fixed.
    Course that limits me to local dealerships; Detroit's big 3, Honda, Mitsubishi, Nissan.
    "The oldest models in the survey, 5 years IIRC, were excellent, beating even Honda."
    That's exactly the point. Older Subaru models (and engines) have fewer problems than the new ones.
    "Subarus tend to show their problems up front while UNDER WARRANTY and at no cost to you."
    Thats a FORD consumer attitude. Ask a Subaru "loyalist" how they feel when they have to take their Subaru back to the dealer for a warranty repair.
    I've spent exactly zero out of pocket in 6 years. Dad's Outback had squeeky brakes, but that's it for the 4 years he had it. My cousin's '99 never went to the shop once. My sister's '03 only had to go once, to the body shop.
    There are bad apples in every batch, but get a big enough sample and Subies tend to be better than average.
    FWIW, in JD Power's Durability study, 5 year old models averaged 2.7 problems per car. So if you had about 2-3 problems, that's average. If you had 7 problems, well then there is one owner with a trouble-free car to average it out.
    joybell: I respectfully disagree. I'm not far from my dealer, but I don't mind visiting once in a while. And again, Subaru is average at first, not below.
    If JD Power's numbers are right, remember, it's 2.7 problems, that could mean 5-6 visits to the dealer to fix all those problems, who knows?
    Keep in mind the people with problems are much more likely to go out of their way to complain. How many people chime in saying "no problem here"?
    -juice
    I do think a lot of people expect to buy the perfect car, and honestly I don't think that's realistic. There are a billion things that can go wrong.
    In fact I doubt there is such a thing as a zero-defect car. Owners may just be overlooking certain quirks.
    Bear with me, I do have a point.
    Look at the BMW X5. They had 14 recalls in the first 12 months. Ouch.
    But then look at JD Power's APEAL study, it won! Customers love them any way, despite 14 dealer visits in 12 months, mandatory, minimum!
    So IMHO that demonstrates that a BMW loyalist can own a vehicle with *horrific*, record breaking quality control yet feel pretty darn good about it! #1 in class, actually.
    -juice
    PS The BMW X5 is *not* an exception. VW New Beetle also has terrible reliability yet it won JD Power's APEAL study for its class also
    They have their issues, too.
    Check the 2nd article on this link:
    http://www.thecarconnection.com/index.asp?article=7041&sid=17- -3&n=156
    And don't forget how Toyota treated its Sludge Customers, all 3.3 million of them.
    -juice
    "joybell: I respectfully disagree. I'm not far from my dealer, but I don't mind visiting once in a while. And again, Subaru is average at first, not below."
    Oh well, I do enjoy visits to the dealer, chatting with other Subie owners, looking at the shiney new models....and driving my Subaru I always feel a little smarter than those who don't drive a Subaru. But, IMHO, "average" is pretty bad....for a Subaru, and I do feel a little betrayed because my Forester did not come out of the factory "perfect". But that's only because I have been spoiled.
    So I got you to admit you are holding Subaru to a higher standard. ;-)
    It's all good, I think feedback and balanced, constructive criticism is necessary for continuous improvement.
    Honestly, though, I think there is a certain type of customer that demands perfection and they'll just keep switching brands for the rest of their lives, never satisifed with what they get.
    Forester has won several APEAL awards, and to me liking your ride is more important than needing 2.03 visits to the dealer vs. 1.75 visits for Brand X or 5.32 visits for Brand Y.
    Also note that Forester was best in class per Polk in owner loyalty again for 2003 (they won in 2000 and 2001 also). When you consider Subaru has just 600 dealers often 180 miles away from some owners, that's impressive.
    So either these are nice vehicles or we are crazy masochists. ;-)
    -juice
  • njswamplandsnjswamplands Member Posts: 1,760
    i had a ford winstar and just let recall notices accumulate unti the next 'real' problem or service occured
    LOL!
    You detected the pattern and then kill 3-4 birds with one stone! Hilarious.
    I stand corrected!
    -juice
    PS Maybe it was a conspiracy by BMW to keep getting people back in to the dealerships?
    that ford dealers got because of some wierd part that had to be swapped out. actually should we get oliver stone on this conspiracy?
    I personally had a bad experience with them.
    There was rust on the fuel filler neck, at delivery. Already. So I pointed this out and they promised a free oil change, and they'd do it all when I hit 3k miles.
    I took it in and they undercoated it instead, never even looked at the fuel filler neck. Then they presented a bill for the oil change!
    Yikes, so they wanted me to pay after not fixing the original problem I complained about. After a lot of noise, I left with a free oil change and undercoating I didn't want.
    And rust on the fuel filler neck.
    To me, really, the key is the experience, seems like that dealer did everything to turn me away from being loyal.
    Ford Credit was worse. I wanted to wait to sell my old car before I bought they new one, they convinced me to buy that day and just pay extra principal on the loan. Long story short, they didn't want to count that as principal payment, and I had to dig out the carbons for my check to prove I had written "FOR PRINCIPAL ONLY" on the check. Yet they still resisted honoring it. Took 45 days to sort out.
    Seems like they try to milk the customer after the sale.
    My Subie dealer has been better, still not perfect, but that's what Patti is for. At least we have a resource as Subie owners.
    -juice
    Just read this today about the same recall:
    http://www.canada.com/national/story.html?id=524812b7-62c7-489a-a- c94-d095881c9ccf
    Hondas assembled in Ontario, Canada with transmissions built in Ohio, USA. Domestic vehicles, IMO. No recall on the CR-Vs made in Japan with the traditional 4 cylinder engine.
    had 1 problem in 20,000 miles, a CEL that needed the computer to be reflashed. Nothing actually wrong, just a computer complaining about something that wasn't there.
    Our '02 Mazda MPV, zero problems in 2 years at 20k miles. 2 minor recall notices that have been unattended to, nothing that requires immediate attention.
    John
    I agree with Juice that Subaru owners in general probably have a higher standard when it comes to problems (it's all those detail oriented engineer and educator owners :-) I think it's also true that owner perception plays a huge role. Juice's excellent example of BMW owners proves that. I've noticed the same with Ford owners. There are literally millions of happy Ford owners who are completely loyal to their brand, regardless of the fact that their vehicles are constantly breaking down, being recalled, have pieces falling off or even rolling over ;-) The only logical conclusion is that your typical Ford owner expects far less when it comes to perfection than do owners of the Japanese import brands.
    -Frank P.
    We have owned three Hondas and one Subaru (03 WRX) with *zero* problems. Other three Subarus (00 Outback, 02 Outback, and 03 Forester) all had assorted defects or problems. Both Outbacks had warped rotors (a continual problem) and the 00 had to get a new clutch at 50K miles. So in my experience Subaru is not doing that great, but it hasn't really changed my opinion of the cars, I still like them a lot and would buy again.
    Craig
    Craig- I'm not sure I would categorize warped rotors as a defect. Some rotors may be more susceptible to warping than others but it's been my experience that individual driving style and conditions play an equal if not greater role in many cases.
    -Frank P.
    Yeah, I would put the rotors in a "problem" category. Anything that is not right at delivery I would classify as a defect (crooked trim, leaky window, etc....).
    I really think the warped rotor problem is a characteristic of the 00-04 Outback, more than individual driving style. My wife's Forester has been fine and she is a hard/late braker. My WRX has been fine, and I tend to drive that much harder than the other cars (by far). The Outback is probably the most casually driven of the bunch, but has recurring warped rotors. And it happened on our 00 (manual trans) and 02 (auto trans) so it's not related to engine braking.
    Craig
    The CEL is really just a symptom. OBD2 requires Subaru to light it up even for a single misfire. So if you have condensation in your gas tank and that water in the fuel line causes one single misfire, you're supposed to go to the dealer to reset it.
    That's true for every brand. You can thank your government for this privilege. I'd reset my ECU, thanks very much.
    As for the rotors, I doubt the metal is any better or worse, but they are halting more weight. More weight means more heat.
    Honda has always done small cars wonderfully. I think you could explain those tranny issues with the fact that they have less experience with bigger, heavier duty transmissions. Just like Nissan is having teething issues with the Armada, their first foray into full-size trucks.
    -juice
  • jazzjazz Member Posts: 15
    I'm looking for guidance/insight. I've tested two Foresters (XS with PP) and in both cases, the moonroof whistles when I hit about 50 mph. This is with the glass closed and the inside panel pushed all the way back. I called the dealer today and they told me that it is recommended that the interior panel only be pushed half way back and that would help. Also told me that getting a deflector would help.
    I really want the moonroof, but not if it's going to whistle on a windy day or when I'm any where with a speed limit above 45! Does anyone else have experience with this?
    If the moonroof is fully closed and you're getting a whistling noise then the glass isn't sealing properly against the gasket and needs to be adjusted or fixed (it shouldn't matter what speed you're going or what position the sun shade is in). I can't believe that a dealer would tell you that unless they misunderstood the problem and thought you were refering to the noise made when the moonroof is fully open at hwy speed (which can be noisy).
    -Frank P.
    The dealer has promised to check the gasket for me, and he's giving me a free wind deflector, too. I told him I'm reluctant to spend the extra $$$ for the PP, specifically to get the moonroof, if it's going to drive me nuts for the next 10 years! He promised to make it right, and I'm glad 'cause I REALLY want that sunroof.
    Thanks again for the help. I haven't bought a car in 13 years and this board, and contributors like you, made the process almost pleasant!
    Now I'll go post about the deal I got on the pricing board...
    Jazz- Well if it didn't look like you'd already bought it I would have told you to make the dealer fix the moonroof before you signed on the dotted line. I'm not saying you can't trust car dealers but they have a lot more incentive to fix something prior to the sale than afterwards ;-) I agree though that's one huge moonroof!
    -Frank P.
    No comparisons here. This is not an industry sponsored survey similar to JD Powers or others. It is an account of problems that real-time users find with their product. 675,000 customers enough ? That's what Consumer reports does, It's real. It's objective.
    No comparison with Ford or BMW or Lexus is necessary.
    The fact from customers is real and objective: problem with Subarus have increased in the past few years of ownership.
    So, what gives Subaru of America ?
    We who own your product care because of our experience. Talk with us. No fluff. No marketing stuff. Just the facts and what you are doing about it.
    Does the CR data give a breakdown on what the most common problems are? It may be mostly because of the MY1999 - 2002 2.5L engines. Surprisingly, my cousin in Switzerland told me that Subarus are top for reliability in Europe. But they don't have that engine, and I'm not sure where the Legacies sold in Europe are built.
    According to this link you can blame the engine (select Y2001 Subaru Forester from the dropdown menu):
    http://autos.msn.com/research/vip/reviews.aspx?modelid=9606&t- rimid=-1&src=ratings&tab=4#rel
  • ellengelleng Member Posts: 33
    Hi all,
    If there are any Montgomery County maryland forester owners there that know of a good body shop in the area. Please let me know. I got hit in a parking lot and have some fairly minor scratch/paint damage to my bumper. I want to get it repainted. I do not want to go to Fitzgerald's bodyshop as I don't trust the people at their service area. Any recommendations are appreciated.
    Ellen
    You can't cross-reference different sources because they're measuring different things.
    Good point about JDP - they panned the Mini Cooper for cup holders, and the H2 for gas mileage. What does that even have to do with reliable transportation?
    CR does mention the Baja as the reason for Subaru's drop overall.
    Ellen: where do you live? There are a bunch of places in Kensington on Plyers Mill Rd. and on the other side of the train tracks, I forget the name of the street. Check it out and look for a place that has a seperate paint booth.
    -juice
    Juice,
    I live in Germantown, MD. I would love some names if you have any.
    Ellen
  • ozman62ozman62 Member Posts: 229
    Joybell. What caught my eye was that even though the link indicates significant engine problems for some model years, they still give the Forester a 5 out of 5 reliabiilty rating. I guess that long-time Subaru owners may feel that there has been a bit of a slide from the legendary reliability of Subarus, but the stats still show higher than average, or at least average reliability. It all depends on one's point of reference.
    My 2 cents,
    Owen
    I think it's just nostalgia. Or plain old luck.
    5 Subies in our family and none of them has ever even once let us down.
    -juice
