-September 2024 Special Lease Deals-
I figured out 1. Instead of hitting the SEL/RESET button to toggle, like every other menu, you have to hit the < button below the ^ button, next to the SEL/RESET button. With all the other menus it cyles between the main menu topics, but it functions totally differently in this menu. Not a logical UI but once you know its fine.
I just got the 2009 pilot with the cross bars (accesory). I am going nuts from a wind-type noise (that sounds like it is) coming from the roof area... Do you think it may be the rails? Is there a way (for me) to check if the roof rails are on backward?
Edmunds Test Drive Review
Not real glowing!
I have had no hunting/seeking problems with the cruise control. It has worked great for me.
As for braking distances, I haven't done the kind of test they did, but for everyday use I have found it find. I like it even because it is realy smooth. The Highlander is much too tight and jerky by comparison. I have had to stop quickly once or twice and had no issue.
Bottom line is I would suggest anyone interested try for themselves before relying on this report. There have been other reviews that didn't note the same issues. Maybe they just had a lemon.
From the hondapilot.org forum:
LINK
Honda and Acura Owner’s Manuals
Navigation manuals are there too.
Scott
One more thing, my wife & I both have phones paired with the car. When both of us have our phones in the car, how does it know which phone to use to make a call? If I say "call" I would think it would ask from which phone. Thanks again! Scott
On a side note, our cell-phone dealer warned us against using the car charger too often, or we'd soon be stuck with charging our phones every day because of reduced battery life.
Sorry I can't answer more for you!
TheGraduate
'96 Honda Accord 184k miles
'06 Honda Accord 38k miles
2009 Pilot finishes first! However, reading between the lines, there is extremely tough competition in this category. Potential buyers should drive at least the Pilot, Mazda CX9 and Toyota Highlander before deciding. Also, highly likely that incentives will return to all vehicles in this category over the winter.
I understand it affecting the lights, but the horn? That's just ODD.
Thanks for the update Scottgbwi!
Now today, the cabin lights are flickering and some instrument panel lights are going on and off. The 'ECO' light stayed on under heavy acceleration.
Do you think these two events are related to the issue you are discussing?
I have an EX-L without the RES. I have turned the interior lighting on and off using the switch on the overhead but have not had any problems with it doing anything other than being on or off. The horn beeps on the 2nd click of the door lock function whether the dome lights are switched on or off. I'd take the car back to the dealer and show them the problem.
As to the oil change concern, I trust the Honda engineers. I've got a '99 Odyssey with about 100,000 miles and have been changing the oil every 6,000 or twice a year since new. I fully expect to have problems other than engine wear to be the cause of this car's demise. Modern engines don't cause the oil to break down so readily because much less fuel gets into the crankcase. Additives in the oil help as well.
I'm on my 6th Honda (my 3rd Pilot) and have never had a problem.
If you have concerns then spend $20 on an oil analysis. Otherwise just save your money and save some resources.
Are oil changes every 3,000 miles really needed?
My Nissan gets dead dino every 7,500 miles (or longer) just like the manual says. It's at 129,000 now and never had an oil related issue.
I wasn't really in love with any of the exterior colors but unfortunately the beige interior only was offerred on a few -- the nimbus grey, the silver grey and maybe one other. I ended up with the Nimbus Grey and its fine. I like the interior and am neutral on the exterior.
Go to 15% Oil Life, or 12 months, whichever comes first.
Best regards,
TheGraduate
I have been driving my 2009 EXL Pilot for about a week now and I love it. It is lot better than the 2006 SR5 4runner I have been driving for the past 3 years. Anyways I wanted to see if anyone had any information about some topics I want to discuss.
1) I just bought a cargo cover for my Pilot and noticed it does not fit properly. Basically the 3rd rolw seat belts get in the way and have to be moved out of the way inorder for the cargo cover to be pulled all the way over. Does anyone have a quick fix for this? Is there a latch for the seat belts where I can fasten them out of the way?
2) I am thinking about adding the 2nd row sun shades. They are about $135 each side. The parts guy at the Honda store said that I did not have to remove the door panel in order to install the shade, but after looking at a Touring model, it seems like I do have to remove the panel in order to get the shade in. Anyone have any recommendations or thoughts?
Try pointing the business end of the fob at your chin instead of at the car and see if that helps. (no, I'm serious ).
I tried unlocking all doors from the remote this morning, anf if I pressed the liftgate handle twice, it opened.
i am considering leasing Pilot 09 EXL 4wd in the next week or so. Got couple of good quotes from New Jersey and Massachusetts that can be followed through (I live in NY, queens). I understand one can service a car in any Honda service station, but what are the cons and pros leasing a car from a remote dealer and saving maybe $20 to $30 in your monthly payment vs getting it near your home?
thnks
