BMW X5 Reliability Concerns
I really like the way BMWs look and feel, especially the X5. However, when it comes to reliability, I am hearing very mixed reviews in regards to BMW as a whole. How would you current and former owners rate the overall reliability and long-term quality of your BMW? Are you happy with your purchase? Would you buy another BMW?
I've owned/wrenched on eight BMWs since 1983, and I currently own two-a 1995 318ti Club Sport and a 2004 X3 2.5.
At 105,000 miles the maintenance and repair costs for the ti have averaged @$40 per month. Prior to the X3 we had a 130K mile 1997 528i that averaged @$85/month to run.
If you are considering the second generation X5 I'd advise waiting a year or so to let Munich work any bugs out. If you want a current model I'd say go for it.
By coincidence, I'm currently looking at a 2001 X5 3.0 to use as my commuter hack...
See above...
I prefer x-drive due to its ability to shift almost 100% of the engine torque to the axle that has traction. However, the older AWD system fitted to the 01-03 X5 is no slouch. I drove an 01 X5 equipped with lightly studded Pirelli Scorpions in the 2000 Alcan Winter Rally and we had no trouble with traction,though human error was another story altogether... I'll go out on a limb and state that you could probably go anywhere you wanted in an 03 equipped with decent all-season tires. Another option would be to fit it with Nokian's WR tire, which is an all-season tire that also carries the severe winter service rating(the "snowflake on the mountain"). To sum up, the older X5s are great, but x-drive makes them even better.
I'll ALWAYS select the option of four winter tires on a dedicated set of wheels. If you are going to go that route I'd suggest checking out some of the other winter tires available on Tire Rack- primarily because the WRs are a bit pricey to buy just for winter use.
If you have experienced this, what was the solution?
Bob
Any ideas about the engine life, or other things I should be careful about?
Is reliability an issue after these many miles?
Thoughts from the guys who hold onto their cars for a LONG time!?!?
Thanks for any help!
Recall date: 06-14-2001
Units potentially affected: 14,300
NHTSA campaign number: 01V196000
Defective part or component: POWER TRAIN:TRANSMISSION:AUTOMATIC:SWITCH:SOLENOID:SHIFT ELECTRIC
Description: Over an extended period of time, abrasion particles could deposit on the electrical contacts within the switch, causing a disruption of the electric current through the contacts. If the disruption occurs when the vehicle is stationary with the transmission in the Neutral or Park positions, the transmission will switch automatically into the emergency program, which is displayed in the instrument cluster via a warning lamp and a message, (TRANS. FAIL-SAFE PROG). In this case, the vehicle can be driven in lower gears only with limited engine output. If this problem occurs, the ability to maintain speed in traffic and/or accelerate could be greatly diminished, possibly leading to a crash. Dealers will replace the transmission gear position indicator switch. Owner notification began August 14, 2001. Owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact BMW at 1-800-831-1117.
Hope it helps
I recently received the trans fail safe error and then our 2001 X5 died. The alternator and battery were replaced. The dealer said the error message had nothing to do with the alt/battery and power failure.
However, when I picked it up, the front monitor/display is blank. It occassionally blinks but nothing displays. The radio turns off after a few minutes. The dealer says that the nav system controls all the displays and that it needs replacing and then the monitor will need replacing. I don't have high regards to the service consultant as he originally told us when we picked it up the first time that the display would show back up the next day. We were stuck in traffic and didn't have time to argue but knew that it was bogus.
Any one have any advice? Does the nav system control the display? The in phone unit still works. I'm not wanting to spend $3900 to replace the nav and the display if I don't need to.
* The first year I took the car back to the dealer 6 times. 3 times for door latch cable, 1 for burn out head light, 1 for transmission position sensor, 1 for electronics problem (disarm the car can cause hazard light to blink and can easily turn it off).
* Fan blower speed control reostat burn out at 55K miles, dealer took care of for free.
* Turn signal light burn out within warrenty.
* Mass flow sensor broke at 65K miles. $$$ to replace.
* Drive power shaft was broken due to bad quality material at 75K miles.
* 70K miles, engine block oil gasket was leaking. $$$ to replace.
* Radiator water hose erupted at 96K miles. Replacement hose had better built.
It is costly to maintain. Oil service and radiator flush costs 325. 100K service is 1500. When you change break pad, all four rotors plus sensors need to be replaced at the same time, 1000.
I have been looking at the reviews of other European SUVs, all seem to have reliability issue. I don't want to turn to the Japanese (had an Acura legend for 8 years never had problem). I may not have a choice here. Any recommendation? Any experience with newer X5 models? Much appreciated!!
//Lion
Oh my oh my so many things even don't go wrong in a corolla. :sick: :surprise:
Thats the main reason why i like bmw a lot but get very tense after reading the troubles :mad:
I've settled on the X5 and the Land Rover LR3. (Please, no replies about how different the vehicles are. My only concerns are luxury and how much I like the vehicle as I live in the city and don't off-road or tow.) I had an '06 X5 that I loved and never had an issue with but, since the LR3 now has an electric steering wheel adjustment, I'm torn between which one I like better. I get a good deal from BMW because of my relationship with them but one of my best friends runs the LR store just a mile from my office and I know I can get a good deal from him too and if I do have problems, it would be closer than the BMW store, which is about 5 miles away.
I know everything about both vehicles as far as equipment, drive, capabilities, etc, however I haven't heard much about problems with the '08. I'm a 24 month leaser so I'm not really so worried about problems with 2 or 3 year old vehicles, just wondering if anyone out there has had initial problems, like I've had with my Commander since day one.
Good luck to you.
http://www.xoutpost.com/forums.html
I had a conversation with a BMW employee today, privately. His comment was that the X5 electronics is more complicated than the earlier models, still is a main problem. As far as I can remember, it has always been a problem since my 325i days. I look at as a trade off for performance!!
To follow up my last posting since Mar '08. I had
window regulator,
water pump/thermostat,
two front axle assembly (CV joints),
instrument cluster,
and DSC module replaced. VERY $$$$$!!!
It is time to say good bye to my beloved and troubling X5! Any suggestion on a SUV that is reliable and have good handling/performance? I am not keen on features, as it always brings trouble along. Thanks for reading and your feedback.
I was replying to lion2000 who I think has over 100000miles on his previous model X BMW. Check above.
Sorry but You may have gotten a lemon Bob.
:lemon: :lemon: :lemon: :lemon: :lemon:
This is anecdotal. Your mileage may vary. He was livid. That makes two of us.
All I can say is: Caveat BMW. NEVER AGAIN.
For every individual that trashes the entire brand because they had a problem with one particular vehicle, you could hear plenty of positives stories. For example, I've had six X5's and have had zero trouble with any of them (with the possible exception of the 2001 X5 4.4i, which was the first model year of the first BMW SUV ever.) Even that first model only required one warranty service visit for the entire time that I drove it. None of my other X5s ever went back to the dealer for anything other than scheduled maintenance. Of the 15 BMWs that I've owned over the years, only one had a significant problem (2002 745i) and that problem was well documented and resolved under warranty.
I have significant experience (multiple vehicles, over 200 hours of track time, cross-country rallies, visits to factories on two continents, etc) with the brand and I have complete confidence in BMW's reliability.
Then I look at the "Learn More" ad to the right as I'm typing this response and see that the 2009 X5 has an Edmund's owner satisfaction rating of 9.1 out 10. Apparently, the major issue that you're having isn't common.
You have owned how many X5s? Do you drive them all for under 18 months...are you a dealer? How in the world do you get so many cars in such a short space of time?
What were you doing at the factories?
There is automobile experiences from those who are in the business and there is automotive experiences from the real world. Why don't you try out the 2009 X3?
Perhaps not but I've only been hearing one dissenting voice. That one is more scientific? :P
SUVs and Smart Shopper
By the way, I have never owner a Ford and don't particulary care for them. I just remember at the time what CR reported.
They could have had a better name though.
While driving on highway got "transfailsafe", 4x4 light, brake and ABS lights came on. When stopped car it stalled and when tried to start was "dead" - starter did not turn. Also made some chirping electronic sounds about one second apart.
Also noticed once between trying to restart that the gauges were in abnormal position speedometer read ~20mph and tachy a little over 1000rpm even though car was stopped.
Few weeks ago similar problem but after 30-45 min the car restarted with no errors and when had it checked said found nothing wrong.
Alternator was replaced one year ago - reported tested now ok. Battery tested ok.
If this is an ABS computer or sensor problem would the starter not crank or lose electric power?
Thanks for any ideas.
/Thank you
Do yourself a favor and research before buying it!!! :sick:
Will this be another one hit wonder???
Mine: 1995 318ti Club Sport 2020 C43 2021 Sahara 4xe 1996 Speed Triple Challenge Cup Replica
Wife's: 2015 X1 xDrive28i
