Toyota Camry Warranty Questions
I am about to buy a mint condition 2004 Camry from a private seller (27,000 miles). It is still under the 3/36k warranty. How do make sure that the warranty transfers into my name? Does Toyota charge a fee for this?
How do I shop for the best price on an extended warranty for my Camry?
GedF
GedF
Extended Warranties
As for extended warranties, I'd recommend shopping around for a Toyota extended warranty at dealers. Prices are negotiable.
But your powertrain warranty is good for 5 years / 60K miles already.
You will never come close to breaking even on an extended warranty. My last car, was a ford, and I had it seven years. I paid $50.00 after the warranty was over.
They start at the same time as the regular warranty so they do not cover the number of years that they are sold to cover. I have saved many thousands of $'s by NOT EVER buying an extended warranty. I have been driving over 40 years.
http://priuschat.com/Discounted-Toyota-Prius-Extended-Warranty-Service-Contracts- - -t3130.html
My sister got pressured into buying the Platinum 7yr/100K $0 Ded. for $1,300 I thought it was kindda okay price but now on 2nd thought, it's silly buying it now when I can get it for less later on. And I heard, dealers will always find reason to deny service in later years claiming you didn't maintain it right (doing oil changes, minor/major tune-up on time etc...) or blame the breakdown is due on wear and tear.
Thanks for all advices.
You might want to check out the general Extended Warranties dicussion as well. Good luck!
I seriously believe he is taken for a ride.
I suspect there is something wrong with the information provided, or what he/she understood. Could be the charges are for services which are not covered under warranty (oil change, tire rotations, replacement brakes, etc).
My delaer tried to sell me a third party warranty at first, but it turned out the Toyota warranty cost much less and offered more protection. My warranty is valid anywhere in the U.S. (travel expenses, hotel stays, towing, gas, tire change, etc.)
If the "problem" falls under the factory warranty it is covered ata any Toyota dealership or approved repair shop. I'm not sure why they had to pay money, they didn't specify.
I guess we'll wait to hear what they have to say.
I have an 2007 Camry SE, and am about to get an extended warranty...Im deciding between a 75k or 100k mile warranty..which should I choose. I drive 25k a year, and will probably contue to drive that much the entiore life of my Camry.
What probelms, do you know that this model has, that I should wory about?
Thanks, Jackie
I have a '07 CE manual and I had the reprogram done (1/2 hour) and have zero other complaints. Most people will tell you the extended warranty is just not worth it. Just follow the maintenance guide in the owner's manual and you will be fine.
I am one of those people who happens to believe in an extended warranty on vehicles. Every vehicle that I have ever purchased, (either new or used), has had an extended factory warranty. Now having said that, I have either broken even with the cost of the warranty, or have made money on the deal! (Once the warranty runs out I trade the vehicle!)
When I purchase a vehicle, I purchase the "top-of-the-line" factory warranty for the maximum number of years and mileage. If I sell or trade the vehicle soon than expected, the extended warranty is a selling point in terms of the sale.
My Carmry will be one year old in January, and at that point I will probably have about 22,000 to 25,000 miles on this vehicle. When this vehicle is three years old, I will trade it for a new vehicle. Note: ---- I also believe in 2,500 mile service intervals for oil and filter changes. Just yesterday, prior to leaving for work, I pulled the oil dip stick to check the engine oil level. The oil was so clean, that I had a problem reading the oil level. ---- (Note: ---- I have never had to add oil between oil and filter changes.) ---- The vehicle is due for service on December 3rd, since I will be "on the road" prior to the Holidays!
Since I am on-the-road extensively, I have the warranty for "peace of mind". I also carry copies of all the service repair orders. Should something happen on the road, I have all my service records and my extended warranty, so there should be no problem with a Toyota dealer.
You will read many opinions about the above two issues. The final decision is yours.
Best regards. ------ Dwyane :shades:
As to "is it worth it," it depends on how worried you are about a major repair bill after the basic warranty expires. I've haven't had one for several Honda and Toyota cars, and I'd have never collected enough to make them worth while.
There's a reason why dealers push them. They're a high profit item.
Later
Caaz
p.s. your financial circumstances may change also. You may have a better job or be making more money and want to upgrade, or the newer model is so much better looking that comes out that you just have to have it. Then the warranty was wasted. Invest the money instead and make it grow for 4 years.
Instead, take care of the car. Change the oil, check and regularly change the fluids, rotate the tires, and drive like a normal human being, and it will last much longer than 100K without issues. (conversely, if you never change radiator fluid until the engine blows, then maybe a warranty is for you). Seriously, tho:
a) the car has a decent warranty already; if anything was gonna show up from manufacturing/component defect - it will do so under the original warranty.
b) IF you take care of the car, nothing else (significant) is going to fail by 100,000 miles. There could be some electrical/wear stuff like a battery, or starter, or coil, that might go, but so what? It won't cost $1600. Some other stuff, like a clutch, is going to go slightly over 100,000, and that still won't cost ya $1600.
Later
Caaz
What does the standard warranty cover? And what does the extended warranty cover? Where should I purchase the extended warranty from? And how much should it cost?
I've been reading up on the Accord forum. Looks like you can purchase Honda extended warranties from dealerships other than the dealership from which you are purchasing the car from. And there is a place online where you can buy Honda extended warranty for less $1,000.
Does Toyota offer something similar?
I bought a used 2001 Camry CE in year 2005. I had no idea about the separate emission warranty until now. I failed my state inspection in MA last year (Setp. 2008, around 70K miles) for the bad catalytic converter. However, i never got the check engineer on. I went to Toyota dealer and replaced the catalytic converter, which costed me $1300. I remembered that i asked the service manager if this is under warranty, and he said no.
Now (7 months later), I realized there is a emission warranty, which is for 8 yrs / 80K miles. Could anyone confirm this for me since i don't have the owner's warranty booklet? I just checked my repair receipt last night, and it stated as Exhaust System (Front). It didn't say Catalytic Converter. Is the Exhaust System (Front) same as Catalytic Converter.
Tomorrow, I am going to the dealer and ask for the money back. Is there any chance I can get my money back since the catalytic converter is under warranty?
Thanks and any inputs are appreciated.
