Buick Regal Maintenance and Repair
Ok Ive changed both wheel hub asembleys and roters and pads but the noise is still their now what are we looking at as the problem Its allmost like a nocking noise only happens if wheel is slightly to the left and not accelorating or brakeing just coasting go's away when wheel is turned slightly to the right This is a 2000 buick regal ls 3.8L non turbo with about 90,000
I own the 1997 Rag LS and the car is constantly overheating. It is running at the 3/4 mark all the time. The cooling system seems to be clogging. I have flushed it and chagne d the heater core, and radiator twice. Is this a commom occurance on the 3.8 when it hit this mileage??
How can I fix it?
PAman, "Buick Regal" #1209, 13 Jul 2001 11:09 am
I had to end of junking the car. It ran great but the overheating could not be corrected. I tried Buick even and could not come up wiht why. I changed everything. Heads radiator heater core, removed thermostat, flushed it out. nly thing my mechanic said it could be is the block breaking down. Please let me know what happens I am curious.
I have found that when the car is parked level or with the nose facing down it doesn't matter how hard it rains everything stays dry. Only when the nose is facing up does the water come in.
This happened suddenly and there was no accident, work on the car or firewall area. The interior filter had not been touch as well. I have been told that there is a "gutter" or railing that runs along the firewall that is designed to run off water to the side. It is possible that it could have fallen off.
The water seems to collect towards the center of the car but leaks out at it's lowest point, the far right side near the fender wall. I have seen discussions about this problem from a few years ago but no one seemed to have an answer. Any updates?
Help!!!!!
The other problem you might have is a leaking heater core. Is the leak water or does it smell like coolant? Does the floor get wet after a rain storm or is it always wet and smell like coolant?
Regards.
As for the sucking, don't worry about it, I put in a K&N Filter, and you can hear that thing breathe inside my house, i triple checked to make sure it was seated properly..
Time for new mechanic!
Don't know how you 'flushed it out', but cooling system isn't usually that tricky.
Changed heads?! sad.
If the beast doesn't cool properly, there has to be debris in the system, or bad water pump, or bad hose. I'd pull hoses and thermostat and flush it out with water, then compressed air.
Maybe even pull one or two expansion plugs (freeze plugs) to look for crud in there.
Also verify that it really was running hot, and not just a gauge lying to you.
cheers
Jay
So maybe the motor only goes 250,000 instead of 300,000?
Coolant loss? Probably better drain/flush system, fresh coolant and, well, I'd use stop leak.
But, I'm cheap. Look up Dex-Cool and inlet manifold problems on GM engines. It seems there can be problems with the gaskets caused by old coolant and air in system?
Good luck
Jay.
So I had this acceleration problem on the highway when I was going up a hill. And a weak idle. These problems have been going on for several months now. They were annoying, but didn’t seem that serious. Then all of a sudden, on a rainy day, the car was really responding poorly to acceleration at all speeds. I was able to drive around, but I couldn’t count on the car responding right away when I hit the gas pedal. And the car would shudder at times.
Then, I didn’t drive the car for a few days, and then it was dry, no rain, and the car ran better. So I’m thinking humidity makes the problem worse.
I have also noticed over the past few months, that the car runs best when I start it up after a few days of not running it. Then if I drive the car a few miles and let it sit for about 2 hours or so, it would idle weakly when I would start it up again. The car’s been doing that for several months now, but it wasn’t really affecting the drivability or the response of the car when I hit the gas pedal.
Now it’s gotten much worse. So, I’ve already replaced the following items myself to no avail: mass air flow sensor, oxygen sensor, and egr valve. I’m guessing the next thing to fix is the pcv valve. But I also think it might be the fuel pump. My first guess though is the pcv valve.
So I guess you have a similar problem. I'll let you know more as I learn more. Have you figured out what's causing your hill problem yet?
If anybody has any idea what could be going on im all ears!!!! :sick:
