Braggin' Rights--Your Special Car
in General
I'm sure we'd all like to hear about your special
collectible car. Could you tell us how you came to
find it, what difficulties you may have had in
restoration, if any, what you like and don't so
much like about it, and what your plans are for
other cars, trades, "upgrades", shows, etc.
Yeah, me too carnut4. I think I could put up 6 garages and fill them all....mustangs of course
Maybe a '55 T-bird....
Can ya tell I bleed blue?? LOL
I bought a Ford Festiva in 1991 as a mail room car for our business. By 1996, it had more miles on it than Gun Smoke's Kitty. So I decided to turn it into a custom. While some personal stuff held things up, I've got it about half way to my goal as a small, v-8 powered Ranchero pickup. You can see it at WWW.CNWMR.COM under pictures ("Chickie" file).
Yes, it's wierd, but my goal is to have it completed this summer and drive it back to Detroit for the annual Dream Cruise up Woodward Ave.
Questions for anyone who has had any kind of experience with customs...
1. Best way to restart the engine after it's been sitting for a couple of years.
2. If you have any tips on building a Barris type of tube grille, such as the type of tube to use, where to get it, etc. I would appreciate it.
3. Does anyone have experience installing neon accessories who can tell me if they're prone to short out or break?
Thanks and please let me know if you have pix of your custom. I'd like to see them.
thanks for the post!
Chickie
As for starting an engine that hasn't run, I'd suggest first of all removing the plugs and squirting some cylnder top oil or ATF into each piston (a few teaspoons worth in each hole). Let it sit overnight, then see if you can possibly turn the engine by hand or with a socket wrench on the crank pulley nut. Do that for a few turns, then hook up a battery and crank it without the coil attached, so as to build up some oil pressure on cranking speed only. After that (presuming you've checked the oil level), give it a try but be sure not to rev it up too high. Let it run until the oil is warm, then drain it and add a cheap 30 weight oil...run that at fast idle for 1/2 hour, then drain that and add your good oil.
The idea here is to gently free the engine in case the rings have rusted to the walls of the cylinder bores. Just cranking it dry may break those rings...
good luck with this, and take your time.
Once you do start it, don't rev it, but also do NOT let it idle. You should hold it at a steady but 'fast idle'. At normal idle, it will take too long to get good oil pressure.
47k orginal miles
Metallic Blue(original paint in good condition too)
Black vinyl top
305 Automatic
My First Car -still own it.
(not currently for sale, but like they
say anything is for sale at the right price)
Thats about it
F-
I like it, I'd love to get it out of my garage sometime this summer and take it to our local show.
I think I just might. Its fun to drive too, although its front bench seat doesn't like to hold anyone in it when going around corners
reason, and its not to keep you upright. It'll be a stark contrast when I slip into the buckets in my new cougar. I think Chevy should re introduce the Nova I can see it now the Nova2000, the way it was meant to be, it should have never turned into the Sh*@ Can car it is today(not sure if still in production), its as big as a chevette.
when i drove it to vegas for a car show-driving over to san diego-the car was in a dust storm-sand storm(wasted my front window)-sleet storm-snow storm-and finally-a rain storm(all in one day). only real damage was the window-i had a bra on the front-that saved the paint job. car drove like a champ--thanks for listening.....
Im my book you can't beat the muscle of the 60s-early 70s especially in convertible form...
