Subaru Forester (up to 2005)
-juice
This is how State Farms rates Subaru's.
Makes me like my Forester even more. I noticed they call it a Sport Wagon, but don't seem to differentiate the XT from the X and XS. Thank goodness.
Makes me rally like the OBW - best of the lot for insurance purposes.
-juice
In any case, I had an 02 L before this and went for the sealer recall. Every coolant service on the 02 after that requires that sealer to be added again to ensure the Subaru warrenty up to 100K for external leaks.
I asked about the sealer for the 04 since I was about to do the 30K service and replace the coolant, he told me the recall affected 99-02 Foresters and SOHC Legacy's only. My 04 did NOT need it.
Only suspicious thing I've noticed is a whitish residue around the bottom radiator hose, which could be from the clamp corrosion.
One other trait its exhibited since new is that in the hot weather the smell of burning anti-freeze is so strong I can't sit in traffic with the window's open.
The only thing I'm sure of is that its not getting in the oil. The rest just increases the nuisance factor. :mad:
Larry
Chuck
Even with Subaru Bucks to foot the bill, the aftermark units look way better.
John
-juice
John
Let me know how it turns out. I'm bringing my 04 2.5X (185XX) in tomorrow for an oil change and a follow-up on some warranty work that was done to the brakes (they replaced pads and resurfaced rotors, but now there seems to be an issue with the pressure). We just got back from a road trip through the Great Lakes and back, and I got heavy hot coolant smell at stops after 2-3 hours of driving.
Interestingly, my coolant level didn't budge a millimeter until about 12,000 miles. It never lost enough to warrant a top-off until right before I took it in for its 15,000 mile service. I mentioned it to my dealer, and they said it all checked out fine (nor did they mention the TSB, which I'm hearing about for the first time).
I am extremely happy with the vehicle overall, though. I didn't have a whiff of trouble for the first 15 months, which I figure is a pretty good accomplishment these days, and the dealer was fantastic about the brake fix.
You can use a sledge hammer to hammer in a nail, but it can be too much for the job and you might waste energy.
Same concept, but to a lesser extent.
The real reason to get it would be to get a more universal 2" receiver instead of the 1.25" receiver that comes with the factory unit. To me that's a better reason.
-juice
But a 2" would sway me.
Agreed, properly loaded none of the hitch options would get into trouble.
John
Speaking of overkill, there would NEVER be a reason to have a class III on a Forester and actually the Class I hitch is too light unless all you ever plan on towing is maybe a motorcycle or something very light. Don't forget hitches aren't light... Class III's weight a ton (metaphorically speaking). Go Class II is my rec...
Towing factoids Foresters
American vehicle tow ratings include what you are carrying in the tow vehicle above the base weight and below the GVWR..in addition to what you have behind you. So, you have to subtract what you are carrying in the tow vehicle. Subaru's and some other European and Japanese vehicles are WYSIWYG on the rating.
The Aussies don't have the class I hitch as standard on their version of the Forester. Towing is touted in Australia for the Suby and minimized in the U.S by Subaru. It is hypothesized that the litigous nature of the U.S. is behind this. They don't want to be sued. That may be why Subaru of America uses a Class I hitch (as standard) to emphasize they really don't want you to tow even though the vehicle is obviously set up for it. The Subaru Forester was rated the top towing vehicle in Australia in 04 per one of their big camping magazines...
The "self leveling" rear end on LL Beans is standard equipment in Australia. It is interesting that in the US, the only vehicle you can get it on is an automatic which reduces the towing rating by 400 lbs. BUT, guess what... The "self-leveling" is all in the struts. There are special struts for the LL Bean (oil based?) that can be installed on any Subaru Forester... I hear they are at least $160 apiece before installation??? I have not been able to nail that down yet, but apparently they work great.
The 50 50 ratio (very towable friendly I hear) for front vs rear traction on the manual Forester may have been done partially on purpose relative to towing.
I got this stuff by researching and reading posts from some others (multiple different people) who seemed to know what they were talking about including one who worked on Subys in Australia. He noted the differences between what their Subaru dealers are told down under verses what American dealers are told regarding towing...
I either don't understand you or I'm not sure how you arrived at this conclusion for American vehicle tow ratings. My Forester manual says nothing about subtracting the tow vehicle's load from the maximum weight limit of the trailer.
The GVWR (Gross Vehicle Weight Rating) is the amount of weight the tow vehicle can support vertically. It includes the driver, cargo in the tow vehicle, trailer hitch, and trailer tongue load. It doesn't include the trailer/cargo weight except the tongue load (less than 200 pounds)
There are other terms, Gross Combination Weight Rating (GCWR) which is the combined weight of the tow vehicle and trailer and Gross Axle Weight Rating (GAWR) which is the maximum weight supported on an axle (used as a measure of whether the load is properly distributed within the tow vehicle). My Forester manual cautions about exceeding the GAWR but never mentions the GCWR; most likely this is because the GCWR is already satisfied by not exceeding the GVWR and the maximum trailer weight.
Kevin
Apparently, from what I read, the tow ratings on American vehicles are different in that you do have to subtract what you are carrying in the vehicle.
-juice
Hope this helps,
Owen
The Hidden Hitch is a Class II (300 lb tongue, 3500 lb tow load). It is an indicated 40 lbs total weight.
The Hidden Hitch must be a very well constructed unit to do 1 1/2 times the OEM hitch but only weigh 1 more pound.
Or, the OEM hitch is very robust? but underated. Why would they rate the Forester MT at 2400lbs but only sell a hitch rated at 2000lbs?
None of the OEM parts on-line have much detail. Anyone know?
John
I don't have much experience with other hitches, so I can't say whether it looks robust enough to tow greater weight.
I do like that the OEM hitch is curved to accomodate the design of the Forester (curves around muffler, etc.)
Kevin
Did you install it yourself? It comes with the wiring kit and also the receiver?
These are all separate items with the aftermarket guys and they bring the price up to close to the OEM unit.
John
It also comes with a wiring kit that seems to plug into the existing pre-wired setup of the Forester. I then took my Forester to a local trailer dealer to install a brake controller which used some of the OEM wiring kit from the Forester for lighting. I also bought a small cargo trailer with brakes from them.
I haven't had any trouble with the hitch, receiver, or brake controller.
Kevin
-juice
'03XS MT.
John
I got a ride back to my house, got my husband to drive back to my car, and he couldn't get it re-started either. When he tried to restart it, it sounded like the battery was almost dead, cranking slow for a few seconds. Then he said he heard an arc or snap sound, and the cranking (and battery) sounded fine. But the car still wouldn't start.
We got back home and called Subaru roadside assistance and had the car towed to the nearest Subaru dealer, over 100 miles away. Talking today to the (non-Subaru-certified tech, as there weren't any working on Saturday), the car started just fine for them, and there were no computer codes to indicate anything was wrong.
The car has 29,000 miles and is still under warranty. Aside from the aggravation of being car-less in the middle of nowhere for 5 days, and then having to drive 100 miles to pick up the car, my questions are:
1)Obvious question: any idea what happened?
2) If this happens again, should I pull over and stop the car, or just keep going?
Thanks....
I-5 or highway 395 through the Mojave desert.
So despite the rave review of the Harmony tires on Tire Rack and other places, I went back to the Big-O dealer explained my misgivings. Wow, their cooperation and professionalism to replace the Harmonys was outstanding. Ended up with their Falken 329's which from all I can tell is the same tire as the 512's. So had the Harmony's replaced with the 329's plus a 4-alignment, $490 OTD with full warranties. After a week on the 329's I'm happy to report these tires are very quiet, offer a solid feel on the open highway, and handle Sierra twisty roads confidently without the squeal we all learned to love with the Geos :shades:
Have fun all.
Will it hurt the engine &/or performance? Thanks
As an added plus, the ethanol will absorb any water in the gasoline tank.
Kevin
Thank You!
-Frank
The only problem is that the radio was not turning on on the trip home: a significant problem because of the 3 yo in the back seat. This will be the fourth trip for repairs in 5300 miles. All minor though, and three dealing with the radio. Maybe I should buy an aftermarket radio.
Oh, the radio works fine today.
I've experienced on many occasions where dirty contacts show symptoms of dying batteries. Changing your batteries may have abraded the contacts enough to make the new batteries work OK for a while.
I clean the battery contacts on my key fobs and garage door openers at least once a year, and I get at least 3-5 years of battery life from one battery!
Elliot
What I would try is I'd disconnect the battery. That resets the ECU. Nowadays cars are computerized to that would basically "reboot" the brains and give it a chance to fix itself.
-juice
-Frank
Good gosh, I had forgotten I had the other remote tucked away in a hidden drawer over the years.
Thanks, I knew I came to the right place!!!
There is a groaning noise that emanates from the muffler (as diagnosed by the service technician) whenever the car accelerates under load. The noise is louder if say you are start from a stop light on an incline. The dealer says that 3 other brand new foresters in the lot have the same noises. In such cases, it seems that the noise is determined to be a charateristic of the car and no repair is done!.
Does anyone else with an 06 Forester have the same problem?
Any suggestions as to how you go about getting something like this fixed?
-juice
BTW, I read a report on the new mpg guidelines coming out of Washington. It said that small "SUV's like the Subura Forester" would have to achieve 28 mpg. Wouldn't this be a step backward for some of you?
This will make manufacturers stretch the wheelbases, watch. Problem is it sort of penalizes smaller vehicles. They'll just make 'em all big!
-juice
-juice
I have a really frustrating problem I'm hoping someone here can shed some light on. In our city there is only one Subaru dealer, and their service center is absolutely atrocious. Most recently, I had the service center attempt to repair the moonroof action.
Three service visits later, the moonroof works but now it rattles like mad even when the car is stopped, they broke the plastic wind breaker and didn't tell me, I found 5 or 6 broken metal clips on the floor of the car, the interior molding pieces they removed are loose and ill-fitting, they broke one of the interior molding pieces, left dirt and fingerprints all over the car, and so on. This is all AFTER the service center manager told me that considering all the work they had to do, I'm "lucky" they didn't break more.
I love my Subaru but the dealer here in town in ruining my car. I plan to take it elsewhere for non-warranty work, but does anyone have any suggestions on what to do when I need the dealer? Can a differnet dealer than the one I bought it from do warranty work for me?
Also, as I mentioned above, my car has damage the service center made when trying to fix the sunroof. The normal procedure would be for me to take it back to them for them to fix what they broke, but I'm pretty sure if I take it back there again they'll make it even worse. Can a different dealer repair damange another one created?
Any information anyone can provide is totally appreciated, thanks.
Absolutely, in fact I'd be willing to drive a while to get better service.
Call 800-SUBARU3 and report their incompetence. Take photos to show evidence of that, ask if you can e-mail it to SoA. I'm sure SoA would want to know where they can improve, and there seems to be a *lot* of room for improvement.
-juice
They also confirmed that what I've done in the interim is what they would suggest: take the car to a differnet dealer.
I called a different dealer about an hour a way that comes recommended, and explained the situation to them. They said they can continue the warranty work the other dealer did, although if they encounter parts that the previous dealer broke, it may get difficult (this is understandable, such parts wouldn't be covered under warranty.)
We'll see how it goes. If any readers here live in Madison, WI, I strongly urge you to avoid the sole Subaru dealership in that city, based on my experience.
http://www.dailykos.com/storyonly/2005/9/8/191146/0209
The link is to one of the best known political bloggers in America, who is converted to his Subaru.
Chat starts in ~20 minutes!
ooooh, Bob has harvested a good link from that blogger's comments too. :shades:
Indeed, some dealers are great, and we should give credit where credit is due.
My wife complained about a throttle that didn't feel smooth, they tore out the entire throttle cable and replaced it proactively. We had a Mercedes C240 4Matic wagon as a loaner when I asked for something similar to our Legacy wagon.
We were not complaining.
-juice
Can I say that my new car has a more serious vibration problem? I was trying to convince myself that there is no problem in my new car, anybody can help me out?
The vibration do disappear once the car fully starts.
Sorry for my poor English! Thanks!
Also, I'd like to share my buying price for this one:
06 Forester 2.5X Premium Option (no other accessories), automatic transmission, red color:
diving out price: 22.2K. (no tax as I am in NH)
