Jeep Cherokee and Grand Cherokee Tires and Wheels
I want to get 31's for my grand cherokee, but i'm not sure the rim size of my factory 15's. Does anyone know? It's this rim - http://www.carbodyparts.net/images/products_small/bodyparts/aly09014u25n.jpg
Do you have any lift on your ZJ? I believe you're going to need about 2" of lift so those tires don't rub the fender wells.
I just bought the Jeep and already put over 600 in it to fix some transmission issues (which I'm now wondering did the dealership screw me after reading some posts on her about related to my exact issue). I must now educate myself better on all thing Jeep it seems. Thanks for any help you can offer!!
Would greatly appreciate any help. I have 96 Cherokee Sport with 215/75R15 wheels and tires. Just wondering what is the biggest possible tire size I can put on it with the current rim size. I'm thinking getting bigger wheels, perhaps 16" or 17" and maybe 2" or 3" left kit in the near future. I've installed the K&N Fuel Injection Performance Kits (FIPK) last summer and not sure if getting a lift kit would in any way affect the FIPK. Again, thanks a million for any input. I'm trying to figure out what options are possible 'cause I wanted to have some fun 4X4 and the factory tires aren't cutting it. :confuse:
If you lift a solid 2" you can clear 31 x 10.5's no sweat.
Mid 90's have a rep for being 'fussy' about lifts... some give no complaints at 4"... some give problems at anything higher than 2".
(Probably should have this moved to a separate thread...)
William
blwllw3@yahoo.com
I would like to know what the biggest size my tire/wheels can be without lifting it. Any help would be appreciated , thanks
jerrytollison@charter.net
no better you can see the wheels stopping and starting straight line is fine at speed .i then replaced the diff oil in desperation it improved
for a day now its worse sounds like the axle is whinning its a 98 g/ch orvis its only done 74.000
im only glad that i did not purchase the new viscous coupling that was priced at £850 i get people stop me to tell me about my wheells
juddering trouble is its difficult to get good advice
so far my 4x4 centre could have cost me a lot of money for no cure.reading the forums people have changed various things but still get problems
what direction should i persue thanks
I have fixed four new Perilli 245/65 R17 ATR tires for my Hemi JGC 2005 but I noticed that they are too noisey at the inside while driving. I was told that because they are off-road hard tyres.
Can any one advise me what are a better performance and more quite/smooth on-road tyres for this Jeep. I'll be able to resell them over here with minor loss.
Your'
Ayoub
