GMC Safari/Chevy Astro Starting/Stalling/Idling Problems
I have a 1998 Chevy Astro, 156,000m this is a recent issue where if it rains heavily during the night my van will not start at all the next morning, I dont seem to be able to hear the fuel pump engaging @ Key on position, I have checked and replaced the fuel pump relay, but still the same problem persists. I am not sure what the culprit could be as the only time i have trouble is when it is very wet out, this has happenned once before after getting to work and trying to leave to go to a jobsite.
If the fuel presssure leaks down before a couple of minutes does that mean the injectors are not providing enough fuel long enough? Could their signal be dropping out too soon or are they bad. Could this be the fuel pump. I heard from another mechanic that this system had lots of problems and has been updated. He was lobbying for work but did say as you that if I am going to do the work myself that to make sure I check everything out before I invest in the updated injectors system. Last time I checked it was about $520.00 and I think its a dealer only item. This current system is CMFI on the 1995 I have. In 1996 they went to CSFI and if it retrofits (and this is the solution maybe I could find a slavage one . The bad news would be if they just changedthe CMFI and only new will work.
Thanks again...
On the Explorer I was checking the IAC valve. Since I cleaned it out(carbon buildup) the idle is doing as you describe. It does go to about 1100 before settling down to about 600rpm. It actually was racing up before. I will continue to observe this and if it continues or reoccurs I will clean it again. It may need to be replaced. The TPS (throttle position sensor also had inconsistent voltage but with this improvement it may have nothing to do with the surging/racing idle at this point.
The fuel pressure leaking down means that the fuel injectors are leaking or their is a leak somewhere in the system. The leaking injectors can cause some flooding of the cylinders, depending on how bad it leaks, because the leaking fuel injector never completely closes and squirts some fuel when it supposed to be closed. The Fuel pressure should NOT leak down, but hold the same pressure for several minutes if the system is "tight" and not leaking. Most common leakage is through the injectors, there could be one or more that is not sealing closed due to dirt in the injector or a sticking injector. In these cases, inspection and cleaning of the injectors is recommended. Other sources of leakage (not common) can be leaking backpressure through the fuel pump or and an external leak. Sometimes the injectors short out and don't open, then it makes that cylinder run lean. I'm glad I drive a Ford, you may notice that the Fords seldom, if ever, have any fuel injection problems.
On your Explorer, the IAC are common to need cleaning or replacement, poor idle is usually IAC or EGR system or vacuum leak.
On my Explorer, my 2000 V8 5.0L is starting to give me a P0401 DTC, EGR insuffient flow, so I'll be having to clean the EGR and passages, maybe have to replace the Dpfe.
Good Luck,
E.D. ISF
Its been a couple of days since I cleaned the Explorers IAC valve and the idle has been consistent so thats a good sign.
We also have a 1998 V8 5.0L and I got that code and and it was the Fuel vapor management hose that was damaged. The unit itself broke while changing the hoses.They and the valve attachments are plastic and this truck has over 200K. It would be nice if I can help you with this information.
That' nice but it's not a problem right now, it can wait a month or so until I have time to get to it. Right now we have all this Christmas stuff going on, and I just don't have time for anything, unless it's an emergency.
Keep me posted on the GMC cause Im curious at to what you find, since we've been through almost everything so far.
Good Luck,
E.D. ISF
The leakdown of the fuel pressure was evident. The psi would rise up to 64 and fall back immediately to 58. It would fall to about 56-57 over the next several minutes. It is said that this system needs 60-61psi at a minimum for proper operation. After I rule out the spark as discussed I am going to pull the manifold and have a look at this fuel injection to be sure of the dampness I see. Its so cramped in the engine bay I am only able to view with a mirror.
On our 98 V8 explorer by the way which is my wifes daily driver she has complained of a "whistling noise" for several weeks. I changed the chain tensioner and idler arm pullys, cleaned the MAF, throttle body and EGR valve, replaced all hoses and lubricated the drive belt. What else could be causing this annoying sound...fan cluth????
What is steering me away from the fuel injectors not being the reason for the NO START is the fact that you sprayed fuel in the intake and the engine still won't start, even with good cylinder compressions, This leads me to think that the ignition is the reason for the no start. The ignition needs to be confirmed before you tear into that fuel injection.
If the injectors were not working, the engne would still fire and run for a second by spraying fuel in the intake.
Good Luck,
E.D. ISF
Again there is a leakdown going on as the fuel pressure is not holding and an outside vlsual(not the most conclusive at this time)showed some dampness where it should be dry carbon buildup. So I am in the process of removing the intake plenum to get a better look. I will be looking closely at the fuel injection "spider"...one injector feeds six poppets. I am awaiting feedback from a supplier of refurbished unit to see if the regulator could just be replaced or does the entire unit. They sell a kit that includes all pieces. I really don't see any other direction to go unless you think the spark results are significant.(Please see above question...what can be done to improve a weak spark?)
Taking a while due to the holidays and the stress of moving into a new home and boy do I need this vans space. To be continued....
If you can't find the problem, you can pull the cap and rotor, or maybe just pull the whole distributor out and take it down to the Autozone Store and let them test it. They can test the module, the pickup coil and the coil output. Does yours have the coil in the distributor cap?
Here is the link to the Autozone repair info for the HEI ignition, it has a lot of information:
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1- 1/7d/1e/0900823d80117d1e.jsp
Good Luck,
E.D. ISF
Here's the link!
http://www.lindertech.com/bubba.htm
What should I be looking at now then concerning ignition. There was no mention of advice in your last post...
Please read it again:
"Your spark is too weak. I checked the spark on my 2000 Explorer at terminal #1 of the coil pack, and it threw hot blue/orange sparks up to 1 1/2 inches long. I think your less than 1/2 inch sparks is only good for a lawn mower. You had better check your manual to see how to check and test the ignition system.
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1- - 1/7d/1e/0900823d80117d1e.jsp "
#1 I said to Check the information at the Autozone website link that I posted, it has ALL the information that you need to check and diagnose the problem.
#2 I said to Take the distributor down to the Autozone Store and let them check it, because they have the testing tools to check the PICKUP COIL, check the MODULE, and to check the IGNITION COIL.
#3 You are checking the resistance of the wires and such, but you need to make sure the system components are working correctly to be sure the coil is putting out the Hot Spark that it is supposed to put out, over 40,000 volts. The specific components that need to be indivually tested are:
A. The PICKUP COIL.
B. The MODULE.
C. The IGNITION COIL.
The components can be tested with an ohm meter to see if they are in spec, but they need to also be tested with the proper electronic testers to be sure that they are performing properly. Then, the assembly all put together needs to be tested for total output. The Total Output Volts should be over 40,000 volts, there is a tool # J-26792 for testing the coil output.
The best thing to do with it is to pull the distributor out and take it down to the Autozone and let them check the whole assembly. Just be sure you have it properly in time when you reinstall it.
Good Luck,
E.D. ISF
I tested the pickup coil by (fig 12 on the auto zone site) and according to fig. 13 it needs replacing. I gave a spark with the 4terminal connector dosconnected and as well I found the new rotor I had put on after the no start problems started was also cracked...hmmm.
The testing of the voltage of the ignition module has me confused No 4"Check volts at "+" and "C" and should I probe both together or probe one and apply the other lead to ground. When I did both methods I got less than 1 volt with the KOEO which indicates to repair wire from module. These two wire swhich connect the Ignition module and the new ignition coil showed .001ohms continuity. Does this appear too low?)but they are not open. I need to do step 5 in fig 13(hopefully my spark plug testor can suffice as a test light?)
I did not change the serpentine belt when I changed the pulleys ...think I need to?
About your question: "The testing of the voltage of the ignition module has me confused No 4"Check volts at "+" and "C" and should I probe both together or probe one and apply the other lead to ground?"
Your question is about Figure 12 steps 3 and 4. If you look in FIGURE 11, it gives you the answer. Those + and C wires go from the module to each side of the coil. The coil is fed "Hot" from the ignition switch and that same connection goes to one side of the coil and also to the "+" wire. Therefore the "Hot" wire from the switch feeds one side of the ignition coil and also the "+" wire, which feeds power into the module. This means the "+" wire should always show power when the ignition is on, I would assume it should be near battery voltage. The test says it should read above 10 volts, with the connector unpluged, measure from the "+" to ground with the key on for your reading.
The "C" wire goes from the module to the other side of the coil from the power connection. This tells me that this is the wire that "Fires" the coil, by electronicly grounding at the instant the coil is suppose to fire. Everytime this wire grounds and then opens, it lets current flow through the primary of the coil, the coil builds up a magnetic field, then the instant the wire is opened (switched) by the module, the magnetic field around the coil collapses and creates the high voltage in the secondary coil. The module is an electronic switch that switches the "C" wire to ground On and Off. So to test the "C" wire, with the ignition on and the connector unpluged measure from the "C" wire to ground with the key on for your reading. The test says it should be over 10 volts. The voltage you are reading is what is coming through the primary winding of the coil. With no load on the circuit, the voltage you read should be the same or very close to the voltage you read on the "+" wire.
What you are calling in fig 13, step 5 is step 4. Connect a 12 volt test light between the Tach Terminal and ground. The Tach terminal is exactly the same connection as the "C" wire, the "load" side of the coil. They call for the light to be steady when you crank the engine, to verify that there is no votlage drop across the primary coil as it is firing. If there IS blinking of the light, that means the primary has voltage drop everytime it has load placed on it, which means the coil is bad. An ordinary 12 volt test light will work for this, the most common electrical tool that there is.
About the serpentine belt, the belt on my 97 used to make noise and would slip a little when it got wet, yet it looked ok. I put on a new belt, the the difference was like night and day, it's been perfect now for 4 years, no noise, no slip.
Good Luck,
E.D. ISF
Now mind you I had started pulling wires off to take off the intake plenum so it ran with the TPS and MAP sensors disconnected and I think it caused some codes; the Chk engine light is on now so I hooked them back up but the light is still on. I'll watch this. I did have a couple of plug wires crossed and after rearranging them the engine smoothed out. The saga continues but for now I see a bit of light....Thanks so much to you my friend. Oh; got a drive belt for the wifes' V8 Explorer.
I know why the engine started, it's because of one of two things:
1. either because you replaced the cracked rotor (it could have been leaking off the high voltage)
2. or removing the module and replacing it could have cleaned and refreshed it's connections (it could have had resistance or corrosion in the connections to the module).
Wow, So ends the Saga of the GMC Safari Van that wouldn't start! That was quite a lot to go through to find that problem, as we have been at this for over a week it seems? I'm glad the effort paid off, I was sure it would start, I was just hoping it would start before Christmas, So let this be a Christmas present to you! Stay in touch.
Merry Christmas & Happy New Year,
from Electric Designer In Sunny Florida
Wow is right but I sure learned a lot and goes to show two heads are better than one. I need to do a top end clean of this van but I am glad you suggested I hold off on the fuel investigation. I am hoping that by having the intake and throttle body extension off while running the engine is what gave those TPS and MAP sensor codes and that once I get everything put back together they should reset. I'll check those circuits anywaay just to be sure.
Hows your residential electrical? I get the idea you're an electrician. I need to install a couple of outlets in the new basement. Do they have a forum for that? I amrodslack@mindspring.com if not.
Happy Holidays to you and yours!!
Good Luck,
E.D. In Sunny and Warm Florida
You might have a gas line that is leaking inside the top intake cover. It is comon on all safari's. Aroung 250 in labor.
Step one is it not getting fuel ? Or is it no Spark ? An easy way to test is will the van run on ether (staring fluid). If it runs then the problem is no Fuel. If it doesn't then it is spark.
If so, please respond because I have 4 kids and I need my van!
93 Safari Engine Code Z. Bought for four hundred bucks 2 years ago, never laid down on me till last wednesday. best vehicle i have ever had.
Stalling at idle and low revs
It just quit on the way too work. Pulled over, looked for obvious under the hood. Nothing. Magically it restarted. I drove to work. That day on the way home, it quit. Did not restart. Got a ride home. The next day i went back to where I left it. this was 12 hours later. it started. I drove it back to work and left it in the heated garage. i will mention that temps have been just around the freezing mark, but this seems to have no bearing on it. At work I park in a heated garage where temps are around 60f. At home I park outside. I removed the doghouse, spent the afternoon poking around. Never started. Not once. This was after I drove it back to work that morning. The next day, I brought my mechanic friend in. He figured it was the fuel pump. It only seemed to prime intermittently, and the the mallet on the gas tank trick didn't really work. I had it towed home. Luckily i have a large shop where i live. Assuming it was the pump. I proceeded to remove and replace the pump, sending unit, tank (I had a brand new one laying around) and the filter. Yippee!! All done!! Its starts!! yahoo!! STALL!!
Next. Now it wont start again. I then proceeded to flight test some of my tools. Hmmmmm. Having a closer look, we noticed no fuel spray at all from the injectors when the starter is engaged. OK. Check the voltage. I have 12V at the injectors, but no pulse. I do not have a noid light but i dont think i need one. We unplugged the idle air controller. BAM!! it starts, runs, does not stall. Let the engine get good and hot, plug the IAC back in, idles down real smooth and nice. now it will restart when i Shut it off with the IAC plugged in (I should mention I had a recent oil change, new plugs, cap and rotor. And the van has been exhibiting these symptoms of stalling for a few weeks before any of that, or the fuel system work was done.)
So i had a used IAC. Tried that, seemed to work for a bit but in the end it still is stalling. My buddy works at a GM dealer, so he orderd me a new one. I drove to his place of employment this morning onmy way to work to pick up the new IAC. By then, the engine is good and hot. I put the part in right there. Idles down nice and low drove the LONG way to work. About a half hour. Never stalled once. I went out to the garage several times today and it started every time. Five oclock i got to leave. Start, reverse, STALL.
Tom the security gaurd, was watching. He found it rather amusing. I didnt, I lost it. I unplugged the IAC started it, left a strip of rubber about forty feet long in our newly surfaced indoor parking garage, said a bunch of things to Tom that even going to church would never excuse. Boy, am I ever gonna have to apoligize to him tommorow. Yikes. I dont think I have a vaccum leak either, not totally sure, but I left the van over night on the weekend, and first thing I did in the morning before trying to start i was to unplug one of the hoses (small one) from the cruise control servo. It was holding there any way.
I was starting to think this was a hot/cold engine problem but it doesnt seem to matter wether the engine is hot or cold.
Someone help.
I just had a brainstorm. Do i need to unplug the ecm fuses inorder to clear any fault codes before the ecm will recognize the new IAC? I do not have a scanner, just the little metal key. Is there any web pages that give you what the engine ligh flashing sequences are?
:confuse: :mad: :sick: :lemon:
advice.
two months later the car would slightly rough idled when the car stared but when the car engine go up to temperature the van would completely stall out. You would have to pump the gas to keep it going.
I started by replacing spark plugs, leads, distributor cap, rotor, ... but none of it made a difference.
What I had over looked was that the vacuum elbow that connects to the carburetor and goes to the PCV value was cracked. When I went to check all of the vacuum connections it crumbled. Old Car!
So I bought some tube and replaced the elbow and the tube connection to the PCV value just to be complete.
The van runs great now!
