Ford Freestyle Tires
As the stock tires wear out on our Freestyles many of us look to other brands, models, and even sizes to replace them. Let's discuss the different tires/sizes we've tried on our Freestyles and how they've affected ride, handling, and traction in the dry, rain, and snow.
Here's a pic to help get it rolling:
I don't think the FS has TPMS...
Since the devices save lives, I guess the question becomes why doesn't the Freestyle (and every other make/model) offer them?
Not necessarily "gizmos", the legislation allows for the manufacturer to use the ABS system to sense if one tire is lower. That is a pure software change.
So the mandate is not for tire pressure caps that transmit data (like Toyota uses), but rather for some system that monitors the pressure.
Mark.
The stock Continentals are indeed very inexpensive at TireRack, but these tires are cheap for a reason. They may be fine in areas with little or no winter weather, but they leave a lot to be desired in the snow belt. I really want to get higher quality tires on our Freestyle.
I'm leaning towards Nokian WRs or Goodyear Assurance TripleTreads. Both are all season tires but oriented more towards snow/ice traction than most. I live in Minnesota where it snows 6 months of the year, so this is an important factor for me. I also like the fact that both tires are H speed rated rather than the T rating of the stock Continentals. This means they are of a more robust design in order to pass the more rigorous government speed test. Even if you don't drive 130mph (can the Freestyle even go that fast?) a higher speed rated tire will offer you a greater margin of safety even in normal driving conditions.
Chad
I don't think any vehicle should be going that fast on the highway.
If you live in a place that doesn't get winter weather then siping will do nothing for you.
I opted out on siping the all-season's on my minivan, but it doesn't see much snow any more.
You are thinking of longitudinal grooves, not siping. Siping is actually composed of many horizontal, across-the-tread cuts, very thin as if with a razor blade. They provide more biting edges to help break up boundary layers of ice/water/tire.
First time I ever had to replace OEM tires so quickly...FORD is going down the tubes and the Freestyle experience is showing why.
The Pirellis are speed rated, you would be lucky to get 30k out of them.
The Conti's are cheap tires and definately you don't want to get a second set of them.
Mark.
A couple of thoughts about the longevity of tires; Just because a tire lasts a long time isn't necessarily a good thing. Some tires last forever because the rubber compound is very hard but that correlates to poor grip, especially in the winter when cold temps harden the rubber further. This is why I try to stay away from 60 to 80 thousand mile rated tires. Plus rubber hardens with age anyway even if the car isn't driven much. So unless you are driving 20,000 or more miles a year an 80,000 mile rated tire will get hard and noisy and practically unusable long before they wear out.
The other end of the spectrum are the 30,000 mile tires like the OE Continentals, but they are are a pain since they have to be replaced so frequently. I believe the happy medium is a 40 - 50 thousand mile rated tire. They get replaced just often enough to keep the rubber fresh but not so often that they are a drain on your bank account.
One other thing that hasn't really been discussed here. For those of us that have AWD Freestyles we must replace all four tires at once to prevent uneven wheel speeds which can damage the AWD system, and we should rotate our tires frequently to keep the front and back tires evenly worn. This isn't as important for FWD Freestyles.
- Chad
The Freestyle with that
We are about to embark on a 2,600 mile road-trip across the northern tier of the US and into the Rocky Mountains. I'm certain by the time we get back in a couple of weeks I'll be able to make a full review. So far the only difference I've noticed is the ride is a bit firmer than with the stock Continentals, but that is to be expected when moving from a T to an H rated tire.
I got the Goodyear Assurance ComforTread. Not a lot of choice in the 18" wheel size. It seemed to be the best value I could find in that size. I didn't want to go back to the Pirelli. I paid $125 per tire after shipping from TireRack. I highly recommend TireRack.
As for the tires, I am very happy with them. They are quiter than the Pirelli's and I haven't noticed any handling differences. According to the tests, they don't handle quite as well as the Pirelli's but their results were so close that it will be hard to notice in real world driving. The tires are warranty'd for 70000 miles. Yes, they have a "B" rating for temp, but I don't expect that to be an issue as I don't heat up my tires with the type of driving I do.
Mark.
Tirerack RULES!
These tires have a 60,000 mile warranty and are H speed rated (up to 130mph). Because of the higher speed rating they have a stiffer sidewall and are more robust than the stock Continentals. This results in a more firm but not unpleasant ride. I have also noticed a slight decrease in gas mileage, about 1-2 mpg. I'm not sure how much of this is the tires and how much was the weather, speed, and how loaded our vehicle was.
In the snow they performed well, not as good as a true snow tire, but well enough to be passable especially with the Freestyles AWD. On the dry they handled very well and gave the Freestyle a more sporty feel than the stock tires. In wet conditions the tires gripped the road well and the tires were always quiet.
The only thing I was disappointed in was what seems to be poor ice traction. We encountered several areas of icy roads and I had very little traction. I can't say that the stock tires would have been any better since not much except true ice tires with a special compound work well on ice.
Overall I would recommend these tires for anyone looking for a 60,000 mile all-season type tire for their Freestyle. Cost was $108 each.
- Chad
Whether or not the stock tires will work off road for you depends on what you mean. Is it a gravel road? Then fine. It is going to be rock crawling on big boulders and digging through deep mud. I don't think so.
This vehicle is leased and it is the third time I have leased but only the first time I have had to replace tires before the lease expired. I am not so happy. I have much higher expectations of tires than 55,000 km. Is this all we should expect from OEM tires?
My 99Volvo at 166,000 km. Ran summer (V rated Michelins) and winter (Gislaveds) to 130,000km, replaced the summer then but still running the same winter (they will be retired this winter).
Ran my 01 Sabb to 95,000km (V rated Michelins) and sold the car with considerable tread remaining (also ran winter Pilots for about 1/3 of that mileage).
Ran my 99Isuzu to 75,000km and turned it back in at lease end with no tire penalties.
So, it is just my experience that 55,000km is low.
I see 25k-35k miles as just about right for wear and a compromsise between life and performance. I do the winter switch as well on my wifes car for the commute so with the 2 sets you are stretching your investment out...
Mark.
Is the dealer (or tire shop) diagnosing any specific wear patterns that would indicate something wrong with the truck (eg, alignment as suggested?) Or are they getting unusual service - road condition, temperature?
I know it can't be from doing brake stands or burning rubber at the stop light
What sort of wear did you have at 11K and then 13K miles on your tires that required replacement? Was it even wear, one side, etc?
