Lincoln LS random misfire
I have a 2000 Lincoln LS with random misfire problems at low idle. I have reviewed the postings in the read only section related to this issue, and it seems exactly like what I am experiencing. Problem is all of the recommendations have been tried. Car is better but still misfiring.
Main problem is that I cannot get the computer to register an misfire codes and it is clearly misfiring. Any thoughts or suggestions?
OK here is what happened:
I was driving down the road- around 55 mph. The ABS light came on, then my radio stopped working, I tried to roll my window up and guess what? You've got it, the window wouldn't go up, the speed odometer wasn't working. The whole control panel was off.
The next thing I know is... I'm giving the car gas and I can tell its not running.. it kept cutting in and out.. eventually it just died.. with me driving down the road. I had to coast into a gas station! And then while at the gas station, the security system kept randomly going off and wouldn't stop!
Does anyone have ANY idea what could be wrong? A friend tried jumping the car off, thinking maybe it was the battery, but that didn't help.
I've had so many problems with this car.. blah, I could just cry.. its so expensive to get this thing fixed.
Connie
I made an appointment with the dealer today. Monday is the earliest date they have but I don't even think the damn car will make it until then. Today, it was hesitating and stalling so badly, cars were going around me. It was so shameful. It smells of rotten eggs, shaking so badly, and barely moves when I give it gas, until it has revved up to about 3000 rpms. The engine was squeaking and sound like an old beat up pick up truck. All this, from a Lincoln? I am too through! I had to leave the thing at work. Couldn't even make it home....
How many miles on yours? How long have u had it? What year? Maintained well? Who swapped the plugs etc? Dealer or shade tree mechanic? If dealer and they didnt mention possible oil leak being the problem, you should push back hard. OTOH, if you're having Joe Palooka work on it, well, ...
The problem is the PCV lines become old and damaged causing a vacuum leak and that is why the car idles rough and dies.
It should cost a total of $500 dollars at a lincoln dealer and here are the part numbers and descriptions:
3w4z-6767-ca connector
f8cz-9e499-ba connector
xw4z-9h486-ac gasket
xw4z-9439-ad gasket
Rough idle without the oil leak or bad coils could be a vacuum leak.
The stock inner gasket will fail and allow oil to leak down to the spark plug tops, which causes the coils to discharge voltage not only to the spark plugs but to the cylinder head (through an oil to ground short). Voltage will be lost at the plugs as a result of this short, and the check engine light can be intermittently tripped. This situation can also cause the coils to fail (on the diag).
Dealers will want to replace the 'faulty' coils and plugs, make quick easy bucks and wait for the whole shebang to fail again, due to the real problem of oil pooling at the plug/coil interface due to the valve cover gasket problem.
The real fix here is to do the valve cover gasket job using FELPRO (problem solver) gaskets. The felpro kit comes with an inner gasket that has multiple sealing ridges to prevent inner gasket failure. The stock inner cover gaskets don't have this feature.
So: remove air intake plenum, remove valve covers/coils/plugs, replace with new plugs, install new felpro gasket set/covers and tighten, check coils OHM reading between poles (any that don't match the others replace), installl coils, retorque valve covers, install intake.
This should do it. Works fine on my 2000 LS V6 Sport.
FELPRO gaskets are by far the best on the market for any engine. Buy them and have the dealer do it if you don't want to tackle this project. This should/will 'permanently' solve the problem.
My dad has the same 2000 LS V6. I just verified the oil fouled plug wells in the two rear cylinders (#5, #6) just like the P-Codes indicated. I am about to purchase the fel-pro gasket on-line, but did not know if they come as a pair or just one gasket (also getting new Motorcraft plugs). They seem very expensive. Could you please help me with a part number and where to get them for the best price? Finally, do you recommend keeping the same coils (no oil contamination) or getting new ones? I am not sure on what the typical life-span for coils are. I do not want to got through the trouble of messing with the intake plenum again! Thanks!
2000 Lincoln LS V8 Sport
Thank you for the information. The Cadillac shop replaced coil 2 last week. I dropped my car off again yesterday. (Today after some pleding to fix my car right, they told me they really cant service Lincolns that well) Yesterday I was told I had to replace the remaining 7 coils to solve the problem. I read your information and called them this morning..I even faxed them the text you wrote. I told them I wanted them to locate the leak. Well, at 4pm I called them and they said the car was ready. They only changed the coil. I asked if there was oil and they said there was oil all over the place. I told them "it wasn't ready if the issue with the leak and gaskets were not resolved" along with a few more choice words. The manager called a FORD rep and there is a recall on the Tbird for the exact same problem. No recall for Lincoln. And there is a tech at Ford that knowns how to repair the issue. I'll be taking my car with that tech along with the word FELPRO. It's a great car just having a bad patch! Thanks again I know you saved me much time and money. (Pending Ford tech doing the job right. :confuse:
Do you know if they make a FELPRO gasket for a V8 LS? Im having the same problem with my car, I pulled the plugs out and they were drenched in oil. Dealer wants 80 bucks for each gasket which i think is a rip off.
The valve cover gasket is leaking oil which gets into the spark plug wells and that contributes to the COP failures (but isn't necessarily the primary cause). It does need to be replaced and yes, it's common but once repaired should not happen again. I'd have all the coils replaced while they're in there.
ONLY OTHER PROBLEM WITH CAR IS SOMETIMES MY STEERING MAKES A HUM OR SQUEAKING NOISE WHEN STEERING AT LOW SPEEDS OR JUST TURNING THE WHEEL, I PUT IT ON MY CAR LIFT TO TRY TO FIND THE PROBLEM BUT IT NEVER DOES IT WHEN ITS IN THE AIR, IT DONT DO IT ALL THE TIME, JUST WHEN MY GIRL FRIEND IS WITH ME IT SEEMS LIKE! I THINK IT DOES IT ON REAL COLD DAYS WORSE THAN WARMER DAYS, ANY HELP IS GREATLY APPRECIATE..
The steering noise sounds like the power steering pump. Check the fluid level and if it's low look for leaks around the hoses.
ON THE STEERING PROBLEM, THE FLUID LEVEL IS RIGHT ON THE MARK, IT HAS NEVER GONE DOWN OR BEEN ADDED TO THAT I KNOW OF, I DID RECALL THAT IT DOES IT ON DAMP OR RAINY DAYS MAINLY, WHEN ITS DRY OR SUNNY OUT, IT DONT DO IT, I DIDN'T REALLY WANT TO TAKE THE CAR TO A DEALER, I ALWAYS SEEM TO GET BURNT BY THEM, I GOT A NICE SHOP WITH A LIFT BUT IT NEVER DOES THE PROBLEM ON THE LIFT OR WHEN IM READY TO CHECK IT OUT, COULD IT BE A BALL JOINT OR TIE ROD ETC, IM HOPPING ITS NOT THE PUMP! HAS ANYONE HAD THIS PROBLEM AND KNOW WHAT IT WAS, ITS ALMOST IMPOSSIBLE TO KNOW WHAT THE PROBLEM IS WITH OUT SHOWING YOU THE CAR OF COURSE.. BUT MAYBE NOT... IM JUST TRY TO SAVE A LITTLE MONEY I GUESS..
BY THE WAY, I CAN ONLY GET 19-21.5 MPG HIGHWAY OUT OF THE LS, IS THIS NORM OR DO YA THINK THERE COULD BE A PROBLEM. IT GOT THE 6 CYLINDER IN IT, WHEN PURCHASED, DEALER SAID IT WOULD GET 26MPG HIGHWAY NO PROBLEM. THANKS AGAIN.
BY THE WAY, THOSE AUTO ZONE GASKETS WERE THE FELPRO BRAND, I COULD HARDLY BELIEVE IT, I WAS JUST EXPECTING SOME CHEAP OLD GASKETS, THESE LOOK REALLY GOOD, THANKS AGAIN.
I have a 2000 ls and at idle it has an occasional miss, It runs great, but if I keep it in park and rev to 3000 rpm it totally misses, BAD. it drive fine on the road, and never notice it on the freeway.
What could this be?
Tony
As for the intermittent miss at idle, my guess is that you have a coil going bad. If so, it will get worse. Your dealer can do a stress test on the coils and determine it that is the problem. Another problem could be a dirty injector.
Best to you!
thank you for the insight. I am looking to my this used and I noticed the very slight miss on the test drive, so I pulled over and revd the engive only to notice the bigger miss. I just dont' want to buy something that is going to be a lemon, it has 82,000 miles and is in great condition along with service at the dealership religiously, When I asked the sales person, he just looked at me like I was crazy. Is there anything that you would suggest to really take notice of?
Thank You,
Tony
It may be something simpler but why buy a car and then have to begin diagnosing a problem? The salesman probably wouldn't know a misfire from a can of beans. If you can get the service manager to confirm the miss, you could make an offer subject to it being corrected. A good dealer doesn't want to sell you a car with a problem.
Thank you for the valuable advice.
Tony
