Jaguar X-Type: What's the Best Gasoline to Use?
 Mr_Shiftright
                    Member Posts: 64,481
Mr_Shiftright
                    87 octane? Premium? What works best for this Jaguar?
Regards:
OldCEM
I have noticed no difference in mileage or temp of engine. The rather crude OEM guages would make that a rather difficult task at best anyway.
I do add a quality fuel inj. cleaner to tank every 10,000 miles, and regular oil changes at 3-4,000 miles.
Hope this helps.
with a 7qt oil pan that is a complete waste of money and oil. I have gone every 10k between oil and filter with Mobil1 and the engine has 95k and still gets 32 hiwy mpg @60mph and usually a 28 combined overall
as far as the gas goes I would stick with atleast 91 octane. these engines have a type of vvt system that will actually be deactivated if the ecu senses too low an octane of fuel. if the butterflies in the intake do not open and close often enough they will stick and become useless and the engine will run like crap
You can't harm your engine using pump gas, say 87 or 89. What changes is your performance. The car will be more sluggish and you'll probably press on the gas more, thus negating the money you saved using lower octane! :P
