Pontiac Sunfire Headlights
in Pontiac
My girlfriend has a 2000 Sunfire and the lights are terrible. We drive with the high beams on all the time and still can't see 15 feet in front of the car. It's getting dangerous, especially in the rain. Does anyone else have this problem with their Sunfires and what do I do to fix it? I'm not sure if the lights are getting dimmer, or if I just need to adjust head lights.
How do I adjust the headlights?
Thanks in advance
Thanks in advance
The headlights no longer come on when I turn them on. The reduced beam comes on when I put the car in gear, and the high beams come on when I pull on the wand, but go back off when I release the wand.
Have checked the two fuses marked headlights inside the car, and all fuses under the hood. And, I work nights, so really need the headlights.
Anyone got any ideas?
Turn off car.
Pop the hood.
Remove enough of the the long black plastic covering that stretches across both headlights (It unscrews or requires the removal of plastic, breakable plugs) so you can get your hand underneath.
Remove the next cover.
Reach underneath, to the back of the headlight, and unscrew the nob holding the headlight in place.
Disconnect the headlight bulb, put in a new bulb, and screw it back in.
Try to aim the headlight as well as you can by pointing it at a wall.
Try putting the plastic covers back on. You should be OK as long as it's still attached.
Owner of a bright red 1996 convertible, 2.4L, and 5-speed.
Today a woman at work told me how much she liked my car.
Go Seminoles!
Had to change the headlight switch. About $180, if I recall.
This is, quite likely, an overloaded circuit breaker.
Headlight bulbs are usually protected by circuit breakers rather than by fuses. These circuit breakers reset after a brief cool-down period.
You probably need to take this car to a competent auto-electric shop and have them look at it. I'm guessing that this is a wiring problem.
Tom
this way I can tell those who have one this is issue and stop paying big coin to dealership for their mess up to begin with.............btw easy fix........get crimping hose and wrap wiring with it and the chances of reoccuring are gone
ClaireS, Host
Automotive News & Views | Coupes & Convertibles
The fix has previously been a wiring problem, though my mechanic did not tell me where the shorts (or loose ground) were found, other than they think it was near the battery.
Any ideas where specifically I should look, and what to look for?
