Ford Mustang Engine Problems
I have a ticking noise coming from the engine, it is worse when I first start it in the morning.
I also have a problem that when I accelerate hard it will sometimes hesitate before taking off. This especially a problem when passing someone.
I have an 02 GT that suddenly developed an odd desire to cut the engine at idle and under normal driving conditions. After driving it around for about an hour the engine just cut off. It sounded like it was trying to crank but wouldn't turn over. Came back an hour later and it started and ran fine. Prior to this I had gotten gas at a station I was later told sold bad gas to a family member and the cut off issue start when the tank was getting low. The next day it cut off shortly after starting and twice on the way to the dealer. Of course once they had it it wouldn't repeat the problem and it made it home fine. Their computer showed nothing wrong when the checked it. The fuel filter was replaced at 35K and now has 68K on the car.
It almost sounds like the engine isn't getting gas when i try to re start but that's just a guess. Alternateror and battery are good although the plugs should be replaced.
Anyone heard of this issue before or is it likely bad/dirty gas mucking up the filter? BTW I normally get 270 miles to a tank before i need to think about refilling but oddly this time around my mileage was in the 220's where it normally in the 270 range.
Use the OEM recommended spark plugs. If you haven't removed them for 100K miles or more - be careful. You really should replace the plugs every 60K or so just to keep them from melding with the block.
Mark
Thanks woody
Not sure if the head gasket issue was ever really resolved but in the early 90s, these engins were blowing up like crazy.
Do a search through the forums.
Mark.
All advice is welcome.
So, what evidence is there of a leak?
I got a 1999 , first year of this body style with 107,000 and dont have a problem. But has it ever been over heated?
That's what I thought but apparently it does. Do a google search.
Thanks in advance
