Subaru Impreza Transmission Problems
in Subaru
Discuss Impreza transmission issues here.
I have a brand new 2006 WRX sedan Ltd. (bone stock) with around 1800 miles on it. I have noticed that shifting from 1st to 2nd and again from 3rd to 4th at high RPM (greater than 5000 RPM), is not really smooth or quick. I have to be really deliberate with my shifts and have to find the exact angle, else it just doesn't fall into place. I don't see this problem when shifting in less spirited driving and also, shifting to 3rd is always smooth and quick.
Has anyone else noticed this problem? I was a really good boy during the break-in period of 1000 miles so I don't think that should be the problem.
Many thanks in advance for your suggestions.
I have most certainly not abused my car by any stretch of the imagination! Looks like I need to take it to the dealer and see what he says....
YES. YES, YES. It's a great thing. You need a bit more force when shifting, especially low gears, but boy, is it worth it! I have 50K on mine and love every ride!
2018 430i Gran Coupe
I have a shortened short shifter and bushings...maybe I went too far.
Not sure what the problem was? Dirty electric connections (in his case he spilled soda near the gearshift)? Once it warmed up a little it seemed to work.
Bob
patrick
-mike
is this a transmission problem?
i need to get this sorted out quick before my warranty is up.
I was having some cold weather issues and occasional grinding from 3 to 2, both of which were cleared up after the oil change.
Check the oil level and condition. I'd change it regardless. You will probably need a long tube and a funnel to add gear oil after you drain it.
-mike
drivelike, if the gear oil has yet to be changed in the car, perhaps it is just not providing the same level of performance it once did. A fluid change is inexpensive and is probably due anyway. If this does not clear up the problem, then you might start to look at a possible transmission problem.
Do you access to an ODBII code scanner? They're $99 or so nowadays. Ask around.
I have one you can borrow if you're in the DC/MD area.
Basically it lets you read the error code to get specific symptoms. It tells you why the check-engine light went on, basically.
Seems as though other users have posted about a similar problem with their cars; typically '99s for some reason, if I recall correctly.
How many miles on the car?
You might consider looking at cost of a rebuild/replacement transmission to determine if you want to proceed with this car. A solvent flush is, I would guess, about a $300-500 job. If it does not clear up your problem, then there is only the expensive option left.
Search the forum for this problem. I am not sure where you will find other discussions on this, but I would shoot for the "problems and solutions" threads for the various Subaru models (especially Legacy/Outback) as they all used to be lumped in those single threads.
so a transmission problem then? this bothers me quite a bit as it's a 2006, and definately not my first manual transmission.
i'm at 34,700 miles so i've only 1300 left on my warranty if it is a trans issue, and if they don't try to tell me it wont be covered.
at any rate, car goes into the shop tomorrow.
-mike
:confuse:
-mike
Motorsports and Modifications Host
-mike
I have 1996 Impreza 150,000 miles, AWD. 2.5.
Lately the automatic gear shifter will not click right away out of park.
When I grasp the gear shift and try to depress the button, it won't go and there is a clicking sound coming from near the steering column. Sometimes I can get it to move by a subtle shift in pressure on the button, and then it's fine. I have noticed that it has been happening only in the morning after the care has been sitting all night, and now in the cooler am temperatures.
Any suggestions welcomed.
I'd start with replacing the button, seems like a bad connection inside.
-mike
I have a problem that I hope you guru's can help me out on.
I have a 2000 stock impreza rs automatic 52K.
I was told my brake lights were out by a cop a week ago.
I came home last night and and put it in park. let the foot off the brake and it starting rolling in reverse. It was in reverse (even though the shift lever was in park). I could gas it and go in reverse. I turned the key off but it would not turn all the way off as it was in gear. The lever was in park.
Played with the shift lever now it locks in park and can only be unlocked manually. If I push the button on the shift lever I can hear a click for every time I push the button. It comes from a realy or switch on the left side of the steering column by the turn signal lever.
Play some more and the car started up, put it in gear and she rolls in every gear including reverse and park. Play more and it goes to park and won't unlock. you have to manually unlock the shift lever. Once unlocked it still wont start as it thinks it is in gear. The more I mess with it it seems I get a different sympton.
As of now I have the steering column and shift consule exposed. I will include a pic of the switch that I can feel clicking every time I push the shift button. It is the one with the red and black wires going to it.
also with the key out I can hear and feel the intergrated module clicking on and off. the little light that is under the automatic shift lever cover that shows which gear you are in blinks in harmony with the clicking of the intergrated module.
As it sits now it won't go out of park and it won't start and all of the above mentioned.
Is there anyone that knows about this or what the problem may be. I replaced the stop switch as this is what happened to another car of mine but it did not help this on. Please help. This occurred Jul of 08 and I threw it in the corner of my garage and forgot about it till now.
Thank you for all your help in advance. Sorry I had to be introduced this way but I'm in a bind as I cant tow it or drag it on a flatbed as it is in gear. Thanks again.
Joel penth2o_1@charter.net
advice? the miles are ticking. how much would replacing a neutral safety switch, or adjusting it, on a 2005 impreza outback sport generally cost? And where is the switch actually located on that particular model??
I would go back to the dealer that sold it to you, or take it to an indy mechanic you trust. The 2010s are out so that car is well past the warranty. Some used cars come with a 30 day warranty from the dealer that sold it, though, if that's the case.
I have regularly served the car and the mechanic that looked at the car so far said the transmission fluid didn't look too bad. That mechanic was not comfortable with the car and suggested taking it to a dealer for a diagnostic. I will be doing that unless I can locate a recommended local mechanic before then - Cleveland / Akron area.
Looking online, I found out that this is probably a ECU P0732 - Gear 2 Incorrect Ratio
Calling the mechanic I usually use in Brooklyn know who's Subaru, he thought it was just a speed senor. Mechanic in Ohio wanted to replace the transmission based on the same info.
