Honda Civic Hybrid Dash & Instrumentation Questions
Has anyone had the IMA battery level gauge on their Hybrid show more than six "units"? The gauge on my recently acquired '06 Hybrid usually fluctuates between four and six "units" but has never risen above six, even after a few hours of driving.
Cheers
For the first 8,000 miles (12,800km) after the Maintenance Required Indicator is reset, it will come on for two seconds when you turn the ignition switch to ON (II).
Between 8,000 miles (12,800km) and 10,000 miles (16,000km) this indicator will light for two seconds when you first turn the ignition switch to ON (II), and then flash for ten seconds.
If you exceed 10,000 miles (16,000km) without having the scheduled maintenance performed, this indicator will remain on as a constant reminder.
Your dealer will reset this indicator after completing the scheduled maintenance. If this maintenance is done by someone other than your Honda dealer, reset the indicator as follows:
1. Turn off the engine.
2. Press and hold the select/reset button on the instrument panel, then turn the ignition switch ON (II).
3. Hold the button until the indicator resets (approximately ten seconds).
The following is NOT in the Civic Hybrid Owners Manual:
NOTE: The select/reset button is the one you use to view the Main/A/B odometers. It is located below and to the right of the speedometer. Also, if you look at the ignition switch you will notice the three positions are marked I, II and III. If you start the car while performing this procedure you turned the key too far. Turn the engine OFF and try again stopping at position II. Hold the select/reset button long enough and you will be rewarded by the light going out.
Alternatively, a small piece of black electrical tape may be used to cover the indicator light. (Just kidding).
Kevin In CT
2006 Civic Hybrid #2
2003 Civic Hybrid #1 Sold in 2003 with 50K miles for $13K
I should mention, I've taken it to the dealership a few times about it and they either "can't reproduce the sound" or want to charge a bunch of money to just find out what it is.
Also, I've taken everything out of the glove box and tightened screws and bolts in the door and anywhere around there that i can find. So I know it's nothing of mine rattling around. (that's another thing they tried to tell me is the cause of the noise.)
I brought my Honda civic 2003 hybrid to MIDAS for oil change/front break pads change and since then the current fuel mileage display stopped working.
Reading the manual you can supposedly turn it on/off by pressing the reset button 10 seconds with the key on position "II", which is also how they did turn off the maintenance light. Unfortunately they tried everything to turned it back on but the instant fuel mileage indicator refuses to show up.
Any suggestion? This indicator is really useful to save gas.
-Chris
It is in the shop now and Honda says it in the "ABS control" and they should be able to fix it?
But they heard it! It was not an auditory hallucination on my part.
