Visitor Agreement.
With its bloated weight, it competes more with the Toyota Highlander and Honda Pilot than with the RDX and CX7.
Is the PCM flash a mid-term update ? Has Mazda included it in the service bulletin to apply on all CX-7 ?
I took out a rental last weekend with 14,000km on it and I did notice some sluggishness in take off, same as in the test drive I had many months ago when the CX-7 first arrived at the dealership.
I am not sure if my rental has the PCM flash yet, and I am wondering if I buy a new one now, would it be any better ?
The engine is not like a V6, where you will feel all the ponies right away. With the flash, the power delivery is more smooth, and you do not really feel the lag.
Rumor has it the 2008 CX-7 will run on regular as well...
Vince.
Take a look at the 2007 CX-7 Spec deck, you will notice it says "Required Fuel...91 Octane (Premium)" The 2008 CX-7 says "Fuel Recommended...91 Octane (Premium)"...Big big difference.
So Aviboy, what do you attribute to the difference in the language? Could it be that Mazda has modified the engine so that premium is recommended vice
required?Or could it be Mazda isn't going to modify the engine but the engineers and management have determined premium isn't as critical as they originally surmised?
I have no insight at this point, just conjecture, but it'll be interesting to compare the specs between 07 and 08.
Vince.
So, how do you like the RDX? What's the feature you like the most?
Later, Vince.
There has been a lot of chatter on the net about Mazda re engineering the engine to run on regular, with no issue of preignition. What exactly they are doing? I do not know, I am not an engineer.
Has Mazda officially announced this? No. But there has been loads of talk about it. This is why I originally stated "rumor has it..."
http://www.mazdas247.com/forum/showthread.php?t=123666102&highlight=cx-7+regular- +fuel
If running on regular means a loss of 30hp I wonder if anyone would want to do so.
BTW, are there any other change in the 2008 model ?
Ride
Both are firm, but the CX-7 is more compliant and comfortable. The RDX is a bit jittery on less than perfect surface that you feel every bump.
Acceleration
CX-7 is sluggish off the line; RDX is smoother when accelerating from a stop and in stop-and-go situation. Once rolling, however, CX-7 is smooth and has strong mid-range power. RDX is also strong but feels busy like reviving a typical 4-cylinder whereas CX-7 is muted like a V6.
Handling
The steering on RDX is lighter, and so is its gas pedal. Together with a more up-right driving posture, it is much easier to drive around town. CX-7 has heavier steering and gas pedal - good on the highway - but takes more effort and feels heavy in parking lot and other tight maneuver. I would describe RDX as a city warrior and the CX-7 as highway cruiser.
Seating comfort
Seating is more up-right in RDX as in most SUV's. Inside CX-7 you naturally sit more reclined as in a sedan, and the front seats (leather) are very comfortable. The rear seat cushion in CX-7 is a bit low whereas the RDX is chair-high and provides more thigh support despite a slightly uneven floor.
My personal opinion
I drive a lot in the city so I like the light and easy maneuver of the RDX and its smooth launch. However, the ride and the mid-range performance of CX-7 are more refined giving it a more luxurious feel. The large windshield and the low dashboard give the CX-7 a panoramic view and together with the comfortable (leather) seats it feels very satisfying sitting at the front, especially as a front passenger. It's tough, but if I have to choose between the two, I think I will pick the CX-7 for its style, more composed ride, and the great satisfaction sitting inside and live with its less than perfect launch and heavy maneuvering in the city.
What were you thoughts on the interior, i.e. materials, lay-out, technology?
Vince.
The models I drove did not have navigation nor did I have time to try it out, so can't comment on the technology. In my understanding RDX has Blue Tooth and CX-7 does not.
I used to like interior of the Murano a lot (the low dash and the wide windshield), but now CX-7 is my favorite. :-)
There appears to be a hesitation in the shifting from the 1st to the 2nd gear within the first car-length when you accelerate gently from a stop. Also, when you slow down, it drops to the 3rd gear and stays there until it comes to a full stop (and then it switches to the 1st gear). The problem is, when you put your foot back on the gas just before coming to a full stop, it's in the 3rd gear, and there's another hesitation in the kick down to the 2nd gear.
I had similar experience with Mazda6 before, though not as pronounced - not sure if it's because of the turbo engine on the CX-7.
Just wondering why Mazda cannot do as well as others in this regard, especially the RDX which also uses a small turbo engine.
Thanks again.
In manual mode, I can get the engine into 5th almost immediately and it pulls exceptionally well at all but the slowest speeds. Can get into 6th as low as 38 mph, but of course there isn't much power in 6th until well over 60 mph.
1. Both have some amount of turbo lag which can be easily avoided once you get used to it. Surprisingly with CX-7, I felt a slight less lag maybe because its a 2008 model and Mazda has done something about it.
2. RDX's engine is much more smoother and refined. It is also less noisy when pressing the gas paddle from a stop.
3. Interior is good in both, however in CX-7 I felt a little bit cramped, especially since the center console is little forward towards the driver. CX-7 has more plastic, but the plastic looks and feels good. It did not give me a cheap feeling though I would agree the RDX interior has better material but the center console layout is not as clean as CX-7. I liked the steering and the visibility of the gauges better in RDX. In Mazda I felt the gauges to be kind of hidden behind the steering wheel and the temp/radio display a little closer to the driver than the RDX. Since both has steering wheel mounted audio controls I would prefer the display to be closer to the windshield to give a comfortable view while keeping an eye on the road.
4. CX-7 had more passing power especially from 40 to 80 miles per hour. RDX seems to struggle a bit more between these speeds. The steering in CX-7 is tight and it feels more comfortable when you are 40 miles/hour or above. The RDX on other hand is more nimble and if you are driving in town its more comfortable. I took an exit from the highway at more than 40 miles per hour in CX-7 and there was some amount of body roll. The pushy car sales man sitting next to me was swept to the side. I did not get a chance to test this with RDX.
6. The ride in RDX is more bouncy, but if you are driving on a smooth road it gives a much smoother feel than CX-7. However the speed bumpers can be a real annoyance in RDX and you have to drive real slow over them.
Overall I liked both of them and I thought once I will test drive both of them it would be easier to pick. I find myself more confused now as to which one to pick. Though I would like to add that at this moment I am slightly leaning towards RDX.
You didn't mention your impressions about environmental controls; techy stuff such as sound system or navigation, blue tooth, aux inputs for MP3; seating comfort; cargo capacity; interior lighting; etc. All of rest of those considerations will help you make the right choice!
Bet you're having fun, eh?
Vince.
Seating comfort is good in both CX-7 and RDX and I did not find much of a difference there too, though seats are one of the most important feature to me.
I did checked the navigation system in RDX and it is really cool. The backup camera picture was a little dark though. I am not sure if that is how it is every car.
Overall the tech stuff is secondary to me, primary being the comfort and how the car rides and in this I felt RDX has a slight edge.
In other words, which one is the most fun to drive, has the most pizzazz and gives you that sense of exhilaration.
You've got your answer, I suspect! Enjoy! :P
Vince.
That is because Mazda is it's own company. They are not just another Ford vehicle. They just have a 33.4% stake in the company.
We don't say Toyota owns Subaru do we? Yes, Toyota owns a small piece of Subaru, 9% I think, and here in the states, they build vehicles in the same plant.
Furthermore, Ford even lists Mazda as a parent company on its main page, whereas Subaru is non-existent on Toyota's website...this fact alone obviously doesn't prove the differences between Ford/Mazda and Toyota/Subaru, but helps to show that Ford does have a slight hand in the decision-making of Mazda..i.e Escape/Tribute; Mazda3/S40; CX-9/Edge...the same can't be said for any Toyota/Subaru vehicles.
...despite Ford's involvement, my point is that Mazdas are very nice cars mostly because they are distinctively different from any other Ford vehicles (99% of the time).
Your point was that Ford designs cars for Mazda. Although Ford has a controlling 33.4% stake in Mazda, Mazda designs its own cars. Mazda has design studios in Japan, California, and Germany. Your statement makes it seem like Mazdas are designed by engineers in Dearborn, Michigan. Renault of France has a controlling interest in Nissan, however, I am yet to hear that Nissans and Infinitis are designed by Renault, nor where past Chryslers designed by Mercedes. Ford's stake in Mazda gives it veto power in board room decisions not in the design direction of Mazda vehicles. I seriously doubt that Ford hates itself so bad that they will design better products for Mazda than for itself. The credit to Mazda's design goes to Mazda and not Ford.
Just because there is technology sharing does not mean Ford does everything. The Mazda3 is on a Volvo platform, the Fusion is on a Mazda platform, as is the Edge and CX-9 (modified Mazda platform) Ford and Mazda use Volvo's AWD system (made by Haldex).
Mazda's chief designer is Laurens Van den Acker. Ford's is J Mays.
Ride quality
Firm, but the CX-7 feels more roomier and suspension is tight like a sports car. The RDX is not as good on handling but ok. A bit soft in my opinion.
Acceleration
CX-7 is lagging from 0-to ?? but from 15-to?? feels fast once you reach over 2500 rpm. RDX is smoother when accelerating from a stop. No lag. But clumsy on handling during acceleration.
Handling
RDX handles like and Accord not too sporty but ok. A bit wobbly. CX-7 handles like a BMW 3 series. Is like driving with Bilstein shocks. Excellent on handling especially on mountain roads. RDX is a cruiser and the CX-7 is a windy road warrior.
Seating
Seating is more up-right in RDX as in most SUV's. Inside CX-7 cushion is sporty and bucket seats wrap around you. The rear seat cushion in CX-7 is low. RDX rear seats has a little more space.
My personal opinion
CX-7 has a cool design compared to RDX
RDX has better quality material used in the car than CX-7
Gas mpg is comparable 18 mpg/22mpg (city/hwy)
HP is similar 244hp on CX-7 and 240 on RDX with comparable torque 255lb/ft on CX-7 and 260lb/ft on RDX
Aftermarket parts CX-7 has CAI for $270 and will increase hp by 9-10hp and not to mention you will here the turbo once you install it. Not sure about RDX.
Both require 91 octane. But 2008 CX-7 did a reflash on the ECU to just "Recommend" 91 octane instead of "required". Check with dealer on this (not sure yet). Personally, spend extra $0.20/gal, enjoy the turbo and make it last using 91.
BOTTOM LINE...I got my 2007 CX-7-sport for $19,995 + tax & lic. and my sister-in-law paid $31,800 (no/navi) + tax & lic. That's almost $12k difference. Why not buy another car with that kind of money! You can definitely get a decent car like an 02 Altima or 05 Civic, etc. I got a used 97 Lexus ES300 for $6,500.
How the heck did you manage that? Is it AWD? It has an MSRP of $26,045. Invoice is $24,406. There is $2000 of incentives, that brings you to $22,406. The CX-7's are selling like hot cakes, how did you manage $2,500 UNDER invoice???
I have been sold out of 2007's for about 2 months, and my 2008's are going fast.
I have been sold out of 2007's for about 2 months, and my 2008's are going fast."
Not as unusual as you think. I noticed an ad in the Washington Post yesterday, advertising new 2007 "up to $5000 off". I don't know what model, but I'm assuming they're the base model.
Vince
To re-iterate what has been lost in this babble: The CX-7 is a nice car and is distinct from other Ford-related vehicles.
Yes, the Tribute and B-Series pick-up. The B-Series is almost extinct. Also, how much influence does a "platform" really have on a vehicle. Look at the Edge and CX-9. Totally different. There is no comparison.
I ask you, how is the CX-7 related to other Ford vehicles? The CX-7 shares nothing with any Ford vehicle.
A few weeks ago I was rotating the tires on my CX-7, and was surprised to see "FoMoCo" on the front brake calipers. They, at least, are shared with a Ford something, I would think...
-c92
Yes, they do, but, just because the calipers are a Ford part, does not mean that the CX-7 is a Ford designed vehicle. Every vehicle made has parts sourced from other companies. Honda and Toyota shared transmissions for years, made by Aisin, as in the CX-7.
Bottom line, there is no vehicle that is entirely made by that mfgr. The CX-7 was not engineered, or designed by Ford. I believe that would be an accurate statement.
Check out your window sticker, if you still have it, it states "US/Canadian Parts Source 0%"
Maybe Mazda uses the brake caliper molds to produce the brake caliper, that is why is says "FoMoCo" on it.
Just because you are not aware of the interactions between Nissan and Renault (parts, platform, and engine sharing to name a few) does not mean there is none.
but their design teams obviously have some interaction/coordination with each other, which varies from car to car.
So how do you then attribute the design of the Mazda CX-7 exclusively to Ford as you stated (quoted below). Engineering and parts sharing is not the same as design. I think you have the two confused. Yes Ford and Mazda collaborate on engines, platforms etc, but it gets to a point in the development of a vehicle where each team will have to independently develop the product in order to give the product its respective brand DNA.
"I'm just glad ford has done a pretty good job of not designing Mazdas to look as cheap as fords! "
When we looked at the RDX then I asked the sales person about the back seat and he could hardly fit inside. He said you can't get everything and I agree with you on that. Today I placed a TURBO badge from the RDX on my cx-7 works wonders when another CX is on my rear and they be looking WTF! Probably wondering if a new CX-7 turbo model just came out or was it just a decal
