Please Advise on volvo 740
I have a 1992 Volvo 740 WAgon with 165,000 miles on it. This car is used for about 300 miles weekly taking several children to various activities. It is used up steep canyon roads several times daily due to the fact that we live in malibu with many canyons. This car seems to require various kind of maintenance and/or repair every 2-6 weeks which takes a day or two to do at a cost of $150 to $400 and we must rent a car when it's being serviced. We just found out we're having a transmission problem that cost up to $1,500 to fix. The car has stopped working in traffic and get's about 16 miles to the gallon. I'm very concerned about saftey with kids the primary riders in the car. The Aamco dealer says everything else is fine and it's a good car. My question is, at this point, would it be a better decision to use the money and purchase another used volvo wagon, a later model after 1995, that has less mileage, will need less maintenance, have better gas mileage, and more dependability so the although we'll need to pay on a monthly loan, it will still work out better than constantly fixing the 740. Since you all are 740 experienced owners, thought you'd have good advice. THANKS SO MUCH!!!!
2. The trans will cost $1500, the car is worth maybe $1000.
3. The car no longer works in traffic. So unless you are the only one on the road, your out of luck.
4. If the car is in the shop every 2-6 weeks, how can the mechanic say everything else is fine (from his point of view it is secured income)?
Volvos are great cars, they are expensive to work on. The older ones have their own little quirks (there are a number of web sites that will advise you of these). From what you describe, I would move on. But be aware, the 95, 96, 97, 98, etc. all have issues you may need to address; ABS Module, AC issues, etc. Do your homework.
As a very fresh member I just put one post in this 740 electric gremlin discussion, thinking that I was replying to a message from two days ago, but it was a year and two days ago... so this time I will be very short:
Find a pre 1990 Volvo 740. Avoid old cars with ABS. Or, import a good 740 Automatic from The Netherlands and use the transmission only (I guess engine / complete car can not be used due to different regulations for exhaust emissions, but it would be worth to check, maybe it may go like oldtimer...) Very good Volvos 740 can be found over here for few hundred EUR.
Regards from Den Haag, The Netherlands
Regards
Kurt
I did not find any exhaust leakage, which was a relief, as I had that replaced just under a year ago. But I did find one odd thing that I'm not sure about, and could use an answer for...
Am I supposed to be able to see my torque converter spinning, or is there supposed to be a cap over that 2" x 3" square hole I found there? It looks like there was something there, but I can't tell.
A-N
Any suggestions? Thanks in advance
Scot
Now if someone would just answer my question about that torque converter hole...
A-N
S.
Back in June, I purchased an '87 740GLE turbo wagon w/232k miles...on the long drive home, it kept overheating and the water pump blew, so it was replaced. But, overheating and loss of fluid in coolant chamber persisted. Upon further analysis, the mechanic discovered water in the engine; so replaced head gasket, had the head machined as it was warped; flushed the engine twice and put it back together.
Drove it "gently" but fluid still "disappearing"; no visible leaks externally. A second mechanic then took hoses off which connect the coolant chamber to the radiator and engine; did a pressure test and they held water, so to speak!
Just yesterday, took the Volvo on a 2hr round trip; had to refill fluid 3-4 times; but it never indicated on the dash display it was overheating. About an hour after being on the freeway, a significant loss of power occurred, the thermostat pegged into the red zone! The car shuddered a bit and then died. Upon checking under the hood, the coolant chamber was bone dry and oil was splattered all over the engine and hood. Tried to re-start without success. Then had it towed.
Anyone out there had similar experiences? Why/how is water getting into engine?
I am really getting frustrated!!
A second question for y'all...the mechanic who's working on it is lusting after the turbo...he's even offerred to trade out any work he does in exchange. So, would removing this device adversely affect the engine? not that i need the power and speed (am also getting crappy mileage!), but are there modifications on the engine to support the turbo which, if removed, could compromise its performance?
Please help...am at my wit's end!!
Namaste, graci, muchas gracias,
Suzan :sick:
My car came back from the shop after some fuel system work, and the central locking only works on the driver side door and the tailgate on my 740 wagon. Aahhah, I said to no one in particular, it must be the relay. The relay diagram for the 740 shows the central locking relay next to the power window relay in the left front of the relay rack. Removed it. No change. Removed the relay NEXT to it, which the diagram shows as an empty space. No central locking at all. Mechanic says the solenoids are shot. Three at once?
Anyone have this problem, or know the relay number for central locking?
The check engine light is on, but I do not know how to retrieve the codes.
What would be the first step ,or the first things I should look for.
Steve C.
kcram - Pickups/Wagons Host
