Toyota Sienna Engine Problems
new2diesel
Member Posts: 148
in Toyota
I have a 2004 XLE with approx 40,000 miles and I have a very persistent spark knock that is anoying. Does anyone know how to remedy this? I f I remember you used to be able to retard the timing just a touch and eliminate this one some vehicles. Would this work on this one and if so how can I go about doing it?
I have also noticed that these vans eat tires. I'm on my second set and they are already wearing unevenly (after alignment) and making the dreaded wop wop wop noise ( yes I rotate them and keep them inflated firmly).
Thanks for your help.
In a way, I can understand if these vehicles go through tires quicker than other vehicles b/c of friction. Just like sportscar tires wear out more quickly b/c they are made to grip the road and, thus, increase friction, the weight of the minivans should give more friction to the tires than other vehicles.
Good luck with your issues.
Has anyone experienced this problem? Can someone offer some advice? I like my Sienna but the vibration is starting to get on my nerves.
Second, Service RQD was on constantly. He said, it has to be reset everytime after oil change is due. Is this normal also.
and got fix at no charge.
Any ideas here?
What impact is there for not replacing this module as the car is running okay?
It reminds me of those old toy cars that had a little plastic strip that touched the gear to make a noise. After it does the noise (EVERY time I go somewhere), it won't do it again until I turn the car off and go somewhere else. I haven't tried putting it back in park after it does the noise to see if it does it again, but I am completely confused as to what it could be. Any ideas? I am hoping it's not something expensive in the transmission.
Do you know the TSB number so I can refer to it? Also how long did the repair take and did it work?
We had snow a while back and I had some kids in the car who asked me to go sideways on the ice. You should have heard the anti-lock brakes then. Sounded like a little motor running when the tires slid when I applied the brakes.
Engine "Pinging" or "Knock Noise"
TSB EG055-06 September 6, 2006.
I took it to local auto shop to get maintenance 3 days ago.
At that time, mechanic said my car's oil level was too low
even though I changed it just a few months ago.
The next day, he called me and said that one piston was broken and unless I change engine, my car will die on the road. And he said he had seen lots of similar problems in other Siennas and Avalons.
I picked up my car today and they charged 1600 dollars.
Can this case be covered with oil gel settlement?
And I'm not keeping any oil change receipts. Can I get reimburse for this?
Also, on the highway, the sienna seems as noisy/quiet as odyssey...
The 3.5l is louder than the old 3.3l because it uses a timing chain, but then again so does Honda. Plus, that means less maintenance down the road.
Also, for the 3.5l, normally only one opening in the intake is used. At more than half throttle, or over a certain rpm, the 2nd intake path is opened for more power, and yes it makes more noise while that path is opened.
Toyota added more insulation for 2007 to compensate for the extra noise, but at full throttle the engine asserts itself nicely.
THIS HUMMING VIBRATION OCCURRED CONSISTENTLY BETWEEN 2200 AND 2500 RPM.
HAVE YOU HAD THIS SAME EXPERIENCE WITH A TOYOTA SIENNA AND, IF SO, DID YOU FIND A CAUSE AND REMEDY?
The catch is timing chains are indeed noisier, so Toyota added some extra sound insulation in the firewall and in the door jambs. I have a picture of it and you can see it below.
Now, about the increase in noise at certain RPM - this engine also has 2 intake paths. Normally one is open to minimize intake road, but when the throttle is more than half way down and above a certain RPM the 2nd path opens to get maximum power.
You might be experiencing that valve opening and closing, effectively doubling the intake roar. And of course it varies according to RPM and throttle position.
FWIW, I don't think the noise is that bad. I've actually modified mine so that both intake ports remain open all the time. A set of vacuum tubes operates these and a simple mod leaves them both open all the time. I'm basically trading off a bit more noise for better throttle response, less hesitation, and (some say) better gas mileage.
PS I should note that the older 3.3l engine also has the dual port intake, but it uses a timing belt.
How do you that? Does this really improve gas mileage? If so, by how much??
Does this modification effects warranty? Did you do it yourself?
I have 3.5 engine.
http://www.angelfire.com/ky3/gabby/intake_mod.htm
The funny thing is that it almost didn't make sense to me. I can understand that freeing up the air intake would reduce hesitation and increase power under certain circumstances, but I didn't believe the improved mileage claim.
Thing is, I just can't argue with results. I drove to the beach this weekend and averaged 30.6mpg for the (all highway) trip. Yowsah.
That's better than I got doing the same trip in my Miata!
And we had 4 people, a dog, a little bit of luggage, and the A/C was on the entire time (DC summers in July are hot/humid).
I can't say exactly how much it improved my mileage because I've only had the van for 1700 miles. I did wait to do this until after the 1000 mile break-in.
The mod is very, very simple. You disconnect two vacuum hoses and re-route one to another location. I took the additional step of getting caps so that everything was sealed nicely.
Does it affect the warrranty? I'll answer "maybe". It's not stock, but it's very easy to reverse and there would be no signs of any mods. Plus, past half throttle the intake operates like this anyway. This just leaves it in that double-intake-path mode all the time. You don't have to wait for the vacuum tubes to operate and suck the 2nd intake path open, hence some people say it hesitates less (note I did not notice any hesitation prior to the change).
So this is your call. If you want to try it, note your mileage on a certain trip. Then, take that same trip again after the mod, and see if you notice a difference. The site claims a 1-2mpg improvement. I seem to observe about that much improvement, but again, my engine is green and breaking in, and it might have improved even without this mod.
Trade-off? More noise. My wife noticed it once, but we got used to it pretty fast, and I don't want to give up 30+mpg plus quicker throttle response, so to me it was worth it.
Does any now if the sienna can be converted to run on etanol (E85)fuel?
Plus, running on E85 actually costs more than running on gas.
So you'd be spending money in order to be able to spend even more money.
the regular 95 octane is about 12 swekr and the E85 is 7.50 swekr.
Here the savings are very small, and you get less mileage so it actually ends up costing more to operate.
New to this site and glad to have found it after all this time googling on the humming issue with '07 Sienna LE without substantial results.
Have 1700 miles and experienced the same exact issues: humming/moaning @ 2300-2500 rpm under load such as accelerating lightly but not enough to drop to the next lower gear. Especially noticeable on long stretch of inclines. The sound is very accurately described in your post - almost like a resonating exhaust vibration due to a resonate frequency in the narrow range of rpm. Don't know about the rest of the owners, but I find it very annoying when it does hum. Sounds almost as if I modified my exhaust system - and droning!
I tend to lean toward the exhaust noise as opposed to the intake noise especially as described the VSV takes on >3200 rpm. Reminds me of my late '85 corolla gts (redlines at 7500rpm) where it would operate the second set of intake valves after 4200 rpm.
Needless to say, I brought the van to the dealer for diagnostics and they were unable to find any problems. They informed me that they were unable to duplicate the noise which I had confirmed with one of mech. on a test drive. I guess this means that the noise is normal due to a design issue/flaw and that not too many drivers notice it.
I'm glad to find out that there are owners that experience this noise and that this "problem" does exist. Now what to do about this?
Wondering perhaps additional isolation engine mounts or something in the exhaust?
Anyone knows of TSB regarding this?
Toyota compensated by adding extra insulation on the firewall and under the door sills, so while cruising my Sienna is still very quiet.
Under full throttle it definitely asserts itself. But I like that. :shades:
The hesitation may be the two-path intake. There's more information about that (and how to modify the intake if you are so inclined) here:
Is this normal for Sienna?
Perhaps more will chime in regarding this noise. And hopefully with more comments comes recognition of this annoying sound so a technical service bulletin will be issued for additional sound/mechanical isolation requirements.
I'm going to test drive a couple and see....
Perhaps it's just that - road noise is very muted, so you hear more engine noise.
I say crank up the tunes! Nothing 100 decibels of DMB can't fix. :shades:
The noise does not bother me. If everyone is getting this, then this how is designed to work. I just wanted to know if my engine have problem.
The code will tell us more. Could be a loose gas cap, a bad 02 sensor, or something more serious.
I'm in the DC/MD area if you want to borrow mine.
http://townhall-talk.edmunds.com/direct/view/.f169371/7
In my case my wife (and now myself) can't stand this noise - weird noise is weird noise - it shouldn't be there.
After the engine cooled down, I reached down and removed it. Since there's quite a bit of room between the pipe and any other component, unless this is covered by a recall or TSB, I'm not inclined to fix it.
Has anyone else had this happen?
