Subaru Forester Suspension/Steering Questions
Discuss Forester suspension and steering issues here.
The biggest beef I have, however, is with the carrying capacity of the '07. This is a car for camp, and frequently I buy a big load of firewood and load up the back of the car. '04: no problem, barely a sag in the rear. '07: loss of at least 2 inches of ground/wheel clearance - this thing sags like a '77 Caddy which has never had its suspension replaced! This is a load that is not even close to 900 lbs.! Tire inflation was fine, too, although I noticed that there is no "range" for the rear tires given for the '07 vs. the 6 pound range that was given for the '04 depending on load size.
Two questions: 1.) Did the suspension change drastically between the '04 and the '07? (BTW, I just drove a friend's '04 yesterday, and noticed the same thing, so it does not appear to be car-specific.) 2.) This is an unacceptable situation: what can I do about it? Can I get the self-leveling struts from the LL Bean model put onto my car? How about the STI springs? It seems to me that Subaru recognizes that this is a problem given the "high beam leveler" offered on the Canadian model, as well as the "self-leveling strut" on the LL Bean model.
Any help would be greatly appreciated.
So it starts out about half an inch taller than the old one. I'm not surprised that it'll sag more, then.
The LL Bean struts should fit, but they are pricey. Get a Chase card and save up Subaru Bucks for that.
-juice
Sometimes perceived changes, among those prone to being "picky" or big enthusiast's, make them more sensitive to those refinements. And they are more resistant to changes.
-mike
I have researched it and found some of the reasons. They may have added .1 as in from 3.0 to 3.1 wheel turns from lock to lock...and then added boost to the power steering.
Here is an article that describes it exactly...
http://www.automotive.com/2006/43/su...ons/index.html
"This is where we don't necessarily like Forester's 2006 "improvements," even if it largely comes down to taste. The new suspension settings seem to have moved Forester a bit closer to the SUV side of the crossover equation and further from the car side. The steering feels a hint more numb than before, and the Forester more reluctant to turn, with more lean in the body through a fast curve. None of it seriously detracts from the Forester's handling edge compared to a truck-based SUV, and many drivers will never notice. But if you're inclined to attack a winding road, even in your little SUV-car, you probably will notice."
Some others have told me they could have used softer bushings etc. and that in conjunction with the raise in height would add the roll.
If you go to Scoobymods or the Subaru Forester Owners Forum there are people that can tell you how to "retune" your suspension. I am probably going to engage in some of the changes in the spring. Not sure which ones yet. I think I'm stuck with the steering difference.
Oh no... I tow a 1900 pop up and didn't extrapolate yet to this. Like you the 200 lb tongue weight barely lowered my back end on my 04. I am really going to be upset when I hook up and have the back end go down. I have explored the addition of the load leveling just for the heck of it before this and it sounds like it is very very expensive. The struts themselves...if you can get them are around 200 apiece. Then you have to change your springs etc.
I believe the basic "metal" set up is the same as the 04 (which by the way was how the vehicle was originally engineered in a wholistic fashion)and it is just the big mushy bushings and things at the top of the struts between the frame etc that have done most of this.
OH and many of the Australians who get load leveling struts on over half their models have issues with the load leveling struts and are asking about switching them out for regular ones...LOL. They go out surprisingly regularly but then again, they use them. There's even a poll on this on one forum. Oh the Aussies get dual range manual transmissions. Subaru tries to tell U.S. they don't exist.
You can retro in STI suspension elements and really tighten up things I am told and with the bushing etc. changes it should be OK...but not cheap. Even if I or a friend does the labor.
-mike
-Brian
It's an 03 Forester XS, purchased in Sep 02. She doesn't put a lot of miles on (34k now) so we actually did the 3yr/36k service at 3 years in Oct 05.
Thanks for any info.
-cb
-mike
-cb
-mike
I have mentioned this before when doing oil change at the subaru dealer and they don't seem to find anything.
Any hints and tips on how can I find out what is the problem?
Thanking you in advance, Elizabeth
-juice
-juice
..."clank"... no grinding noise...
What else would you think? Something that wears out ? what could it be that wears out in the drive train?
We had a 626 and an axle boot tore, leaking out all the grease. That created symptoms similar to what you describe. A sharp rock probably cut the rubber.
-juice
David
Thanks. Jim
-mike
ClintonRon
Check the axle boots. We had a 626 that leaked black grease from a torn boot.
-mike
So calling it a lemon seems a tad premature. I recommend you take it to a trusted mechanic for a thorough going over. Once you get it in good running shape, the odds are good that it'll give you another 10 years of service
-Frank
-mike
I'm wondering if you ever got this problem resolved and what was it? My car is being repaired now for a similar problem but mine also makes a noise when backing up to the left or right and when braking. They think its a bushing so keeping my fingers crossed but won't rest easy until fixed!
Shane
I'd also move the tires around to see if it moves, that would indicate a problem with the rim or tire. If you move the tires and the problem is on the same wheel then it's either bearing or axle or both.
-mike
Thanks Roy
-mike
You could engine de-gunk, but again, cover any electrical wires, rubbers, plastics. That may be hard.
Do no use a steam-cleaner - that will get warmth and water on the electrical contacts, which is exactly what you do not want.
It will burn off over time.
-mike
for a complete discussion of the problem you can find it on the page below with a subject line of #17737 of 17762 Subaru Forester suspension noise or what?
http://townhall-talk.edmunds.com/WebX/?14@@.ef0d013/17725
Any ideas?
If not, check the axle boots, make sure they're not torn, maybe re-grease those.
If it has, changing the tires won't fix the coupling which would have to be replaced!
