Infiniti FX35 Burning Smell
Just picked up a 2004 FX 35 from a good friend. I have noticed a smell of burning rubber or plastic after driving it for a few minutes. I have the 2WD version. My friend told me she never had that issue.
I checked the oil level and it is fine, and the car has been regularly serviced by Infiniti. Anyone else have this problem? Any thoughts on what this might be?
A search revealed a few other posters with a similar problem, but those all appeared to be related to use of AWD.
That's my .02 for the easy stuff to check.
The brake is definitely not engaged. What do you mean by hand brake? I only saw a foot emergency brake. Thanks.
But I bet some of the tarp burned into the exhaust system or some other part that gets hot underneath.
If it doesn't burn off or get better in a couple of days, you may want to see if any codes have been thrown by the car's computer system just to rule out a mechanical problem. Many auto parts stores will pull the codes for free.
I suppose the burning plastic could be an electrical smell from wiring insulation burning off. That could be bad.
Anyone else have any suggestions for things to check?
The smell on mine wasn't noticeable inside the car though.
1) Catalytic converter is breaking in. I already have 25K miles. How much longer can it break in?
2) Use different brand of gas. We tried, but since the problem is occasional it's hard to make a conclusion.
3) Catalytic converter is cold on short drives needs time to warm up.
If anyone was able to fix this problem or determine with certainty the reason, please post. Otherwise - LOVE MY FX!!!
My leased FX45 has the same mold odor problem. Did you find a resolution to your problem?
